Engine analyzer.
I am considering installing an engine analyzer/monitor on my 67 skylane with
a Continental 0-470....opinions options thoughts.................. |
Engine analyzers are becoming more and more popular. They give you the
cylinder head temperatures and the exhaust gas temperatures for all your cylinders. That said, there is no real evidence they prevent engine failure or prolong TBO, despite the many testimonials to the contrary. This is probably especially true of a cool running engine like the carbureted O-470 in a Skylane - there is little you can do except adjust the mixture. I wouldn't bother with the expense. Just my opinion. DB |
I also have one in my 67 182. Nice blinkin' lights but I wouldn't do it
again. Doodybutch wrote: Engine analyzers are becoming more and more popular. They give you the cylinder head temperatures and the exhaust gas temperatures for all your cylinders. That said, there is no real evidence they prevent engine failure or prolong TBO, despite the many testimonials to the contrary. This is probably especially true of a cool running engine like the carbureted O-470 in a Skylane - there is little you can do except adjust the mixture. I wouldn't bother with the expense. Just my opinion. DB |
On Wed, 24 Nov 2004 13:12:28 -0700, Newps wrote:
I also have one in my 67 182. Nice blinkin' lights but I wouldn't do it again. I've spent a lot more time installing and maintaining (troubleshooting and repairing faults where the owner was convinced he/she had a serious engine problem) "graphic engine monitors" than I have using an engine monitor to help diagnose a problem. The only instance I've ever had on the shop floor where a problem was identified by an engine monitor in-flight was an engine that spit out the pipe plug in the alternate position for the fuel injector nozzle. I've installed a bunch of digital TIT and multi-point EGT systems (with a selector switch), and overall have had good luck with them. A little bit of common sense and an accurate digital EGT works quite well. TC |
My A&P was of that school, told me I was wasting my money when I put in a JPI
EDM700. Wouldn't you know it, the JPI paid for itself when I had a rough engine problem a month later. Turned out to be a card that wasn't atomizing the fuel, but we could see exactly what the engine was doing. We would have probably spent several times the labor hours chasing that without the analyzer. He now recommends analyzers to his customers. You are right, when everything is working perfectly, the analyzer is little more than a box with blinkin lights. When the engine gets rough or worse though, you have an immediate indication on where to look, and the response gives narrows down the possible causes pretty quickly, before the cowl is even opened and before the A&P punches the time clock. Doodybutch wrote: Engine analyzers are becoming more and more popular. They give you the cylinder head temperatures and the exhaust gas temperatures for all your cylinders. That said, there is no real evidence they prevent engine failure or prolong TBO, despite the many testimonials to the contrary. This is probably especially true of a cool running engine like the carbureted O-470 in a Skylane - there is little you can do except adjust the mixture. I wouldn't bother with the expense. Just my opinion. DB -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
I would highly recommend them. They really help in saving fuel and
give you indications of what is wrong (high egt's when one mag quits, wrong egts and cht's if timing is off by a lot, (like when the mechanic screws up the timing due to his faulty buzz box)), stuck valves, bad spark plugs etc. They tell you a LOT and help you lean to max economy or max power. If the 6 cylinder jobs are too expensive a, one cylinder unit is better than nothing. I wouldn't own a plane without one. "R.T." wrote in message ... I am considering installing an engine analyzer/monitor on my 67 skylane with a Continental 0-470....opinions options thoughts.................. |
I own an EI analyzer.
Highly recommended and the best investment you will make in your aircraft. For more info, look up engine analyzer in Cessna Owner Organization. Check out Walter Atkinsons comments - he really does know what he is talking about. Tony C- GICE In article , "R.T." wrote: I am considering installing an engine analyzer/monitor on my 67 skylane with a Continental 0-470....opinions options thoughts.................. -- Tony Roberts PP-ASEL VFR OTT Night Cessna 172H C-GICE |
We've got the JPI EDM-700 on our Lycoming O-540, and love it.
In fact, I'm in the middle of diagnosing an engine problem that the JPI has made much simpler to correct. The #2 cylinder is not always firing, but only when set to the left mag. Our ONLY indication of trouble was when the bar graph shot up to 1650 degrees (EGT), and the CHT dropped to 200. The engine never changed sound, or missed a beat. (Well, until we turned the mags to "left" instead of "both".) Without the JPI, we wouldn't have known we had a problem. Which is why I bought the thing in the first place! In my opinion, it has paid for itself. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote: We've got the JPI EDM-700 on our Lycoming O-540, and love it. In fact, I'm in the middle of diagnosing an engine problem that the JPI has made much simpler to correct. The #2 cylinder is not always firing, but only when set to the left mag. Our ONLY indication of trouble was when the bar graph shot up to 1650 degrees (EGT), and the CHT dropped to 200. The engine never changed sound, or missed a beat. (Well, until we turned the mags to "left" instead of "both".) Without the JPI, we wouldn't have known we had a problem. Which is why I bought the thing in the first place! In my opinion, it has paid for itself. And if it turns out that the plug was fouled the analyzer didn't do anything but make you nervous. |
Similar Threads | ||||
ROP masking of engine problems | Roger Long | Owning | 4 | September 27th 04 07:36 PM |
Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 06:42 PM |
Car engine FAA certified for airplane use | Cy Galley | Home Built | 10 | February 6th 04 03:03 PM |
Tanis Pre-heater with Engine Analyzer | O. Sami Saydjari | Owning | 12 | January 29th 04 12:50 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
