Garmin 196 antenna inside fabric ?
Old October 4th 09, 09:30 PM posted to rec.aviation.homebuilt
Phil
Default Garmin 196 antenna inside fabric ?
Hello
Young friend of mine is finishing his EAA Biplane , he would like to
mount the detector/antenna inside the fabric so as to not show on the
outside of upper center section , the airplane is in the silver/aluminum
stage of painting , the alum. powder in primer is used to block UV , he is
wondering if it could also block the RF from the Sats., I told him that we
might get an answer off the group.
Thanks
Phil L.
Old October 5th 09, 08:49 AM posted to rec.aviation.homebuilt
Philippe[_2_]
Phil a écrit:
Hello
to
silver/aluminum stage of painting , the alum. powder in primer is used
to block UV , he is wondering if it could also block the RF from the
Sats., I told him that we might get an answer off the group.
Just try, it may work....
02°44'45"E 45°30'50"N
Philippe Vessaire Ò¿Ó¬
Old October 5th 09, 10:25 PM posted to rec.aviation.homebuilt
Morgans[_2_]
"Philippe" wrote in message
news:2548283.koFCf946Em@GastonCoute...
Phil a écrit:
Hello
to
How about making an inspection hatch for the antenna to be under, and make
the hatch out of fiberglass, or colored Plexiglas, or some other RF
transparent cover that does not need to be UV protected. I have no doubt
that you will need to be getting to the antenna once in a while anyway, so
that would kill two birds with one stone.
Jim in NC
Old October 5th 09, 10:10 AM posted to rec.aviation.homebuilt
J. Severyn
"Phil" wrote in message
Hello
Thanks
Phil L.
If alum powder particles are small enough to be mostly encapsulated by the
primer so that conductivity of the finished surface is poor, the attenuation
might be low (high conductivity will attenuate the signal). Make a test
patch slightly bigger than the GPS antenna. Set up the GPS to look at the
sats received power (most GPSs have this capability). Move the finished
patch over the antenna and watch the received power. There is a very good
chance it will work. It all depends on the amount of Al powder in the mix.
J. Severyn
AF6QO
RV-9A N79LH
Antenna under fabric in welded tube ship? Jon[_6_] Home Built 7 April 27th 08 06:50 PM
Garmin GA56 GPS antenna [email protected] Home Built 1 September 12th 07 02:31 AM
antenna for Garmin GPS in C172 or C152 d&tm Piloting 7 May 8th 07 02:12 AM
Garmin 95 antenna needed Marty from Florida Owning 0 February 19th 06 08:48 PM
Garmin remote antenna Dave Piloting 3 December 18th 05 11:58 AM
