Gun, machine gun and/or cannon?
Old August 22nd 04, 03:49 PM
Ctenos
Default Gun, machine gun and/or cannon?
Is there a consistent basis for this designation in aircraft armament?
Old August 22nd 04, 04:29 PM
Kevin Brooks
"Ctenos" (reply w/o spam) wrote in message
All cannons *are* guns, so it is OK to refer to them as such; but all guns
are not cannons. I'd imagine (educated guess only) the division between the
two comes at the point where typical loads can include "payload carrying"
rounds, which is at the 20mm point (not aware of any *typical* loading of HE
into rounds under that size, which is why the 14.5mm is still refered to as
a machine gun and not a cannon).
Brooks
Old August 22nd 04, 06:06 PM
Gernot Hassenpflug
"Kevin" == Kevin Brooks writes:
Kevin "Ctenos" (reply w/o spam) wrote in
Kevin message
Kevin ...
armament?
Kevin All cannons *are* guns, so it is OK to refer to them as
Kevin such; but all guns are not cannons. I'd imagine (educated
Kevin guess only) the division between the two comes at the point
Kevin where typical loads can include "payload carrying" rounds,
Kevin which is at the 20mm point (not aware of any *typical*
Kevin loading of HE into rounds under that size, which is why the
Kevin 14.5mm is still refered to as a machine gun and not a
Kevin cannon).
With 'payload' do you mean anything other than 'ball', i.e., HE or
what else? For instance, tracer was available also in 7.7mm rounds I
believe. I think different countries had different names and
conventions for this. Certainly, the Japanese called all calibres up
to 40mm 'machine guns', after the automatic loading.
G Hassenpflug * IJN & JMSDF equipment/history fan
Old August 22nd 04, 06:26 PM
Kevin Brooks
"Gernot Hassenpflug" wrote in message
Kevin message
Kevin
armament?
Kevin cannon).
Tracer is not really a payload, and it has been available even down to the
5.56mm size; I meant a real payload (and it does not have to be HE; we have
various other cannon projectile payloads in the larger bore weapons, to
include even the esoteric artillery delivered jamming system). You gotta
wonder when some bright fellow is going to come up with a cannon fired short
duration/expendable UAV which could provide a rapid response visual/IR recon
capability...
Brooks
Old August 23rd 04, 10:53 AM
The Raven
"Kevin Brooks" wrote in message
Kevin message
Kevin
armament?
Kevin cannon).
have
short
recon
capability...
On that last point, MetalStorm are already investigating a camera equipped
round.... Probably a good idea not to be wearing a VR headset on
launch.......
The Raven
http://www.80scartoons.co.uk/batfinkquote.mp3
** President of the ozemail.* and uunet.* NG's
** since August 15th 2000.
Old August 22nd 04, 08:51 PM
Paul J. Adam
In message ,
Ctenos writes
Not really. "Machine guns" traditionally went up to 12.7mm or 13.2mm,
"cannon" were 20mm and up, and there was sort of a grey area in between:
notably the Soviet 14.5mm and German 15mm weapons.
The Soviets started with an anti-tank rifle and used its ammunition for
a Really Heavy Machine Gun; the Germans made a 15mm weapon, then decided
that it would be better necked out to 20mm and firing bigger rounds with
more payload. (Though they called both MG151/15 and MG151/20 'machine
guns', as well as the 20mm MG/FF, further muddying the waters)
In terms of aircraft armament, it's gone away because 20mm is low-end
for fast-jet armament. Meanwhile, the old rule of thumb that you
couldn't get a useful explosive round in less than 20mm has been
overturned by Raufoss and their 12.7mm multipurpose round.
Basically, pick a position you like and stick to it
He thinks too much: such men are dangerous.
Julius Caesar I:2
Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk
Old August 23rd 04, 06:49 AM
The Enlightenment
"Paul J. Adam" wrote in message
In message ,
Ctenos writes
more payload.
I believe the MG151/15 and MG151/20 were designed at the same time with the
same cartridge. The 15mm MG151/15 has a proportionatly longer barrel than
the MG151/20 to exploit the hot gases appropriatly and achieved a much
higher muzzle velocity. It had ballistics better than the US 50 caliber
with an explosive shell to boot. Pilots who used it in the early Me 109F
liked it because of its great accuracy and range. It lacked enough of an
explosive filling to damage the heavy bombers the Germans were encountering
so they had to resort to larger caliber weapons with lower muzzle
velocities. It was simply to hard to get enough hits to get a heavy down.
