Our gliding club towplane (Piper Super Cub) has developed play in the
Fuselage / Main strut connection - Portside. The bolt and clevis (Fork) seem to be OK bolt is a reasonably snug fit in the fork. - I presume the play is in the hole in the Bracket welded to the fuselage. Play seems to be about 10 thou (+-.25mm) which translates to about .75 inch of "Waggle " At the wing tip. Can anyone help with the following - What is the permitted wear at this point ? (If any) What approved repair methods can be used here? Thanks in advance Best wishes from Cape Town John Spargo |
![]() "John Sp" wrote in message ... Our gliding club towplane (Piper Super Cub) has developed play in the Fuselage / Main strut connection - Portside. The bolt and clevis (Fork) seem to be OK bolt is a reasonably snug fit in the fork. - I presume the play is in the hole in the Bracket welded to the fuselage. Play seems to be about 10 thou (+-.25mm) which translates to about .75 inch of "Waggle " At the wing tip. Can anyone help with the following - What is the permitted wear at this point ? (If any) What approved repair methods can be used here? Being a pilot myself, I think you have more of a concern that merely fixing the play in the strut end. If it has been wiggling the the hole, there's a high likelihood of fretting corrosion and fatigue in the element around the hole. I hate to say this, but you might need to check if there are any Airworthiness Directives out on that model, about that part. LLoyd |
I am not sure if this is something you want to play around with
yourself. I would consult a licensed aircraft mechanic. There may be a repair scheme for this or it may have to be replaced. A mechanic familiar with the aircraft would know. Having worked on aircraft engines, nothing gets fixed without an engineer working out an approved repair. Or as we used to say " no engine flys till the paperwork weighs as much as the engine" :-) John Sp wrote: Our gliding club towplane (Piper Super Cub) has developed play in the Fuselage / Main strut connection - Portside. The bolt and clevis (Fork) seem to be OK bolt is a reasonably snug fit in the fork. - I presume the play is in the hole in the Bracket welded to the fuselage. Play seems to be about 10 thou (+-.25mm) which translates to about .75 inch of "Waggle " At the wing tip. Can anyone help with the following - What is the permitted wear at this point ? (If any) What approved repair methods can be used here? Thanks in advance Best wishes from Cape Town John Spargo |
Thanks - Have no intention of repairing this - do want infromation though.
Regards John "machineman" wrote in message news:YPFre.55319$HI.1726@edtnps84... I am not sure if this is something you want to play around with yourself. I would consult a licensed aircraft mechanic. There may be a repair scheme for this or it may have to be replaced. A mechanic familiar with the aircraft would know. Having worked on aircraft engines, nothing gets fixed without an engineer working out an approved repair. Or as we used to say " no engine flys till the paperwork weighs as much as the engine" :-) John Sp wrote: Our gliding club towplane (Piper Super Cub) has developed play in the Fuselage / Main strut connection - Portside. The bolt and clevis (Fork) seem to be OK bolt is a reasonably snug fit in the fork. - I presume the play is in the hole in the Bracket welded to the fuselage. Play seems to be about 10 thou (+-.25mm) which translates to about .75 inch of "Waggle " At the wing tip. Can anyone help with the following - What is the permitted wear at this point ? (If any) What approved repair methods can be used here? Thanks in advance Best wishes from Cape Town John Spargo |
Earlier, John Sp wrote:
...Play seems to be about 10 thou (+-.25mm) which translates to about .75 inch of "Waggle" At the wing tip... I'm not an engineer, but somehow that doesn't add up. Simple geometry suggests that in order for 0.010" of play at the root to yield 0.75" at the tip, the ratio of the depth to the semispan would have to be around 75:1. Operating from basic specs and a grainy 3-view, it looks to me like the semispan is around 17 feet and the depth (height from the wing mount to the strut mount) is around 4 feet. That yields an actual semispan/depth of only around 4:1. With that arrangement, +/- 0.010" of play at the bolt yields a vertical play at the wingtip of around +/- 0.040". Some semi-random comments on this situation, in no particular order: * There's a thread on a similar topic on the discussion boards at http://www.supercub.org but it seems to concern J-3 rather than PA-18. However, I'll bet that you would more quickly get a good response on that board than here. * Was there perhaps a typo in this post? If the .75 is mm instead of inches, then it all makes sense. On the other hand, I can't imagine worrying about .75mm of wingtip vertical play... * I know from measuring wing mounting play on various gliders that it is very hard to measure wingtip vertical play separate from wing flexibility. It's hard to tell where mechanical slop ends and limberness begins. * It's possible that you are actually seeing +/- 0.010" of play at the strut bolt and 0.75" of vertical play at the tip. But only if there are also other sources of play such as the fuselage-to-wing mounting, or the strut mount provisions inside the wing. * A certain amount of play is inevitable. There is simply no way of making the wing mounting provisions completely tight without using interference fit fasteners. Good luck, and best regards Bob K. http://www.hpaircraft.com |
On Tue, 14 Jun 2005 20:50:15 +0200, "John Sp"
wrote: Our gliding club towplane (Piper Super Cub) has developed play in the Fuselage / Main strut connection - Portside. I was going to guess portside then I reread your message. I used to tow with a PA-12. I'm guessing that upon release, your pilot is doing a slipping spiral on the wingtip like I did. Lots of vibration and shuddering. Possibly the cause of the wear. I know that doing that makes controling the airspeed a matter of feel rather than instrumentation. Perhaps a little overspeed is mixed in? I was taught to do that to prevent cold shocking the engine and to get back on the ground ASAP. As we only had one sailplane, I wasn't in a hurry to get down, but it was fun to do and the people on the ground loved to see me do it. |
I learned to fly in a J-3 and I have owned various steel tube airplanes
over the years... I have helped to jig, drill, and ream the fuselage tabs and mount biplane wings... I doubt that there is any wear allowed by Piper at that lower spar attach tab... The hole in the fuselage tab should be a close tolerance fit for the bolt... I always considered the wing tip shake test to require no relative movement of the wing in relation to the strut/fuselage - other than the usual springing/bouncing of the entire airframe with a vigorous shake... With any slop in the strut flutter becomes an issue... I urge that you folks get an experienced steel tube airframe mechanic to make the repair soon... denny |
Heater problem fixed! | Jim Burns | Owning | 14 | December 17th 04 10:38 PM |
SSA Website problem | Raphael Warshaw | Soaring | 2 | February 12th 04 02:56 PM |
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Home Built | 78 | December 3rd 03 09:10 PM |
Help with serious Glider Registration Problem | Soaring | 5 | November 12th 03 04:01 PM | |
Problem: Ground Speed Estimate with Volkslogger and WinPilot | RamyYanetz | Soaring | 3 | August 26th 03 03:06 PM |
