How to Remove Piston from Cylinder
Old October 1st 08, 07:29 PM posted to rec.aviation.owning,rec.aviation.homebuilt
Paul Dow (Remove Caps in mail address)
Default How to Remove Piston from Cylinder
A member of our EAA chapter has a cylinder from a Franklin 150 engine
(off the engine.) The piston was pushed too far up and the top ring
sprung out so it now overlaps the cylinder sleeve which locks the piston
in place.
Does anyone have a technique to get the piston out? Preferably while
doing the least amount of damage. (So no explosives, please!)
Thanks,
Paul
Old October 1st 08, 08:25 PM posted to rec.aviation.owning,rec.aviation.homebuilt
Gig 601Xl Builder
Thanks,
Paul
How do expect any help if you tie our hands?
Old October 3rd 08, 08:22 PM posted to rec.aviation.owning,rec.aviation.homebuilt
Dan[_12_]
Thanks,
Paul
"There are very few of man's problems that can't be solved by the
proper application of the appropriate explosives." - Ragnar "oops" Benson
Dan, U.S. Air Force, retired
Old October 4th 08, 12:21 AM posted to rec.aviation.owning,rec.aviation.homebuilt
Vaughn Simon
"Dan" wrote in message ...
"There are very few of man's problems that can't be solved by the proper
"Blo-Jell ! The plastic explosive you use at home. Great for those pesky stuck
window frames; better than a string and a doorknob for removing Junior's loose
tooth" (As remembered from the Prairie Home Companion show)
Vaughn
Old October 4th 08, 02:33 AM posted to rec.aviation.owning,rec.aviation.homebuilt
Dan[_12_]
Vaughn
I prefer hand grenades. They can be used for fishing, removing walls
from fingerprints, getting your neighbour to stop mowing the lawn too
early..etc.
Hand grenades are also very effective for painting rooms. One opens a
can of paint, places it on the floor in the geometric centre of the
room, pulls the pin from the grenade, drops it into the, vacates the
room, and voi ci, a painted room.
Old October 1st 08, 09:49 PM posted to rec.aviation.owning,rec.aviation.homebuilt
Bob Kuykendall
in place...
The last time I heard of that happening, the guy sawed the cylinder
head off the top of the cylinder with a bandsaw. In the process, he
zinged the piston pretty bad, pretty much ruining everything there.
My advice would be to see if there's a cylinder overhaul shop with the
capacity of unscrewing the head from the barrel. If so, send it to
them and see if they can rescue it. If not, make a lamp or bookend out
of it.
Thanks, Bob K.
Old October 1st 08, 11:05 PM posted to rec.aviation.owning,rec.aviation.homebuilt
Bill Daniels
"Bob Kuykendall" wrote in message
in place...
of it.
Thanks, Bob K.
That'd be my advice as well. I've watched as one of these shops mounted a
cylinder in their jig and very precisely and evenly heated the head until it
unscrewed. I was told they keep the aluminum head and replace the steel
barrel. I'd bet your friend won't be the first to show up with this
problem.
Old October 2nd 08, 12:47 AM posted to rec.aviation.owning,rec.aviation.homebuilt
Thanks for the replies.
Unfortunately it looks like the head doesn't unscrew like a Lycoming or
Continental would. This is from a Franklin engine, so we believe it's a
single piece casting. I guess a cylinder shop could heat barrel to get
the steel sleeve out. Hopefully that will provide enough clearance to
get it out.
If not, I guess it gets turned into a tacky lamp. I could put it next to
the other lamp I won as a "Major Award".
Paul
in place...
of it.
Thanks, Bob K.
problem.
Old October 2nd 08, 01:11 AM posted to rec.aviation.owning,rec.aviation.homebuilt
John Kunkel
"Paul Dow (Remove Caps in mail address)" wrote in
message ...
A member of our EAA chapter has a cylinder from a Franklin 150 engine (off
the engine.) The piston was pushed too far up and the top ring sprung out
so it now overlaps the cylinder sleeve which locks the piston in place.
Does anyone have a technique to get the piston out? Preferably while doing
Take an old spark plug and break out the ceramic center, then thread the
steel body for a zerk fitting. Be sure both valves are closed, hook up
grease gun and start pumping; you might be able to build enough pressure
(grease guns are cabable of several thousand psi) to break the ring and
force the piston out or even push the liner out of the one-piece
cylinder/head.
Old October 2nd 08, 03:31 AM posted to rec.aviation.owning,rec.aviation.homebuilt
steel body for a zerk fitting. *Be sure both valves are closed, hook up
cylinder/head.
Adding to that idea heat the whole thing in an oven and then pack the
bore with ice upon removal. Remove the piston and the steel liner as
one assembly. Then renew as one would normally with a Franklin
cylinder/head combo ????
Never had this problem, and never tried this fix .............. Pure
speculation on my part.
Leon McAtee
Will remember not to do the same with my Franklin :-)
Oil in cylinder, other cylinder issues Robert M. Gary Piloting 7 May 27th 07 05:26 AM
Oil in cylinder, other cylinder issues Robert M. Gary Owning 8 May 27th 07 05:26 AM
Oil in cylinder, other cylinder issues Jim Burns[_3_] Owning 2 May 24th 07 05:26 AM
Oil in cylinder, other cylinder issues Robert M. Gary Piloting 0 May 23rd 07 10:44 PM
Oil in cylinder, other cylinder issues Robert M. Gary Owning 0 May 23rd 07 10:44 PM
