Where is the next thermal?
Old September 21st 09, 09:52 PM posted to rec.aviation.soaring
danlj
Default Where is the next thermal?
I am writing this to ask experienced soaring pilots to correct me
where you have acquired different wisdom, or your local conditions are
different, or where you have something more to add.
I hope this turns into a thread on "How I keep going" - there must be
scores of pilots more excellent than I who can say more than me.
More than 20 years ago, before I had become able to pursue soaring (as
distinguished from gliding), a letter to the editor appeared in
Soaring Magazine. A SE-WI hang-gliding pilot who'd done a lot of self-
taught XC soaring, innocently thought that SSA members might have a
lot more wisdom that he, so he asked for clues on how to find
thermals. He never got a response that was printed in the magazine...
He did tell the one thing he knew about finding thermals: "The best
lift is at the most downwind corner of the field."
This, in my own experience, is the single most important clue on where
to go when scratching low, here over the prairies. Identifying what
is "the field", where the wind's coming from, and what's "a corner"
have sometimes been challenging, and figuring out just how small hills
and valleys will affect the thermals is always interesting (hills tend
to help, valleys tend to channel them - flying downwind up a valley
above ridgetop is usually a route to a save).
I've also noticed that any isolated sorta-bare hill or rock pile on
flat ground is a pretty reliable source...
On the negative side, being anywhere downwind of any lake wider than
about a mile, or wet river flood plain, is definitely associated with
a lack of organized thermals, sometimes for miles. Forests are bad,
but the clearings in them are good. Swamps in the prairie are often
bad (wet) but in the woods often create boomers due to the
differential, and moist air is buoyant.
I am not very good at identifying the best field when they all look
good (spring planting or fall harvest). On the first cold day after a
warm spell in the fall, some fields generate thermals on overcast
days: the best seem to be cut bean fields, covered with a thin layer
of stems and leaves.
Early in the day, thermal sources tend to be small (a single field or
parking lot) and late in the day, they tend to be very large (e.g., a
3-10 mile-diameter prairie).
And at the beginning of the day, all clouds have lift (of quite
variable strength), mid-day, as few as 20% do, and late in the day,
the appearance of the cloud is a reliable indicator of whether it's
"working."
When high, the corollary to the field is of course the flat cu: the
first place to look for the thermal is at the most upwind part of the
cloud. Although again, what's a "cloud", where the wind's coming from,
and the direction of the wind above cloudbase all affect what will be
found.
Clouds with flat bases are better that clouds with fuzzy bases, except
that a new wisp always has something, and an "old" flat cloud may be
dying.
Clouds with enthusiastic tops are sucking air, and under these, the
lift is usually under the tower (useful when aiming from a distance)
and there's often a dimple in the bottom where the suction is
greatest. I was once told that streamers usually indicate condensing
lift, but I've found this usually wrong -- except when the thermal is
unusually humid.
Clouds sometimes are lined up. My experience is that the streets are
fake (but not necessarily useless) if the surface wind is less than 10
kt, and usually real above that; but that all streets end.
The hardest time for me is when I'm sort of midway between cloud and
ground. Do I fly under the best part of the cloud and look up? Or do I
fly toward the thermal source? Or, how can I reliably identify a good
intermediate point?
In this regard, I've found that thermals are curved, sometimes
strongly (if imagined in "section"). This can be seen with swamp
fires, where the smoke skims along the ground for awhile, then begins
to rise in a great slow curve to the small cu created by the humidity
released from the ground by the fire's heat. This makes physical
sense, when one stops to think about it, for the wind first whisks the
thermal bubble along horizontally (at, say, 10 mph = 900 ft/min). The
warmed air must accelerate; this rate of acceleration depends on the
buoyancy of the thermal relative to the lapse rate. If it's a boomer,
say 900 ft/min, then the angle will go from nil to 45 degrees as it
accelerates, and this feels almost vertical. But down low, below about
1500 ft agl, the clouds are sometimes more a distraction than a help
because of this. The curvature of thermals, I think, is a special
mystery when trying to fly xwind on a blue day. I, at least, often
feel mystified.
