Flying this weekend in a new area it was difficult to keep track of
where each other was, thought about using the team location feature in SYM. I've copied the details on how it works below. Has anyone tried this feature and how did it work? Brian 6.17 Team The Team feature in SeeYou Mobile will help you find or hide your teammate. It lets you share your position with other pilots and even encrypt this information so that your competitors won't be able to decode it. To use it: .. Enable the "Team Position Code (Team)" Navbox in Menu Next Navboxes . Or use Menu Next Team from the main menu. .. Go to the map view and tap on the Team navbox. .. Team dialog opens. You need to press Setup before first use. .. Press Select to select a source waypoint for the calculation. It is imperative that your teammate does the same. .. If you would like to hide the information from others, enter the Encryption key. Again, both or all pilots have to share the same key. Go fly. When asked about your position, answer "One-Kilo-Bravo- Yankee". Your teammate will tap the Team navbox, enter the code and say "Thanks" while others won't have a clue unless they have the key ![]() |
For those in the USA who believe that FLARM is a pile of rubbish and
having expensive, not yet available and and power-hungry technology is the way to go: Forget about this useful tool. Jim |
Yep! It's for sure fault the fault of the stubborn Yanks. Nothing
whatsoever to do with Air Regulations or the fact that Flarm prohibited their unit from being sold in the USA. Just a simple case of a bunch of hard heads... -John On Sep 3, 12:59 pm, JS wrote: For those in the USA who believe that FLARM is a pile of rubbish and having expensive, not yet available and and power-hungry technology is the way to go: Forget about this useful tool. Jim |
JS wrote:
For those in the USA who believe that FLARM is a pile of rubbish and having expensive, not yet available and and power-hungry technology is the way to go: Forget about this useful tool. Jim The SeeYou Team code does something FLARM can not do: show you were your friends are, using your map display, as far as your radio can reach. Flarm is limited to 2 - 3km. For another way to show your friends on a map, look at the Garmin Rino series of two way radio with GPS ($250-$500): push a button, and your position is indicated on their GPS. It also works over a far greater distance than FLARM, and allows private communication off the busy 123.3 and .5 frequencies. Distance to 10 miles or more. And finally, take a look at the Garmin Astro Dog tracker. I don't know if anyone has used these in a glider, but it looks like it might work, and it does it's job automatically - no pilot workload. $600 for the display and one collar, works with up to 10 collars. Buy a unit and give the collar to your friend, so you know where he is; he does the same for you. It also works over 7+ mile range on the ground on a dog, certainly farther in the air, again a greater distance than FLARM. No, the collar doesn't have a shock device built into it, but that might be a useful feature for clubs that have problems getting members to bring the glider back when their time is up! -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * Sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
On Sep 3, 4:44*pm, Eric Greenwell wrote:
JS wrote: For those in the USA who believe that FLARM is a pile of rubbish and having expensive, not yet available and and power-hungry technology is the way to go: Forget about this useful tool. Jim The SeeYou Team code does something FLARM can not do: show you were your friends are, using your map display, as far as your radio can reach. Flarm is limited to 2 - 3km. For another way to show your friends on a map, look at the Garmin Rino series of two way radio with GPS ($250-$500): push a button, and your position is indicated on their GPS. It also works over a far greater distance than FLARM, and allows private communication off the busy 123.3 and .5 frequencies. Distance to 10 miles or more. And finally, take a look at the Garmin Astro Dog tracker. I don't know if anyone has used these in a glider, but it looks like it might work, and it does it's job automatically - no pilot workload. $600 for the display and one collar, works with up to 10 collars. Buy a unit and give the collar to your friend, so you know where he is; he does the same for you. It also works over 7+ mile range on the ground on a dog, certainly farther in the air, again a greater distance than FLARM. No, the collar doesn't have a shock device built into it, but that might be a useful feature for clubs that have problems getting members to bring the glider back when their time is up! -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes"http://tinyurl.com/y739x4 * * * Sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" atwww.motorglider.org Eric ! Are you insinuating that your plane is - a dog ?? |
On Sep 3, 3:44*pm, Dave Nadler wrote:
On Sep 3, 4:44*pm, Eric Greenwell wrote: JS wrote: For those in the USA who believe that FLARM is a pile of rubbish and having expensive, not yet available and and power-hungry technology is the way to go: Forget about this useful tool. Jim The SeeYou Team code does something FLARM can not do: show you were your friends are, using your map display, as far as your radio can reach. Flarm is limited to 2 - 3km. For another way to show your friends on a map, look at the Garmin Rino series of two way radio with GPS ($250-$500): push a button, and your position is indicated on their GPS. It also works over a far greater distance than FLARM, and allows private communication off the busy 123.3 and .5 frequencies. Distance to 10 miles or more. And finally, take a look at the Garmin Astro Dog tracker. I don't know if anyone has used these in a glider, but it looks like it might work, and it does it's job automatically - no pilot workload. $600 for the display and one collar, works with up to 10 collars. Buy a unit and give the collar to your friend, so you know where he is; he does the same for you. It also works over 7+ mile range on the ground on a dog, certainly farther in the air, again a greater distance than FLARM. No, the collar doesn't have a shock device built into it, but that might be a useful feature for clubs that have problems getting members to bring the glider back when their time is up! -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes"http://tinyurl.com/y739x4 * * * Sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" atwww.motorglider.org Eric ! Are you insinuating that your plane is - a dog ?? No just you have to add the zap the pilot gadget to an ASH-26E. It is not like those 'lectric motorgliders that come pre-wired to do that :-) Ah alright I'm just jealous. Darryl |
