o and io engines
Old May 4th 06, 06:45 AM posted to rec.aviation.owning
Default o and io engines
whats the difference from IO and O engines?
Old May 4th 06, 06:57 AM posted to rec.aviation.owning
O is for "opposed", like flat VW and aircraft engines.
I is for "Injected"
so, an O470 is an Opposed, 470 cu. in. engine, by default, its
carburetted
an IO470 is an Fuel Injected, Opposed, 470 cu.in. engine.
Old May 4th 06, 02:27 PM posted to rec.aviation.owning
As someone else has already explained, fuel-injection vs. carburetion.
You might be interested in the information at http://www.prime-mover.org/
There's a lot of basic engine information there. Under the Lycoming section,
look for the "key reprints" in particular. I think the answer to your question
is in there somewhere, among many other things.
Dave
Old May 4th 06, 05:11 PM posted to rec.aviation.owning
For the Lyc 360, the difference is 20 horsepower.
-Robert
Old May 4th 06, 07:13 PM posted to rec.aviation.owning
....or, you could say the difference is 'I'.
Old May 4th 06, 07:38 PM posted to rec.aviation.owning
Yes, I be the difference.
Old May 8th 06, 01:40 PM posted to rec.aviation.owning
-Robert
But that's not a universal truth. In fact, there are sometimes
different HP ratings for the same major engine major series...
IO-470's for example come in different HP ratings based on the
suffix (an IO-470-C is like 240HP, where an -H gets 260).
Old May 4th 06, 08:39 PM posted to rec.aviation.owning
"Lets Fly" wrote in message
The I.
Old May 4th 06, 10:06 PM posted to rec.aviation.owning
Fuel injected engines usually burn less fuel for the same horsepower
due to more even fuel flow.
Old May 5th 06, 02:21 AM posted to rec.aviation.owning
For the Lycoming series its horsepower, not fuel flow. In fact, every
plane I've ever flown from Bonanzas to J-3's have burned 1/2 of 10% of
its horsepower (200hp burns 10gal/hr 65 hp burns 3.5 gal/hr, 250 hp
burns 12.5 gal/hr). All this same for carb and fuel injected.
The difference between an IO-360 and O-360 is 200 hp for the IO and 180
hp for the O. The 200hp burns about 10 gal/hr in cruise and the 180hp
burns about 9 gal/hr.
Otherwise the IO-360 and O-360 are 100% the same engine. Stick a FI
system on the 360 and you get an extra 20 hp.
-Robert
Home Built Aircraft - Alternative Engines - Geo/Suzuki OtisWinslow Home Built 1 October 12th 05 02:55 PM
Book Review: Converting Auto Engines for Experimental Aircraft , Finch Paul Home Built 0 October 18th 04 10:14 PM
P-3C Ditches with Four Engines Out, All Survive! Scet Military Aviation 6 September 27th 04 01:09 AM
Engines and Reliability Dylan Smith Piloting 13 June 30th 04 03:27 PM
Accident Statistics: Certified vs. Non-Certified Engines Ron Wanttaja Home Built 23 January 18th 04 05:36 PM
