What happens when a glider reaches its end-of-life?
Old November 9th 09, 02:34 AM posted to rec.aviation.soaring
Michael[_7_]
Default What happens when a glider reaches its end-of-life?
Hi all,
Novice question here.....what happens when some of these vintage (or
even more modern) gliders reach their airframe end-of-life or number
of landing limits?
Is the aircraft now salvage or can things be done to refurbish it?
What things, if any, are typically done and about how many "additional
hours" does this give the glider?
--Michael
GHSA, Texas
Old November 9th 09, 03:51 AM posted to rec.aviation.soaring
BT
Most "American" gliders do not have an airframe end-of-life.
Tube and fabric,... recover it and repair any rusting tubes.
Wood and fabric.. rebuild it, replace the wood if it has dried out, cracked,
weakened glue joints.
Most of the "plastics" have a life hour or calendar year maximum. Most if
they still have factory support, or at one time if the factory had provided
instructions on how to extend a life before closing down, have
instructions/inspections replacement parts etc to extend the life hours.
Those that do not.. are salvage.
I know of a BG-12 that was beyond reasonable salvage.. it met it's end in a
bonfire.
There is a plastic (fiberglass) glider out there now that has no factory
support on how to complete a "life extension inspection". It is grounded.
Most European fiberglass gliders have "life extension inspections" at 3000hr
intervals up to 9000 or 12000hrs, then 1000hr intervals. Most will not be
flyable beyond those years/hours.
BT
"Michael" wrote in message
Hi all,
of landing limits?
--Michael
GHSA, Texas
Old November 9th 09, 04:54 AM posted to rec.aviation.soaring
Frank Whiteley
What Bill said.
The L-23's around have a service life, nominally 6,000 hours, adjusted
by use; aerobatics, flying with extended tips, or winch launching.
That would put operational use at typically 15-25 years. Others have
periodic inspections to extend life. One glass glider has a 3000 hour
life limit in the US, so they will be sold into countries that have
life extensions as they time out here. Works the other way with some
gliders that have time limits in other countries, but no limit in the
US. Some have had a shelf life. The all metal IS28-B2 for example.
But that has been extended multiple times, including the number of
hours and landings. It currently doesn't appear there will be much,
if any, further metal production for a variety of reasons.
When composite gliders were first built, there were a lot of
unknowns. Design life for early designs was 18,000 hours, with 3,000
hours adopted as the initial service life. As they reached 3,000
hours, more information was gathered and extension schemes were
developed. Metal fatigue in the control systems resulted in some AD's
and periodic replacement of parts. Prior to JAR22 and EASA, OSTIV
provided some guidance. Those early glass sailplanes tended to be
overbuilt and some may well be flying in the 22nd century. Of the ten
original Phonix, at last check nine remained airworthy, now 50 years
old, but of course they are no longer daily drivers. Design,
materials and methods have moved along. Will modern builds prove to
be as robust? Time will tell.
Experimental racing/exhibition gliders generally have no component
life limits, see FAA Order 8130.2F. Doesn't mean you should ignore
bulletins and ADs in countries where the same airframe may be
certified. But these airworthiness certificates are based on a
condition inspection and are restricted by operating limitations.
Now, there are some gliders out there that are getting pretty long in
the tooth and may require work that may be less than economical to
perform, at least until supply and demand change that equation.
You must have a specific example in mind.
Frank Whiteley
bonfire.
BT
Hi all,
of landing limits?
--Michael
GHSA, Texas
Old November 9th 09, 05:04 AM posted to rec.aviation.soaring
Tony[_5_]
Hi all,
of landing limits?
--Michael
GHSA, Texas
Michael,
This is the great benefit to owning an old wood glider. the parts grow
on trees.
Old November 9th 09, 08:24 AM posted to rec.aviation.soaring
Darryl Ramm
On Nov 8, 9:04*pm, Tony wrote:
[snip]
on trees.
And failing that they burn so much better on that bonfire than our
plastic ones.
Darryl
Old November 9th 09, 01:13 PM posted to rec.aviation.soaring
Tony[_5_]
[snip]
on trees.
plastic ones.
Darryl
no kidding! the s'mores taste much better without that fiberglass
taste!
Old November 10th 09, 04:05 AM posted to rec.aviation.soaring
ZZ
Frank Whiteley wrote:
What Bill said.
Frank Whiteley
Frank
An excellent summary.
Paul
ZZ
bonfire.
BT
Hi all,
of landing limits?
--Michael
GHSA, Texas
Old November 10th 09, 04:15 AM posted to rec.aviation.soaring
Michael[_7_]
Thank you everyone for the responses.
No, I didn't have a specific glider in mind. The question came to me
after I was studying the Blanik L-23 (in which I train) manual (6000
hours) and then read something about vintage gliders on the web.
I'm still learning about experimental aircraft and all the regs that
go with those, too.
--Michael
GHSA, Wallis, Texas
Old November 10th 09, 03:20 PM posted to rec.aviation.soaring
n7ly
What Frank said ------------
life limits, see FAA Order 8130.2F. *Doesn't mean you should ignore
certified. *But these airworthiness certificates are based on a
What Frank said - and -
There is a considerable difference in how the experimental operating
limitations have
been written over the years. Mine are worth the aircraft weight in
gold. They read
very much like older amateur built aircraft. It is unlikely to find
recent operating
limitations that are as flexible as the old ones. The FAA does not do
a good job
of translating the significance/importance of changes from foreign
documents and
won't stick their neck out. Avoid doing anything that would result in
requiring new
operating limitations. Newer is not better.
Dennis Brown
Old November 9th 09, 04:16 PM posted to rec.aviation.soaring
Frank Whiteley
On Nov 8, 7:34*pm, Michael wrote:
Hi all,
of landing limits?
--Michael
GHSA, Texas
Other options for non-serviceable gliders are displays (hanging in
public areas or on posts) and simulators (at least good cockpits).
Frank Whiteley
A Day in the life of ..... a glider addict ! fred Soaring 6 December 25th 08 10:47 PM
[T-shirt] A Day in the life of ..... a glider addict ! [email protected] Soaring 9 August 5th 08 07:56 PM
Life Insurance for Glider Pilots?? [email protected] Soaring 6 January 12th 05 07:41 PM
Standard Cirrus group reaches 200 Jim Hendrix Soaring 0 August 9th 04 10:23 PM
V-22 Osprey reaches 1,000-hour milestone Otis Willie Military Aviation 0 December 15th 03 09:58 PM
