Can anyone provide some guidance on the necessary steps for importing
a glider trailer from the UK to the USA? There is plenty of information on RAS on the steps to take for importing the glider inside the trailer, but this always assume that the trailer is something similar to a Cobra that is already approved for use within the United States. What about a trailer that was built as a one off in the UK? As far as I can tell this is considered a non-conforming vehicle by the DOT and the only solution is to use a registered importer and provide a steep bond to cover any potential modifications. BUT perhaps someone else who's done this can suggest an easier (and less expensive way)? Chris |
At 23:02 01 September 2009, Chris wrote:
Can anyone provide some guidance on the necessary steps for importing a glider trailer from the UK to the USA? There is plenty of information on RAS on the steps to take for importing the glider inside the trailer, but this always assume that the trailer is something similar to a Cobra that is already approved for use within the United States. What about a trailer that was built as a one off in the UK? As far as I can tell this is considered a non-conforming vehicle by the DOT and the only solution is to use a registered importer and provide a steep bond to cover any potential modifications. BUT perhaps someone else who's done this can suggest an easier (and less expensive way)? Chris I have a cobra already in this country! Contact me. 5U |
On Sep 1, 7:02*pm, Chris wrote:
Can anyone provide some guidance on the necessary steps for importing a glider trailer from the UK to the USA? There is plenty of information on RAS on the steps to take for importing the glider inside the trailer, but this always assume that the trailer is something similar to a Cobra that is already approved for use within the United States. What about a trailer that was built as a one off in the UK? As far as I can tell this is considered a non-conforming vehicle by the DOT and the only solution is to use a registered importer and provide a steep bond to cover any potential modifications. BUT perhaps someone else who's done this can suggest an easier (and less expensive way)? Chris The major requirements customs will be looking for relate to DOT compliance. This will require DOT markings on lights, wheels, and tires. One of our club members just did this. He went to the UK on a pre buy inspection and got the trailer into compliance before shipping. DO NOT assume you can just slide it in. If you do, and it does not comply, it will be impounded and the only alternatives are export or bringing into compliance by a registered importer. Expect them to charge $1000 or more for their services. Good luck UH |
On Sep 2, 8:34*am, wrote:
On Sep 1, 7:02*pm, Chris wrote: Can anyone provide some guidance on the necessary steps for importing a glider trailer from the UK to the USA? There is plenty of information on RAS on the steps to take for importing the glider inside the trailer, but this always assume that the trailer is something similar to a Cobra that is already approved for use within the United States. What about a trailer that was built as a one off in the UK? As far as I can tell this is considered a non-conforming vehicle by the DOT and the only solution is to use a registered importer and provide a steep bond to cover any potential modifications. BUT perhaps someone else who's done this can suggest an easier (and less expensive way)? Chris The major requirements customs will be looking for relate to DOT compliance. This will require DOT markings on lights, wheels, and tires. One of our club members just did this. He went to the UK on a pre buy inspection and got the trailer into compliance before shipping. DO NOT assume you can just slide it in. If you do, and it does not comply, it will be impounded and the only alternatives are export or bringing into compliance by a registered importer. Expect them to charge $1000 or more for their services. Good luck UH Having DOT marking is not all. I imported the trailer a year ago. It had the right markings on everything and it also had a plate stating it meets all federal DOT standards. The trailer was sold new in US, yes, and then exported. When I re-imported it back the plate would not help neither would DOT markings. The customs officer wanted a manufacturer statement. Luckily I was able to obtain it and clear customs after weeks in port. Is this logical? No. Why did this happen, well because some of these customs officers don’t have a clue what is needed. The plate should have been enough that was what my broker told me. If you don’t have a plate or a manufacturer statement the only option is to hire a company to certify and or bring the trailer to compliance. That is at least three zeros after a number probably greater than 1 as I was told looking at my options. If you import as a container you can then make it a trailer and yes you will be able to register. Parts will be what you imported plus some that you buy here. There is no law that forbids you from building a trailer out of a container. |
So there seems to be two options:
(1) Ask the British manufacturer to provide a statement of compliance. If this is simply a letter they provide, then I can probably get that. If it requires them to do a bunch of paper work, file this all with the DOT, an so on, then it's likely the shop that made the trailer for me will want to take a pass. Does anyone know off hand what's involved for he manufacturer to provide a statement of compliance? If not, I imagine I'll get to spend some quality time on the phone with the DOT (which is looking likely anyway). (2) The container option sounds interesting. Would this be as simple as declaring that it is a container, that it will not be used for road transport, simply storage, and then haul it away from the port on a flatbed? If so, then that sounds like it could be the way to go. Thanks in advance for all of the assistance. Chris |
On Sep 2, 11:46*pm, Chris wrote:
So there seems to be two options: (1) Ask the British manufacturer to provide a statement of compliance. If this is simply a letter they provide, then I can probably get that. If it requires them to do a bunch of paper work, file this all with the DOT, an so on, then it's likely the shop that made the trailer for me will want to take a pass. Does anyone know off hand what's involved for he manufacturer to provide a statement of compliance? If not, I imagine I'll get to spend some quality time on the phone with the DOT (which is looking likely anyway). (2) The container option sounds interesting. Would this be as simple as declaring that it is a container, that it will not be used for road transport, simply storage, and then haul it away from the port on a flatbed? If so, then that sounds like it could be the way to go. Thanks in advance for all of the assistance. Chris Chris, in regards to number one. I can provide you with a copy of the statement Avionic issued for my trailer. You just have to remember my trailer also had a plate. It might be that the statement is all that is required. Contact me off group I will give you a copy of my letter. Wording is the key. In regards to number two I suggest calling customs and asking about bringing a glider storage container, tell them it has wheels to move the container around the airport, but the container is not going to be used on public roads. Call customs in the port of entry where you are going to bring the glider. AK |
| Custom Built Model Airplanes | [email protected] | Products | 0 | May 30th 08 02:45 PM |
| Importing AVIONIC glider trailer - what a pain | [email protected] | Soaring | 12 | September 7th 07 02:49 AM |
| Custom Built Model of your Aircraft | customairmodels | Aviation Marketplace | 2 | November 10th 05 10:56 AM |
| Custom built Model of any Military Aircraft | customairmodels | Military Aviation | 0 | November 8th 05 10:20 AM |
| Custom glider trailer builders in the US | Ken Harry | Soaring | 6 | January 9th 05 05:12 AM |
