After all the threads on venting high pressure air overboard I thought
I would share this one with you. I sealed up the ASW17 canopy and its nice and quiet now. On Tow yesterday as I retracted the gear the pressure change was enough to blow the hatch off the top of the turtle deck. I couldn't figure out what the noise was at first thinking it was a gear door who's bungy had broken or come unhooked. I cycled the gear 2 - 3 times more so thinking it might be an animal or rock or stuck in the gear well. The noise continued until I performed a sharp pull up from 80 knots. The rest of the flight was uneventful except there was more air noise I attributed to a stuck gear door. The glider had a slight resonance vibration again I attributed it to the gear door. Upon landing I was amazed to see the rigging hatch wedged in the aperture retained by its lanyard and the remaining tape. It was aligned 45deg. to the airflow which explained the vibration I was feeling. So now the fun part.... The ASW17 has a hatch that is exactly dead center of the fuz. so I am now working on a replacement air exhaust hatch that will replace the stock "non breathing" hatch. I am looking at a design like the ramp style that Dick butler has on his ASW22. More to follow..... Al |
On Sep 4, 7:53*pm, "
wrote: After all the threads on venting high pressure air overboard I thought I would share this one with you. I sealed up the ASW17 canopy and its nice and quiet now. On Tow yesterday as I retracted the gear the pressure change was enough to blow the hatch off the top of the turtle deck. *I couldn't figure out what the noise was at first thinking it was a gear door who's bungy had broken or come unhooked. I cycled the gear 2 - 3 times more so thinking it might be an animal or rock or stuck in the gear well. The noise continued until I performed a sharp pull up from 80 knots. The rest of the flight was uneventful except there was more air noise I attributed to a stuck gear door. The glider had a slight resonance vibration again I attributed it to the gear door. Upon landing I was amazed to see the rigging hatch wedged in the aperture retained by its lanyard and the remaining tape. It was aligned 45deg. to the airflow which explained the vibration I was feeling. So now the fun part.... The ASW17 has a hatch that is exactly dead center of the fuz. so I am now working on a replacement air exhaust hatch that will replace the stock "non breathing" hatch. *I am looking at a design like the ramp style that Dick butler has on his ASW22. More to follow..... Al Al, I think a reverse NACA duct is a better model to use. It will smooth the transition more and accelerate the air to about equal to the speed of the outside air for less drag. I would build one similar to the one in the link but with a cover over about the first half with a smooth transition toward the back. http://www.appletreeauto.com/naca-du...4-pr-3425.html Tim |
On Sep 5, 10:03*am, Tim Taylor wrote:
On Sep 4, 7:53*pm, " wrote: After all the threads on venting high pressure air overboard I thought I would share this one with you. I sealed up the ASW17 canopy and its nice and quiet now. On Tow yesterday as I retracted the gear the pressure change was enough to blow the hatch off the top of the turtle deck. *I couldn't figure out what the noise was at first thinking it was a gear door who's bungy had broken or come unhooked. I cycled the gear 2 - 3 times more so thinking it might be an animal or rock or stuck in the gear well. The noise continued until I performed a sharp pull up from 80 knots. The rest of the flight was uneventful except there was more air noise I attributed to a stuck gear door. The glider had a slight resonance vibration again I attributed it to the gear door. Upon landing I was amazed to see the rigging hatch wedged in the aperture retained by its lanyard and the remaining tape. It was aligned 45deg. to the airflow which explained the vibration I was feeling. So now the fun part.... The ASW17 has a hatch that is exactly dead center of the fuz. so I am now working on a replacement air exhaust hatch that will replace the stock "non breathing" hatch. *I am looking at a design like the ramp style that Dick butler has on his ASW22. More to follow..... Al Al, I think a reverse NACA duct is a better model to use. *It will smooth the transition more and accelerate the air to about equal to the speed of the outside air for less drag. *I would build one similar to the one in the link but with a cover over about the first half with a smooth transition toward the back. http://www.appletreeauto.com/naca-du...4-pr-3425.html Tim But NACA ducts are usually used for inbound air not outbound... There was another type I saw on a buddies ASH26 but can remember the name of it began with an E. Cheers Al |
On Sep 5, 11:08*pm, Al wrote:
