Helicopter
Old September 30th 09, 08:52 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
Default Helicopter
Stu,
Have you seen this one?
http://www.wimp.com/impossiblehelicopter/
Old October 5th 09, 06:16 PM posted to rec.aviation.homebuilt
Stu Fields
Default Helicopter
"cavelamb" wrote in message
m...
Stu,
I have now. Some how it seriously degrades the old adage: "Seeing is
Believing".
I was involved in the development of the shuttered video camera nearly 40
years ago when I worked at the Naval Weapons Center. We didn't even need
the radio signal. We could adjust the shutter speed to stop props and other
rotating devices. The radio signal would allow you to sync to a particular
blade tho...
Thanks
Stu
Old October 10th 09, 12:43 AM posted to rec.aviation.homebuilt
RogerN
Default Helicopter
m...
Stu,
There are optical tachs used on R/C heli's that you adjust the speed of a
shutter to make the blades appear still then read the rotor RPM.
RogerN
Old October 10th 09, 01:29 AM posted to rec.aviation.homebuilt
Dan[_12_]
Default Helicopter
m...
Stu,
RogerN
The military used to use strobe lights on real helicopters to "stop"
rotors. Another neat gag was a large F shaped devise that had a strip of
fabric across the opening. I think it was used to find out who was crazy
enough to approach the tips of spinning main rotors with it.
Dan, U.S. Air Force, retired
Old October 10th 09, 01:57 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
Default Helicopter
Dan wrote:
m...
Stu,
of a shutter to make the blades appear still then read the rotor RPM.
RogerN
Gee, I did that a bunch of times.
That was how you measure the tracking on a UH-1.
Gotta admit, though, it would definitely get your attention!
For sure!
Old October 10th 09, 04:24 AM posted to rec.aviation.homebuilt
Dan[_12_]
Default Helicopter
cavelamb wrote:
Dan wrote:
m...
Stu,
RogerN
of fabric across the opening. I think it was used to find out who was
crazy enough to approach the tips of spinning main rotors with it.
For sure!
The only time I have ever seen it done was on an H-3. I'm glad I
never had to do it myself. My kind of luck the pilot would have a
sneezing fit.
Dan. U.S. Air Force, retired
Old October 10th 09, 02:21 AM posted to rec.aviation.homebuilt
RogerN
Default Helicopter
"Dan" wrote in message
m...
Stu,
RogerN
I'm wondering if the F shaped device was to detect blade tracking, to see if
one blade was flying higher than the other?
RogerN
Old October 10th 09, 02:31 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
Default Helicopter
m...
Stu,
RogerN
RogerN
That's right.
The blades have a small tab sticking out the ends which get marked up heavily
with two different colored grease pencils.
Old October 10th 09, 04:03 AM posted to rec.aviation.homebuilt
Default Helicopter
On Fri, 09 Oct 2009 20:31:39 -0500, cavelamb
m...
Stu,
RogerN
RogerN
That's right.
Those tabs had a hole to hook your tiedown strap. Tail rotor was a
bit different. A grease pencil taped to a broom handle.
Old October 12th 09, 02:48 AM posted to rec.aviation.homebuilt
Brian Whatcott
Default Helicopter
m...
Stu,
RogerN
The usual optical (digital) tach sold by RC hobby sources reads through
a prop blade to a light background - can use mirror tape or a white
paint dab too. No synchronizing needed. About $25. I have one.
Switchable to read two blade or three blade.
Brian W
MINI 500, Rinke, Turbine, Helicopter for sale, Helicopter, Revolution, Turbine Power TurbineMini Richard Rotorcraft 2 January 28th 09 07:50 PM
boB and helicopter fly-in Stuart Fields Rotorcraft 3 February 14th 06 07:54 PM
aero-domains for helicopter pilots and helicopter companies secura Rotorcraft 0 June 26th 04 07:33 AM
JAG Helicopter Video, Rinke Aerospace, Spy Photos, JAG Helicopter, Helicopter, Black Ops Dennis Chitwood Rotorcraft 4 January 10th 04 05:34 PM
