Hello all... just looking for input on getting and airspeed indicator
overhauled. Any luck on shops/etc? My True ASI in my cherokee appears to have a bit of a static leak. Thoughts on shops? I had good luck with Kelly Instruments (KS) with two gyro overhauls last summer. Also, any thoughts on whether it's allowed or a good idea to get it repainted to indicate KTS, rather than MPH on the major (and true) scale. Minor thing, I know, but everything else I use (charts, GPS, DME, etc) is in NM, and it'd be one less step to calculating TAS enroute. -Cory -- ************************************************** *********************** * The prime directive of Linux: * * - learn what you don't know, * * - teach what you do. * * (Just my 20 USm$) * ************************************************** *********************** |
I just had one overhauled by Keystone Instruments in PA.
(http://www.keystoneinstruments.com/) If your TAS has a setting knob, try some grease around the knob shaft first. They always leak there. wrote: Hello all... just looking for input on getting and airspeed indicator overhauled. Any luck on shops/etc? My True ASI in my cherokee appears to have a bit of a static leak. Thoughts on shops? I had good luck with Kelly Instruments (KS) with two gyro overhauls last summer. Also, any thoughts on whether it's allowed or a good idea to get it repainted to indicate KTS, rather than MPH on the major (and true) scale. Minor thing, I know, but everything else I use (charts, GPS, DME, etc) is in NM, and it'd be one less step to calculating TAS enroute. -Cory |
Rip wrote:
: I just had one overhauled by Keystone Instruments in PA. : (http://www.keystoneinstruments.com/) If your TAS has a setting : knob, try some grease around the knob shaft first. They always leak there. I haven't looked too closely at it yet, but I thought there was a thread going a few weeks ago where people swore the knob didn't matter. That would make sense, because I can't imagine an ASI like this *NOT* leaking like a seive when the shop pumps static down to 20kft with the gauge at STP. -Cory -- ************************************************** *********************** * The prime directive of Linux: * * - learn what you don't know, * * - teach what you do. * * (Just my 20 USm$) * ************************************************** *********************** |
The static port is connected to the case. The knob shaft goes through
the case, and is supposed to be sealed with an "O" ring. If you grease the shaft and your static leak goes away, you know where the problem is. wrote: Rip wrote: : I just had one overhauled by Keystone Instruments in PA. : (http://www.keystoneinstruments.com/) If your TAS has a setting : knob, try some grease around the knob shaft first. They always leak there. I haven't looked too closely at it yet, but I thought there was a thread going a few weeks ago where people swore the knob didn't matter. That would make sense, because I can't imagine an ASI like this *NOT* leaking like a seive when the shop pumps static down to 20kft with the gauge at STP. -Cory |
Rip wrote:
: The static port is connected to the case. The knob shaft goes through : the case, and is supposed to be sealed with an "O" ring. If you grease : the shaft and your static leak goes away, you know where the problem is. I stand corrected... will check. Er... have my licensed/certified person check for me. -Cory -- ************************************************** *********************** * The prime directive of Linux: * * - learn what you don't know, * * - teach what you do. * * (Just my 20 USm$) * ************************************************** *********************** |
I've thought about the knots converstion also, but it seems to me that
reading in knots when all of your placards and POH standards are in MPH is asking for trouble when things get dicey and you get busy. |
PaulH wrote:
: I've thought about the knots converstion also, but it seems to me that : reading in knots when all of your placards and POH standards are in : MPH is asking for trouble when things get dicey and you get busy. Eh... yeah. I'm sure that's how the FAA would decree it's illegal to do this. If they're both still painted on (just swapped), I figure it's still the same indicator. I was planning on converting the numbers in the POH (rarely consulted) and checklists (usually consulted). Besides, most important speeds: Vy: 85 mph \approx 75 kts Vx: 75 mph \approx 65 kts Easy to remember converted numbers. The rest are painted on the dial. -Cory -- ************************************************** *********************** * The prime directive of Linux: * * - learn what you don't know, * * - teach what you do. * * (Just my 20 USm$) * ************************************************** *********************** |
Cory:
I had to have the ASI repaired (went for a new one, since I was dealing with 35 year old ASI) and had it marked exactly the same as the old one -- both MPH and KTS. Didn't cost anything different. |
Instrument overhaul - Are all overhauls created equal? | RonLee | Home Built | 1 | February 7th 05 06:35 PM |
Engine... Overhaul? / Replace? advice please | text news | Owning | 11 | February 17th 04 04:44 PM |
Overhaul? Lead flakes in oil - interpretation please | Les Sullivan | Owning | 14 | February 7th 04 05:29 PM |
O-200 overhaul & Vari EZ value | Steve Ruse | Home Built | 13 | October 21st 03 09:52 PM |
AI/DG Overhaul shops | [email protected] | Owning | 3 | August 20th 03 05:08 AM |
