Visualize a glider on a experimental certificate:
1- Does it take a "pro" (I.E a glider repair shop used to do this on a regular basis) to redo the gelcoat on a glider legally, or can it be done by anyone? 2- What needs to be entered in the logbooks, if any? Thanks |
On Nov 18, 7:41*am, jeplane wrote:
Visualize a glider on a experimental certificate: 1- Does it take a "pro" (I.E a glider repair shop used to do this on a regular basis) to redo the gelcoat on a glider legally, or can it be done by anyone? 2- What needs to be entered in the logbooks, if any? In the US, 14CFR43.1(b), Applicability, says that Part 43 applies does not apply to experimental aircraft. That includes a huge mass of verbiage about who can perform and sign off various repairs. Ergo, none (as in not any) of that verbiage applies to experimental aircraft. That isn't to say that there aren't any rules, just that they're not in Part 43. One place where there definitely rules about this is in the operating limitations that accompany the special airworthiness certificate issued for the purposes of operating an experimental aircraft. Those OpLims are actually part of the special AW cert, and the AW certificate is not valid unless accompanied by them in the aircraft. So make sure you have your OpLims document and that you have it in the aircraft. I usually keep two copies in the aircraft; one folded up and tucked into the clear plastic document holder with the AW cert and the registration cert, and one tucked under the seat cushion that I can refer to at need (in flight if necessary). Personally, if the OpLims do not specifically state that maintenance and repair must be performed by persons with thus and such certification (A&P, IA or whatever), I would operate under the assumption that anybody can do the repair until it is demonstrated otherwise with a reference to something relevant in the 14CFE or in the OpLims. If I did the repair, I would document it in the logs with simple, clear language and sign it with my airman's cert number. One major control over the maintenance and repair of experimental aircraft is that the annual condition inspection (not an airworthiness inspection, by the way) must be signed off by either an A&P mechanic or an IA or the holder of a repairbeing certificate applicable to the particular aircraft. If you are the holder of the repaircreature certificate, no sweat, you hold both the authority and the responsibility. If you are not said certificate holder, you have to do the repair in such a way as that you can convince an A&P or IA to sign off on the condition inspection. If you do a shoddy job and document it poorly, you might have trouble getting that inspection signoff. So do good work using good practices such as those described in AC43.13 where applicable, and keep good records of what you did. Thanks, Bob K. www.hpaircraft.com |
On Nov 18, 9:00*am, Bob Kuykendall wrote:
On Nov 18, 7:41*am, jeplane wrote: Visualize a glider on a experimental certificate: 1- Does it take a "pro" (I.E a glider repair shop used to do this on a regular basis) to redo the gelcoat on a glider legally, or can it be done by anyone? 2- What needs to be entered in the logbooks, if any? In the US, 14CFR43.1(b), Applicability, says that Part 43 applies does not apply to experimental aircraft. That includes a huge mass of verbiage about who can perform and sign off various repairs. Ergo, none (as in not any) of that verbiage applies to experimental aircraft. That isn't to say that there aren't any rules, just that they're not in Part 43. One place where there definitely rules about this is in the operating limitations that accompany the special airworthiness certificate issued for the purposes of operating an experimental aircraft. Those OpLims are actually part of the special AW cert, and the AW certificate is not valid unless accompanied by them in the aircraft. So make sure you have your OpLims document and that you have it in the aircraft. I usually keep two copies in the aircraft; one folded up and tucked into the clear plastic document holder with the AW cert and the registration cert, and one tucked under the seat cushion that I can refer to at need (in flight if necessary). Personally, if the OpLims do not specifically state that maintenance and repair must be performed by persons with thus and such certification (A&P, IA or whatever), I would operate under the assumption that anybody can do the repair until it is demonstrated otherwise with a reference to something relevant in the 14CFE or in the OpLims. If I did the repair, I would document it in the logs with simple, clear language