Aerodynamics of carrying water
Old October 11th 05, 03:55 AM
Gene Whitt
Default Aerodynamics of carrying water
Y'all,
Been many years on rec.aviation.student but even more years since
gliding. Unable to explain the 'why' of water ballast to increase
performance in gliders to argumentative airplane student.
I need a simple explanation in 25 words or less.
Gene Whitt
Old October 11th 05, 04:22 AM
Tony Verhulst
Gene Whitt wrote:
Y'all,
Gene Whitt
For the long answer, see
http://home.comcast.net/%7Everhulst/...t/ballast.html
The real short answer is - see the polar at the end of the above
article. One curve is with ballast, the other without.
The slightly longer answer is that a glider's best glide, for instance,
occurs at one speed. Increase the weight and that same best glide (more
or less) now occurs at a higher speed. You can go faster and maintain a
better L/D than you would without ballast.
Tony V.
Old October 11th 05, 04:26 AM
Pete Brown
Gene:
1: A glider's best glide ratio is unaffected by its weight.
2: However, a heavier glider flies and sinks faster at
the same glide angle than a lighter one.
3: When lift conditions are strong, the pilot accepts the
higher sink rates to achieve higher speeds over the ground.
Pete
Gene Whitt wrote:
Y'all,
Gene Whitt
Peter D. Brown
http://home.gci.net/~pdb/
http://groups.yahoo.com/group/akmtnsoaring/
Old October 11th 05, 07:01 AM
Nyal Williams
The best illustration used to be: Remember when you
rode your coaster wagon downhill alone and also with
a buddy in it? It always went faster with two people.
Who knows anything about coaster wagons anymore?
At 03:30 11 October 2005, Pete Brown wrote:
Gene:
weight.
at
ground.
Pete
Gene Whitt wrote:
Y'all,
years since
to increase
Gene Whitt
Peter D. Brown
Old October 15th 05, 02:21 AM
Ralph Jones
On 11 Oct 2005 06:01:11 GMT, Nyal Williams
Think of a 400-pound skier.
rj
Old October 15th 05, 03:56 AM
Eric Greenwell
And I suppose it would go faster uphill, with two people pulling it
back: not a very good analogy, I think, since the heavy glider will
climb more slowly. "Going faster" isn't the issue, but instead, why
heavy is better than light. After all, both the heavy and the light
glider can fly the same speeds right up to Vne. It's because the heavy
glider can cruise faster for any given L/D, and (in strong conditions)
loses relatively little in the climb.
The aerodynamic reason it can cruise faster at any given L/D is that the
angle of attack determines the L/D, and the heavy glider needs extra
airspeed to generate the extra lift for that weight.
Eric Greenwell
Washington State
USA
Old October 19th 05, 07:24 PM
For Example John Smith
The beauty of the soapbox derby example--like Nigel's--is that it points out
that the glide slope is the same. With the added weight you have the same
glide slope but a higher speed.
The other way to make the soapbox derby car go faster was to reduce drag....
And I suppose it would go faster uphill, with two people pulling it back:
not a very good analogy, I think, since the heavy glider will climb more
slowly. "Going faster" isn't the issue, but instead, why heavy is better
than light. After all, both the heavy and the light glider can fly the
same speeds right up to Vne. It's because the heavy glider can cruise
faster for any given L/D, and (in strong conditions) loses relatively
Eric Greenwell
Washington State
USA
Old October 11th 05, 11:52 AM
Andy
Gene Whitt wrote:
Y'all,
Gene Whitt
A ballasted sailplane has more energy at a given altitude and airspeed
than an unballasted sailplane. (potential + kinetic). At cruise
speeds the energy is dissipated predominantly to overcome parasite drag
which is independent of weight. Start with more energy, expend the
same to overcome drag, so give up less altitude. Edit to 25 words.
Andy
Old October 11th 05, 05:38 PM
Pat Russell
On 11 Oct 2005 03:52:06 -0700, "Andy" wrote:
Edit to 25 words.
"A glider is a gravity-powered machine. The heavier it is, the more
power it has."
16 words, beat that!
-Pat
Old October 11th 05, 07:10 PM
Andy
But I need the same amount of power to go the same speed don't I? Why
does more power reduce my sink rate?
I think you'll need more than 16 words.
Andy
Airbus A380 water purification john smith Piloting 1 July 7th 05 02:50 AM
Induction System Water Problem Mike Spera Owning 1 January 30th 05 05:29 AM
Water, water, everywhere, but none for thirsty wings.... Chris OCallaghan Soaring 0 November 21st 04 03:14 PM
Questions regarding Air/Oil Separators Doodybutch Owning 6 April 20th 04 05:56 PM
Water Cooled Jet Engines: a possibillity then and now? The Enlightenment Military Aviation 3 December 18th 03 09:41 AM