They needed about 20 hits of 20mm as it is.
The designation MG means "MachineGewher" or machine gun. It seems that
this ended at about 20mm
The designation MK means "MachineKanone" or machine canon. It seems this
started at about 30mm eg Mk 103 and Mk 108 which were the high and low
velocity 30 mm guns used by the Luwftwaffe. They regarded the Mk 108 as
firing 'mines'. They even had a hydrostatic fuse to detonate within the
fuel tank.
Only 3 hits were required to brring down a 4 engined heavy bomber and even a
P47 couldn't survive more than a hit or two. (which made the Me 109 so
deady if it got to within 200m) http://www.luft46.com/armament/mk108.html
At some point, around 50mm the designation changed the BK (Bord Kanon)
sometimes appeared. Believe it or not the Germans were planing to arm
their fighters with the 55mm Mk 112. It was a scaled up Mk 108. It was
actualy quite a feasigle weapon calculated to require only 1 hit. It was
low velocity but the shear size of the shell gave it reasonable ballistics.
There was also PAK (Panzer Abwher Kanone) literaly (tank anti canon) and
FLAK (Flugzeug Abwher Kanone) literaly (Flyingthing anti gun). FLAK has
ofcourse entered the english language.
The MG/FF was a liscence or import of the Swiss Oerlikon 20mm used by both
allies and germans. It was recoil opperated and had a nice heavy shell but
its cadence and velocity was relative low. British AAA used a modified
version with higher velocity and even lower cadence (450rpm). It was
however simple, compact and reliable and it fitted into the Me 109s wing.
The Much Bigger compressed air opperated Mauser (known as the jack hammer
becuase of its sound to the allies) had to be slung under the 109s wings
becuase of the slats.
What makes this round supposedly effective? New more powerfull explosives?
Minaturised fuses?
During the Korean war Sabre pilots often observed their 50 caliber rounds
bouncing of Migs. The combination of extended ranges and thicker metal
skins meant that the standard 50 caliber round lacked the punch needed.
Julius Caesar I:2
Old August 23rd 04, 07:13 AM
Gernot Hassenpflug
"The" == The Enlightenment writes:
The fuse to detonate within the fuel tank. Only 3 hits were
The required to brring down a 4 engined heavy bomber and even a
The P47 couldn't survive more than a hit or two. (which made the
The Me 109 so deady if it got to within 200m)
As loing as it was _behind_ the P-47 at the time g
The At some point, around 50mm the designation changed the BK
The (Bord Kanon) sometimes appeared. Believe it or not the
The Germans were planing to arm their fighters with the 55mm Mk
The 112. It was a scaled up Mk 108. It was actualy quite a
The feasigle weapon calculated to require only 1 hit. It was low
The velocity but the shear size of the shell gave it reasonable
The ballistics.
I suppose much like the vaunted 18" guns on Furious. Only one gun,
only need one hit. But one shot also takes out the carrier
aircraft, rattle rattle splat. Sorry, I couldn't resist, hard day
at work...
(PS The Japanese pilots carried swords for really close-range work
- *kathwap* there goes the enemy's aerial wire, *thwakaaa* there
goes the venturi, *bong bong bong* sound of hilt on the canopy).
Old August 23rd 04, 08:14 AM
Dave Eadsforth
In article , The
Big SNIP
fuel tank.
How on earth did that work, given the inevitable cavitation in the body
of the fuel as the projectile passed through?
N'other SNIP
Cheers,
Dave
Dave Eadsforth
Old August 23rd 04, 12:08 PM
Greg Hennessy
On Mon, 23 Aug 2004 08:14:56 +0100, Dave Eadsforth
Our nazi loving chum is emitting yet more uninformed bull****.
greg
Es ist mein Teil - nein
Mein Teil - nein
Denn das ist mein Teil - nein
Mein Teil - nein
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 05:07 PM
Democracy Expires Grantland Military Aviation 14 March 8th 04 04:54 AM
Titor's Time Machine... USAF Missile Box??? Jason Strong Military Aviation 8 November 28th 03 12:51 AM
marlin aerial machine gun spad? old hoodoo Military Aviation 0 August 10th 03 09:06 PM
Machine Tool Co. Bankruptcy Sends Ripple Through JSF Program huuto Military Aviation 3 July 29th 03 05:59 AM