On Sep 5, 10:03*am, Tim Taylor wrote: On Sep 4, 7:53*pm, " wrote: After all the threads on venting high pressure air overboard I thought I would share this one with you. I sealed up the ASW17 canopy and its nice and quiet now. On Tow yesterday as I retracted the gear the pressure change was enough to blow the hatch off the top of the turtle deck. *I couldn't figure out what the noise was at first thinking it was a gear door who's bungy had broken or come unhooked. I cycled the gear 2 - 3 times more so thinking it might be an animal or rock or stuck in the gear well. The noise continued until I performed a sharp pull up from 80 knots. The rest of the flight was uneventful except there was more air noise I attributed to a stuck gear door. The glider had a slight resonance vibration again I attributed it to the gear door. Upon landing I was amazed to see the rigging hatch wedged in the aperture retained by its lanyard and the remaining tape. It was aligned 45deg. to the airflow which explained the vibration I was feeling. So now the fun part.... The ASW17 has a hatch that is exactly dead center of the fuz. so I am now working on a replacement air exhaust hatch that will replace the stock "non breathing" hatch. *I am looking at a design like the ramp style that Dick butler has on his ASW22. More to follow..... Al Al, I think a reverse NACA duct is a better model to use. *It will smooth the transition more and accelerate the air to about equal to the speed of the outside air for less drag. *I would build one similar to the one in the link but with a cover over about the first half with a smooth transition toward the back. http://www.appletreeauto.com/naca-du...4-pr-3425.html Tim But NACA ducts are usually used for inbound air not outbound... There was another type I saw on a buddies ASH26 but can remember the name of it began with an E. Cheers Al Actually there are NACA designs for inlets and outlets. They would be the best design to use for an outlet. Dick Butler's design is close, but could use some slight modifications to improve the speed of the exit airflow. In my opinion the Mandl Extractor is not the best design to use. It has too great of an angle where the air rejoins the outside airflow. |
Hi Tim and Al, Perhaps it was just a pressure pulse which blew the cover
off. If you attatch a rear-facing duct you are likely to produce a negative pressure difference, and an altimeter with an inboard static vent would read higher than you are. Perhaps the best initial solution would be to drill a 10-15mm hole in the access cover, (or anywhere else really.) which depending upon the airflow, would act as a static vent... neither increasing or decreasing the ambient pressure. I wonder if the pressure pulse was created by the closing of the u/c doors, or because you where using the screen ventilation system, which admits air onto the screen... Where is that supposed to go ? Pete At 06:14 06 September 2009, Tim Taylor wrote: On Sep 5, 11:08=A0pm, Al wrote: On Sep 5, 10:03=A0am, Tim Taylor wrote: After all the threads on venting high pressure air overboard I though= t I would share this one with you. I sealed up the ASW17 canopy and its nice and quiet now. On Tow yesterday as I retracted the gear the pressure change was enough to blow the hatch off the top of the turtle deck. |
On Sep 7, 6:45*am, Peter Higgs wrote:
Perhaps the best initial solution would be to drill a 10-15mm hole in the access cover, (or anywhere else really.) which depending upon the airflow, would act as a static vent... *neither increasing or decreasing the ambient pressure. On Sep 7, 6:45 am, Peter Higgs wrote: Perhaps the best initial solution would be to drill a 10-15mm hole in the access cover, (or anywhere else really.) which depending upon the airflow, would act as a static vent... neither increasing or decreasing the ambient pressure. I'm not sure I would want an "air spigot" pointing straight out of the fuselage into the airstream - seems like unnecessary drag versus a solution that lines the flow up with the external slipstream. The reverse NACA duct has been shown to work well and it's my understanding that it even produces a small amount of thrust. As to altimeter readings - my altimeter is hooked to my tailboom static ports. I'd recommend it as a general practice if you have external ports available. My feeling is that any solution that vents high-pressure fuselage air would yield a more accurate altimeter reading than not venting but that the differences in any even aren't that large. 9B |
| Carrier Hornet, pt 7 - Pilot House Hatch.JPG (1/1) | Mitchell Holman[_3_] | Aviation Photos | 0 | March 17th 09 12:54 PM |
| GT White Floats out the Open Hatch GPN-2000-001407.jpg | [email protected] | Aviation Photos | 0 | April 9th 07 10:02 PM |
| GT-3 Virgil Grissom shown through window of open hatch on Gemini craft S65-20605.jpg | [email protected] | Aviation Photos | 0 | April 9th 07 09:52 PM |
| I almost blew it today | Bill Watson | Piloting | 6 | January 25th 07 01:17 AM |
| Blew a Gasket | jls | Home Built | 6 | June 2nd 04 08:36 PM |