Dave Nadler wrote:
And finally, take a look at the Garmin Astro Dog tracker. I don't know if anyone has used these in a glider, but it looks like it might work, and it does it's job automatically - no pilot workload. $600 for the display and one collar, works with up to 10 collars. Buy a unit and give the collar to your friend, so you know where he is; he does the same for you. It also works over 7+ mile range on the ground on a dog, certainly farther in the air, again a greater distance than FLARM. No, the collar doesn't have a shock device built into it, but that might be a useful feature for clubs that have problems getting members to bring the glider back when their time is up! Eric ! Are you insinuating that your plane is - a dog ?? No, no: *I* have the display! My friends' gliders have the collars so I know where they are. Incidentally, the collar can tell "whether he’s [the dog] running, sitting, on point or treeing quarry. Astro can also sound an alarm to let you know instantly when your dog goes on point." I'm certain that a collar, properly mounted on the glider, will indicate "on point" when the pilot is thermalling. Now, Dave, imagine how useful one of these would be if it were mounted on a friend's glider, a friend flying in the same competition you are, especially if you didn't mention it to him, right? But the dog tracking idea has some merit: if they can do it for dogs, perhaps the same technology would be allowed for airborne use. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * Sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
On Sep 3, 1:44*pm, Eric Greenwell wrote:
JS wrote: For those in the USA who believe that FLARM is a pile of rubbish and having expensive, not yet available and and power-hungry technology is the way to go: Forget about this useful tool. Jim The SeeYou Team code does something FLARM can not do: show you were your friends are, using your map display, as far as your radio can reach. Flarm is limited to 2 - 3km. For another way to show your friends on a map, look at the Garmin Rino series of two way radio with GPS ($250-$500): push a button, and your position is indicated on their GPS. It also works over a far greater distance than FLARM, and allows private communication off the busy 123.3 and .5 frequencies. Distance to 10 miles or more. And finally, take a look at the Garmin Astro Dog tracker. I don't know if anyone has used these in a glider, but it looks like it might work, and it does it's job automatically - no pilot workload. $600 for the display and one collar, works with up to 10 collars. Buy a unit and give the collar to your friend, so you know where he is; he does the same for you. It also works over 7+ mile range on the ground on a dog, certainly farther in the air, again a greater distance than FLARM. No, the collar doesn't have a shock device built into it, but that might be a useful feature for clubs that have problems getting members to bring the glider back when their time is up! -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes"http://tinyurl.com/y739x4 * * * Sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" atwww.motorglider.org I wouldn't mind the option of installing shock collars on my competition and then giving then a friendly little jolt now and again...............as the owner of a Dog Boarding business we are quite adept at using these ingenious devices! now, back on topic.................would SYM and XC Soar share compatible Team Code functionality? If not.............since XC Soar is free and quite powerful, maybe a migration to XS-Soar for safety reasons might happen..............or better yet, perhaps the developers of the 2 programs could allow the 2 to talk to each other, and to the other flight software programs for that matter. Brad |
For team flying, a number of US pilots have used Garmin RINO. Back
when they allowed position data to only be transmitted on the lower power FRS band, air-to-air range was about 10 Nm. Then a few years back, the FCC allowed use on the GMRS channels and airborne range increased to 20 - 23 miles *if* the RINO is mounted so it's antenna is above the canopy rail. Yeah, it's one more gadget to add, but it's easy to use displays the other glider/s bearing, distance, and altitude. It also allows a spot (thermal) to be marked and that info transmitted to team members. Polling may be individually enabled too, and that allows you to request and receive position info from other "team" gliders without their having to push their send button. bumper MKIV and QV zz |
On Sep 5, 6:52*am, bumper wrote:
For team flying, a number of US pilots have used Garmin RINO. Back when they allowed position data to only be transmitted on the lower power FRS band, air-to-air range was about 10 Nm. Then a few years back, the FCC allowed use on the GMRS channels and airborne range increased to 20 - 23 miles *if* the RINO is mounted so it's antenna is above the canopy rail. Yeah, it's one more gadget to add, but it's easy to use displays the other glider/s bearing, distance, and altitude. It also allows a spot (thermal) to be marked and that info transmitted to team members. Polling may be individually enabled too, and that allows you to request and receive position info from other "team" gliders without their having to push their send button. bumper MKIV and QV zz Not only does the Team Code work very well in SYM it also generates the same format as XCsoar, so this weekend another pilot and I were able to locate each other by using the feature in those two programs. FLARM is not required. As has been pointed out, this is not a tracking device, the other pilot tells you the location code over the radio and you type it in which results in a waypoint being added to your screen with distance and bearing if that is how you have your softwar st up- in SYM it becomes the Target and shares those atributes. Brian |
| code | adelsonsl | Aviation Photos | 1 | March 22nd 08 08:33 PM |
| SeeYou Mobile 3 FLARM Feature and Team Flying? | [email protected] | Soaring | 10 | February 5th 08 09:28 AM |
| Seeyou NMEA to Winpilot/Seeyou | Jean | Soaring | 4 | June 3rd 06 12:38 PM |
| morse code | Sandra Oevering | Naval Aviation | 8 | December 31st 03 12:45 AM |
| F-16 Source Code | Charles Talleyrand | Military Aviation | 40 | December 26th 03 02:40 PM |
