removing transparency coating
Old September 18th 09, 11:51 PM posted to rec.aviation.soaring
Brad[_2_]
Default removing transparency coating
I am trying to remove the spray coating that was sprayed on my
transparency for shipping. Stuff has been on there for over 3 or more
years now and it might take me that long just trying to remove the
damn stuff.
Any advice from those who might have some experience with this
tenacious film?
Thanks,
Brad
Old September 19th 09, 01:15 AM posted to rec.aviation.soaring
Nyal Williams[_2_]
What is this "transparency" and what is it made of?
damn stuff.
tenacious film?
Thanks,
Brad
Old September 19th 09, 01:53 AM posted to rec.aviation.soaring
Bob Kuykendall
In the case at hand the transparency is made of 1/8" aircraft grade
acrylic plastic, commonly referred to as Plexiglas (tm) or generically
plexiglass. It's the clear plastic thingy you look out of when you sit
in a sailplane. I don't refer to it as a "canopy" because that word is
too often used to refer to the entire assembly consisting of the
acrylic transparency, the canopy frame and assorted mechanisms of
latching and hinging.
Thanks, Bob K.
Old September 19th 09, 04:45 AM posted to rec.aviation.soaring
Nyal Williams[_2_]
Hot water and plexiglass cleaner.
damn stuff.
tenacious film?
Thanks,
Brad
Old September 19th 09, 01:27 PM posted to rec.aviation.soaring
JJ Sinclair
Yeah, really hot water, boiling water won't hurt plexy and may loosen
the stuff some. Scraping with wood will leave a rub mark, but this can
be removed with canopy cleaner/scratch remover. I once removed the
stuff after 20 years...........Ugh!
JJ
Old September 19th 09, 01:33 PM posted to rec.aviation.soaring
jcarlyle
In that case, would one of those steamer thingies that they use to
remove wallpaper be useful?
-John
JJ
Old September 19th 09, 02:08 PM posted to rec.aviation.soaring
JJ Sinclair
-John
JJ- Hide quoted text -
- Show quoted text -
Worth a try, plexy doesn't yield until it reaches about 350F
Old September 19th 09, 03:30 PM posted to rec.aviation.soaring
bumper[_2_]
-John
Worth a try, plexy doesn't yield until it reaches about 350F- Hide quoted text -
This is from one manufacturer of acrylic plastic (Plexiglas is a brand
name). Note the softening and melting temps are lower than some have
suggested in this thread - - so don't heat it and then lean on it (g).
"Thermal
Maximum Recommended Continuous Service
Temperature
°F 170-190
Softening Temperature °F 210-220
Melting Temperature °F 300-315"
I would do as JJ suggests, use boiling water. But use caution about
getting "creative" while applying heat,
My experience is the longer some such protective coatings are aged,
even when not directly exposed to UV, the harder they are to remove -
- UV makes is worse still!. So it's probably better to get on it
sooner rather than later. If the coating is left on because the canopy
is part of a building project, one might consider removing the coating
and then using clear plastic sheet to drape the canopy.
On a smaller scale, some of the tapes used to attach yaw strings can
be hell to remove later after prolonged UV exposure - - - especially
clear tapes. Ease of removal, leaving no residue even after years of
exposure, is one of the benefits of my MKIV yaw string.
bumper
zz
Minden
Penalitel anit-corrosion coating Jon Woellhaf Owning 2 June 27th 07 06:11 PM
Coating aluminum Lou Home Built 23 December 24th 05 04:11 AM
How to identify fabric/coating process used? Wallace Berry Home Built 7 October 7th 05 07:14 PM
Doors Open On New Powder Coating Facility Anaheim California United States [email protected] Home Built 0 October 21st 04 02:33 PM
Suitable coating for spring-steel wire? Wright1902Glider Home Built 6 February 9th 04 04:12 PM
