Is anyone out there using these radios? Thanks to limited archive
searchability all I was able to find was a post a while back from Tim Mara saying that he had sold about 50 of them. I'm curious what the real world power drain is on them from a 12V sealed lead acid battery. Spec is a bit high at 300 mA for standby. But they sure are cheap...any reports? Tony Condon |
On Oct 5, 10:59*am, Tony wrote:
Is anyone out there using these radios? *Thanks to limited archive searchability all I was able to find was a post a while back from Tim Mara saying that he had sold about 50 of them. *I'm curious what the real world power drain is on them from a 12V sealed lead acid battery. Spec is a bit high at 300 mA for standby. *But they sure are cheap...any reports? Tony Condon We have one in a club glider, installed recently. So far, so good. The 300 mA spec appears to be accurate -- one of our club members checked this. Our ship has 12 AH battery now, so no particular concern for us. I have not flown with it, but pireps are good. I can vouch for the transmission quality -- I receive it nice & clear. -Evan Ludeman / T8 |
Hi Tony,
I have sold a few of them. You can read my review of it on my web site. http://www.cumulus-soaring.com/flightline.htm The customers seemed happy with them. I also offer wiring harnesses for the radio. Best Regards, Paul Remde Cumulus Soaring, Inc. "Tony" wrote in message ... Is anyone out there using these radios? Thanks to limited archive searchability all I was able to find was a post a while back from Tim Mara saying that he had sold about 50 of them. I'm curious what the real world power drain is on them from a 12V sealed lead acid battery. Spec is a bit high at 300 mA for standby. But they sure are cheap...any reports? Tony Condon |
On Oct 5, 2:07*pm, "Paul Remde" wrote:
Hi Tony, I have sold a few of them. *You can read my review of it on my web site..http://www.cumulus-soaring.com/flightline.htm The customers seemed happy with them. I also offer wiring harnesses for the radio. Best Regards, Paul Remde Cumulus Soaring, Inc. Paul - I did find the review on your website very helpful for the head to head comparison between other models. Thanks! |
On Oct 5, 2:20*pm, Tony wrote:
On Oct 5, 2:07*pm, "Paul Remde" wrote: Hi Tony, I have sold a few of them. *You can read my review of it on my web site.http://www.cumulus-soaring.com/flightline.htm The customers seemed happy with them. I also offer wiring harnesses for the radio. Best Regards, Paul Remde Cumulus Soaring, Inc. Paul - *I did find the review on your website very helpful for the head to head comparison between other models. Thanks! Can someone school me on the use of TSO vs non-TSO radios? I seem to recall someone at sometime saying that non-TSO was ok for part 91, and that TSO'd instrumentation was required for 121/135 ops. Also is the M760 actually TSO'd? I see that Microair has the FCC paperwork on their website, but they make absolutely no mention of the M760 being TSO'd. Thanks Pete |
I did an actual check of the current on the FL760 and it appears to run at
about +/-270mH at 12V...(current drain will be different rates at different voltages with this radio as well as any other). I didn't test (yet) any other radios to see if the manufacturers data was accurate or not but it appears they all will vary somewhat based on the voltage supplied. More important than simply stand-by power is the power required in receive and transmit and the lowest operational voltage the particular radio can operate at but it appears the FL760 does like a bit more current than some of the other small 57mm radios for stand-by but is still rather economical in current in the TX and RX modes which are somewhat in relation to TX output power and volume settings. Even at this the FL760 is low enough current drain to be a really good option for most glider batteries, especially with the most recent batteries we now offer...where in the past a 6-7 pound battery was pretty much limited to 6.5Ah the same battery size and weight today is likely to be more like 9-10Ah and even 14aH is common now with "glider size" rechargeable batteries, that's in the range of 30% more available Amp hours. The FL-760 doesn't approach the current drain of most transponders, a lot of the new big screen glider computers and Nav displays, or for that matter a lot of the older glider radios still in use today so I think the FL-760 for the cost and performance is still a pretty good option..I have personally used the FL-760 and sold a bunch of them and users have all had good response..the reliability so far has been excellent. The FL-760 is not TSO'd but doesn't need to be unless the radio is required as a piece of equipment that specifically calls for one that meets TSO "____" and since a transceiver is not "required" in gliders (unless you fly IFR) you are only required to have