More topics, about which I can't say much:
Staying alive late in the day (e.g., "there's zero-sink over
freeways")
Identifying mountain thermals
"Good terrain" in deserts
sea-breeze and dry-front lift
other...
Old September 21st 09, 10:13 PM posted to rec.aviation.soaring
Mike Bamberg
to go when scratching low, here over the prairies. *Identifying what
"working."
found.
dying.
unusually humid.
intermediate point?
because of this. *The curvature of thermals, I think, is a special
feel mystified.
freeways")
other...
Danlj
A very nice collection of ideas for finding thermals. Many of the
same Ideas that I have noticed and shared with students. They work
better in farmland and wooded areas than desert as the triggers are
less distinct in the dessert and more of the surface are is being
heated to the same temperature.
Regarding the "downwind corner", I also note that where the ground
surface changes; dry to wet, low to high, plowed to growing. At each
of these areas especially if you can identify that the downwind
surface is colder or denser, there will be the necessary upward push
to start a thermal. I describe them as "discontinuities" in the
surface. They form an edge, if you will, that can trigger the thermal.
Thanks for the list.
Mike
Old September 21st 09, 10:45 PM posted to rec.aviation.soaring
Nyal Williams[_2_]
A bare field just downwind of a patch of trees has time to heat up more
owing to the windbreak and it can kick off a thermal sometimes down
lower.
Also, wooded areas serve well late in the day. Surrounding open land will
cool off more quickly and then the woods will begin to give up its heat in
a soft thermal that won't go very high, but can serve to hang on for a
bit and as a place from which to jump to the next woods patch while trying
to get home.
Not an expert by r.a.s. standards.
be
self-
to go when scratching low, here over the prairies. =A0Identifying what
corner"
"working."
from,
found.
dying.
unusually humid.
intermediate point?
thermal bubble along horizontally (at, say, 10 mph =3D 900 ft/min).
The
because of this. =A0The curvature of thermals, I think, is a special
feel mystified.
freeways")
other...
Danlj
Mike
Old September 22nd 09, 02:07 AM posted to rec.aviation.soaring
BT
Downwind at the edge of the dry lake.
Dry hot air moving across the lake bed get triggered to release and rise
when encountering the scrub.
On an open desert floor, look for darker areas. The darker areas are most
likely elevated hard rock that is hotter than the surrounding sand and dirt.
I have also found thermals coming up from broad open "dry washes", the
exposed rock in the dry wash gets hotter than the surrounding soils.
BT
"Mike Bamberg" wrote in message
"working."
found.
dying.
unusually humid.
intermediate point?
feel mystified.
freeways")
other...
Danlj
Mike
Old September 21st 09, 11:28 PM posted to rec.aviation.soaring
Andy[_1_]
I well remember that years ago when a visiting German pilot asked for
advice on finding thermals in Arizona I told him to look above and
downwind of cattle tanks. These are known as stock ponds in other
places. His reaction, that I must be a complete idiot for suggesting
that pools of water could trigger thermals, has made me cautious about
offering that advice to anyone. I hoped he landed out but I don't
think he did.
Andy
Old September 21st 09, 11:51 PM posted to rec.aviation.soaring
[email protected][_2_]
I've noticed that there seems to be a time in the afternoon when the
lift gets "soft" and previously reliable clouds become much less
reliable. Then, after an hour or so, the lift seems to pick up again,
not usually as strong but good enough to get home.
My totally uneducated guess is that at some point, the reserve of lift
that is breaking loose and forming thermals gets exhausted and isn't
replenished fast enough, so it takes a while to build up again and
start making reliable thermals.
This is really noticable where I often fly in Illinois, where you have
to slow down and be real careful not to get too low mid afternoon,
even though the day still looks great with cu's all over the place -
around 2 to 3 in the afternoon it gets real soft and you have to slow
down and stay high and wait for the lift to cycle back on. Then you
can stay up till the sun goes down!
