My lower tail nav light doesn't work because the braided metal ground
strap that connected the tailcone to the light housing fell off the tail cone side. I can't tell (at least from the outside) how it was originally attached to the aluminum skin. I don't see a rivet -- would it have been soldered? Crimped somehow? -- Ben Jackson http://www.ben.com/ |
strap that connected the tailcone to the light housing fell off the tail cone side. Usually they are connected with a crimp ring tongue on the braided strap and by a screw to the frame that the tail cone attaches to. John Dupre' |
You didn't specify make/model, but on my C182, the Grimes lamp
holder assembly is mounted on the fiberglass tailcone. There are two wires, power and ground. Each has the aircraft-style "quick connect" interlocking-blade connectors (the kind that have a piece of insulating sleeve pushed over them). The power wire comes through the rear fuselage bulkhead via a grommet. The ground wire is grounded to that same bulkhead with a crimp-on ring-tongue terminal under a 6-32 screw. At each annual, it only takes a moment to remove the fiberglass tailcone and to disconnect the blade-tongue connectors. MikeM Ben Jackson wrote: My lower tail nav light doesn't work because the braided metal ground strap that connected the tailcone to the light housing fell off the tail cone side. I can't tell (at least from the outside) how it was originally attached to the aluminum skin. I don't see a rivet -- would it have been soldered? Crimped somehow? |
Almay Hypo-Allergenic Kinetin Skin Care Value$32.89 | [email protected] | Aviation Marketplace | 0 | April 29th 04 11:41 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 03:52 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 06:24 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
Antenna Ground Plane Grounding | Fastglasair | Home Built | 1 | July 8th 03 05:21 PM |