two way communications for flights as stated in part 91 when you have to be in contact with ATC, even then part 91 says nothing about communication with ATC with a TSO'd radio...so unless your flight manual or glider operations specifically state "TSO required" it isn't necessary. Transponders however are all required to be TSO'd for operation.....this is one piece of equipment that regardless of what it is installed in the equipment, used for ATC control is required to have this approval. And Transponders once installed MUST be certified by an approved avionics shop before operations and ALL Transponder equipped aircraft MUST have the transponder turned on and operational during ALL phases of flight..not just when you think it will be useful. tim Please visit the Wings & Wheels website at www.wingsandwheels.com "vontresc" wrote in message ... On Oct 5, 2:20 pm, Tony wrote: On Oct 5, 2:07 pm, "Paul Remde" wrote: Hi Tony, I have sold a few of them. You can read my review of it on my web site.http://www.cumulus-soaring.com/flightline.htm The customers seemed happy with them. I also offer wiring harnesses for the radio. Best Regards, Paul Remde Cumulus Soaring, Inc. Paul - I did find the review on your website very helpful for the head to head comparison between other models. Thanks! Can someone school me on the use of TSO vs non-TSO radios? I seem to recall someone at sometime saying that non-TSO was ok for part 91, and that TSO'd instrumentation was required for 121/135 ops. Also is the M760 actually TSO'd? I see that Microair has the FCC paperwork on their website, but they make absolutely no mention of the M760 being TSO'd. Thanks Pete |
Thanks, Tim. That makes a whole lot of sense. BTW have you tried
running any of these radios on less than 12V using a variable DC power supply? It would be very interesting to see where these radios quit working. Peter |
Is anyone out there using these radios? *Thanks to limited archive searchability all I was able to find was a post a while back from Tim Mara saying that he had sold about 50 of them. *I'm curious what the real world power drain is on them from a 12V sealed lead acid battery. Spec is a bit high at 300 mA for standby. *But they sure are cheap...any reports? Tony Condon I bought mine from Tim Mara, am very happy with it. On a single new fully charged 9AH battery I got 8 hours of powering the radio and CAI 302/303 together. When the battery voltage dropped below 10 volts the radio just came up with static when there was traffic on the frequency (I also had a hand-held monitoring), and would not transmit, but right up until that point it was fine. With two batteries in parallel I have yet to run out of power, even if I fly two days in a row without recharging the batteries. With proper mic and antenna the transmit/ receive quality is excellent. NG |
On Monday, October 5, 2009 at 10:59:31 AM UTC-4, Tony wrote:
Is anyone out there using these radios? Thanks to limited archive searchability all I was able to find was a post a while back from Tim Mara saying that he had sold about 50 of them. I'm curious what the real world power drain is on them from a 12V sealed lead acid battery. Spec is a bit high at 300 mA for standby. But they sure are cheap...any reports? Tony Condon I currently have a Microair 760 in my Luscombe 8. I am considering replacing it with a new FL-760. Will the same harness work? I think they are essentially the same radio. |
On Monday, October 5, 2009 at 9:59:31 AM UTC-5, Tony wrote:
Is anyone out there using these radios? Thanks to limited archive searchability all I was able to find was a post a while back from Tim Mara saying that he had sold about 50 of them. I'm curious what the real world power drain is on them from a 12V sealed lead acid battery. Spec is a bit high at 300 mA for standby. But they sure are cheap...any reports? Tony Condon Hey Tony, Our club put one in a 2-33 and another in a 1-26 several years ago, they work well, we switch out sla 7AH single batteries every other day or so. Keeping the unused battery on trickle charge. IMHO good value and much better than a hand held. Transmission quality goes into the toilet when the battery gets low. With the relative glut of Euro radios available, do you want new? I've bought a couple of Dittle fsg-2t from "Ross" and couldn't be happier with them. But make sure any dittles have the mods done! Good LIft, Scott |
Flightline FL-760 radio | T8 | Soaring | 5 | July 1st 09 09:23 AM |
FLIGHTLINE VHF RADIO ON EBAY | user[_2_] | Home Built | 2 | October 14th 08 09:59 PM |
FLIGHTLINE VHF RADIO ON EBAY | user[_2_] | Soaring | 2 | October 14th 08 09:59 PM |
R/C Flying, pt 3 - Flightline.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | July 4th 08 12:10 PM |
Old Ones are the Best Ones, pt 2 - Flightline.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | June 12th 07 12:41 AM |
