View Single Post
Old October 14th 06, 02:45 PM posted to rec.aviation.piloting,rec.aviation.student
Robert Chambers
Default Beacons/anticollision lights and engines
Haha, in a 737... you mean in Bill Gates somewhat grainy representation
of a 737 you mean.
prior to engine start the beacon goes on, once you start up if it's
night time put all the lights on for taxi, if there are others that
might be impacted by the strobes turn them off, if you're flying in a
cloud (or in your case a pretend cloud) turn the strobes off to prevent
the reflection of the strobes from giving you vertigo - you might fall
off your chair.
Mxsmanic wrote:
Kingfish writes:
Hmmm. Do you turn on your virtual strobe before you start your virtual
engine, so as not to endanger anyone with your virtual prop?
I turn on the beacon. I understood that the strobe is for low
visibility conditions and that a lot of pilots are irritated by
strobes operating on the ground. Whereas the beacon simply indicates
that the engines are turning (in addition to improving visibility).
In a 737, I turn on the anticollision lights before engine start.
