In a white paper from the Lexington Institute, it is claimed (most
likely by Loren Thompson, the Lexingtin Institute defense analyst and resident Raptor cheerleader) that the F/A-22 has an Infrared Search and Track capability. Specifically, on page 8 of the attachment below, the following passage: "The sensor usually described in open sources is the main radar — an electronically steered array that can simultaneously provide surveillance, fire control, jamming and other functions. However, Raptor also carries other sensors such as an infrared surveillance and tracking system that are seldom discussed." I have never read this anywhere else. Does Dr. Thompson know something the rest of the non-classified world doesn't? Does anyone else have any info on this? Or is he just blowing smoke up our collective keisters? |
![]() "Mike Zaharis" wrote in message om... In a white paper from the Lexington Institute, it is claimed (most likely by Loren Thompson, the Lexingtin Institute defense analyst and resident Raptor cheerleader) that the F/A-22 has an Infrared Search and Track capability. Specifically, on page 8 of the attachment below, the following passage: "The sensor usually described in open sources is the main radar - an electronically steered array that can simultaneously provide surveillance, fire control, jamming and other functions. However, Raptor also carries other sensors such as an infrared surveillance and tracking system that are seldom discussed." I have never read this anywhere else. Does Dr. Thompson know something the rest of the non-classified world doesn't? Does anyone else have any info on this? Or is he just blowing smoke up our collective keisters? The F-22 was to have an IRST, but it was subsequently deleted from the program. There has been some amount of informed speculation that with the name change to "F/A-22", a targeting FLIR will instead be mounted internally. See: www.aviationnow.com/avnow/news/ channel_awst_story.jsp?id=news/sb03_16.xml Brooks |
On Sun, 29 Aug 2004 22:11:54 -0400, Kevin Brooks wrote:
The F-22 was to have an IRST, but it was subsequently deleted from the program. Do you happen to know why? -- "It's easier to find people online who openly support the KKK than people who openly support the RIAA" -- comment on Wikipedia (Email: zen19725 at zen dot co dot uk) |
![]() "phil hunt" wrote in message .. . On Sun, 29 Aug 2004 22:11:54 -0400, Kevin Brooks wrote: The F-22 was to have an IRST, but it was subsequently deleted from the program. Do you happen to know why? IIRC, it was mostly money and project timeline concerns; it was thought that as the aircraft's primary weapons and other sensors adequately (or more than adequately) support its BVR mission, and along with its stealthiness, that it was not a "have to have" item in the initial operational version. It may have also been influenced by sensor fusion concerns--it will already have what is probably the most complex and ambitious sensor fusion capability flying, and adding another sensor into the mix could have been more trouble than it is worth at this time. I believe the IRST will likely be included in future spirals, and a FLIR/target designation capability will undoubtedly be added in the first spiral. Brooks |
phil hunt wrote:
On Sun, 29 Aug 2004 22:11:54 -0400, Kevin Brooks wrote: The F-22 was to have an IRST, but it was subsequently deleted from the program. Do you happen to know why? Probably because every IR search-and-track mechanism ever made has failed to be worth its cost. (Very short range, complicated electronics, sometimes- dunious operation.) |
![]() "Dweezil Dwarftosser" wrote in message ... phil hunt wrote: On Sun, 29 Aug 2004 22:11:54 -0400, Kevin Brooks wrote: The F-22 was to have an IRST, but it was subsequently deleted from the program. Do you happen to know why? Probably because every IR search-and-track mechanism ever made has failed to be worth its cost. (Very short range, complicated electronics, sometimes- dunious operation.) The LMCO AIRST destined (at one time) for the F-22 is based upon the IRST used in the F-14, which from what I have read is not a very bad system. Cost was the major reason AIRST was dumped. Brooks |
(Mike Zaharis) wrote in message . com...
In a white paper from the Lexington Institute, it is claimed (most likely by Loren Thompson, the Lexingtin Institute defense analyst and resident Raptor cheerleader) that the F/A-22 has an Infrared Search and Track capability. Specifically, on page 8 of the attachment below, the following passage: "The sensor usually described in open sources is the main radar ? an electronically steered array that can simultaneously provide surveillance, fire control, jamming and other functions. However, Raptor also carries other sensors such as an infrared surveillance and tracking system that are seldom discussed." I have never read this anywhere else. Does Dr. Thompson know something the rest of the non-classified world doesn't? Does anyone else have any info on this? Or is he just blowing smoke up our collective keisters? BTW, here's the link I talked about: http://www.lexingtoninstitute.org/de...f/LEX_FA22.pdf Thanks for responses. |
Delivery of Raptor delayed | Henry J Cobb | Military Aviation | 48 | July 22nd 04 01:45 AM |