Kirk
66
Old September 22nd 09, 12:09 AM posted to rec.aviation.soaring
rlovinggood
Two items:
1. Junkyards
2. Radio transmission antennas.
I can understand the junkyards. It's a good "discontinuity" in the
surrounding area and has the wrecked cars packed tightly together,
more so than the typical parking lot.
As for the antennas, we speculate it's not the antenna itself, but the
ground they're on. They are probably most likely on the highest spot
around, even though it all looks quite flat to us. And, we're talking
about the 2,000' tall, cable stayed antennas and not the little cell
phone towers. But I guess any water tower and radio antennas are
placed on the highest ground in the local area.
Remember, Your Mileage May Vary...
Ray Lovinggood
Carrboro, North Carolina, USA
Old September 23rd 09, 09:35 PM posted to rec.aviation.soaring
mattm[_2_]
On Sep 21, 7:09*pm, rlovinggood wrote:
Two items:
1. *Junkyards
2. *Radio transmission antennas.
I can understand the junkyards. *It's a good "discontinuity" in the
ground they're on. *They are probably most likely on the highest spot
around, even though it all looks quite flat to us. *And, we're talking
phone towers. *But I guess any water tower and radio antennas are
Ray Lovinggood
Yes, mine varies. I've found those shorter cell phone towers to be
reliable lift points when I'm lower. They act as a wick to dislodge
the warm air from the ground, I think. Reichmann points out that
the warm air at the surface has a surface tension that needs to be
broken. He relates the point by describing a case of finding a
thermal down low that was wicking from a roadside monument.
At medium levels you can sometimes relate a lift source with
its resulting cloud. At a contest a year and a half ago I was
getting lowish (2000ft or so) and was flying over some shaded
ground looking for a thermal. Ahead, I saw a large field in the
sunlight that was being plowed. To my left and even with the
field was a new and growing cu (downwind). I drew a mental line
between the two and pulled up into the strongest thermal of the
day (an honest 8kt climb to cloudbase).
-- Matt
Old September 23rd 09, 09:51 PM posted to rec.aviation.soaring
Brad[_2_]
Two items:
1. *Junkyards
Ray Lovinggood
Yes, mine varies. *I've found those shorter cell phone towers to be
reliable lift points when I'm lower. *They act as a wick to dislodge
the warm air from the ground, I think. *Reichmann points out that
broken. *He relates the point by describing a case of finding a
its resulting cloud. *At a contest a year and a half ago I was
ground looking for a thermal. *Ahead, I saw a large field in the
sunlight that was being plowed. *To my left and even with the
field was a new and growing cu (downwind). *I drew a mental line
-- Matt
High tension power lines act as triggers, and the dirt roads/gap in
the trees where the towers are located are generators. IMO.
Brad
Old September 22nd 09, 10:00 AM posted to rec.aviation.soaring
Derek Copeland[_2_]
Can I agree with Andy. In the UK we often seem to get really strong
thermals close to a large lake or reservoir such as Grafham Water. The
thermals are coming off the surrounding land of course, but the
temperature contrast between the hotter ground and the cooler water seems
to act as a trigger mechanism or a mini front. I have often found that
discontinuities such as the edge of a forest, a ridge line (especially if
pointing into sun), or a ploughed field next to one with crop often seem
to give thermals. Provincial towns and active power stations are also good
ground sources.
However the most reliable thermal markers are circling birds of prey such
as buzzards or kites, or insect eaters such as swallows and swifts.
Derek Copeland
be
think he did.
Andy
Which Way is That Thermal? ContestID67 Soaring 26 September 9th 06 08:30 PM
Thermal Divider RST Engineering \(jw\) Home Built 18 May 30th 06 05:03 PM
Thermal Data Files Thermal Mapping Project Australia Mal Soaring 0 December 2nd 05 11:14 PM
thermal lift ekantian Soaring 0 October 5th 04 02:55 PM
Thermal mapping John Soaring 35 April 27th 04 04:29 PM