and sign it with my airman's cert number. One major control over the maintenance and repair of experimental aircraft is that the annual condition inspection (not an airworthiness inspection, by the way) must be signed off by either an A&P mechanic or an IA or the holder of a repairbeing certificate applicable to the particular aircraft. If you are the holder of the repaircreature certificate, no sweat, you hold both the authority and the responsibility. If you are not said certificate holder, you have to do the repair in such a way as that you can convince an A&P or IA to sign off on the condition inspection. If you do a shoddy job and document it poorly, you might have trouble getting that inspection signoff. So do good work using good practices such as those described in AC43.13 where applicable, and keep good records of what you did. Thanks, Bob K.www.hpaircraft.com Lets not get hung up on the letter of the law, here. Re-painting control surfaces involves suspending the surface at the hinge point (I like to hang them on twine) in a horizontal position and measuring the weight at the trailing edge. Readings (in ounces ) X distanse from hinge line are then checked against the maximum allowed in the hand book. If out of tolerance, weight must be secured ahead of the hings line. This is not something I would trust to unskilled hands. Do it wrong and you go to flutter city. Been there, done that, and don't wish to revisit the place. Have a knowledgeable guy hold your hand. Hope this helps, JJ |
On Nov 18, 10:41*am, jeplane wrote:
Visualize a glider on a experimental certificate: 1- Does it take a "pro" (I.E a glider repair shop used to do this on a regular basis) to redo the gelcoat on a glider legally, or can it be done by anyone? 2- What needs to be entered in the logbooks, if any? Thanks Does not take a "pro" as long as you can accomplish the following elements. 1 Determine whether gelcoat damage being removed/repaired does not reach structural layers. 2. Remove correct amount of gelcoat without damaging underlying structure. 3 Know how to properly evaluated and repair consequences of failing to do '2" above correctly. 4. Able to do actions required to ensure that control surfaces meet mass and moment specifications in aircraft maintenace manual. This almost always requires removal and reinstallation after weighing. Nobody who has done this very often leaves surfaces on. This requires logbook entry by qualified individual- A&P. 5. Able to accomplish appropriate weight and balance record keeping and revision to operation limits. Logbook entry by A&P. Many gliders are started on this path by"non pros". The list is long of those that get completed later by "pros" at greater expense than hoped. It can be lots more work to fix mistakes and sometimes permanent damage results. If you want to do it yourself, please enlist the help and guidance of soemone known to be skilled in this. Good Luck UH |
On Nov 18, 9:04*am, wrote:
... 4. Able to do actions required to ensure that control surfaces meet mass and moment specifications in aircraft maintenace manual. This almost always requires removal and reinstallation after weighing. *Nobody who has done this very often leaves surfaces on. This requires logbook entry by qualified individual- A&P. Hank, remember that we are talking about an experimental aircraft, which 14CFR43.1(b) exempts from everything in part 43. So unless the OpLims require an A&P signoff, I would [citation needed] any generic statement about an A&P signoff being required. 5. Able to accomplish appropriate weight and balance record keeping and revision to operation limits. Logbook entry by A&P. Same as above. Many gliders are started on this path by"non pros". The list is long of those that get completed later by "pros" at greater expense than hoped. Many gliders and airplanes have also been built, maintained, and repaired by "non pros," at lower expense, with greater performance and utility, and greater enjoyment than hoped. Bottom line, I agree with the sentiment that you should seek guidance wisely, and proceed cautiously, when undertaking critical repair and maintenance operations. But I would disagree with the idea, implied or explicit, that working on aircraft is too difficult to be left to any ordinary folks. Thanks again, Bob K. www.hpaircraft.com |
On Nov 18, 1:57*pm, Bob Kuykendall wrote:
On Nov 18, 9:04*am, wrote: ... 4. Able to do actions required to ensure that control surfaces meet mass and moment specifications in aircraft maintenace manual. This almost always requires removal and reinstallation after weighing. *Nobody who has done this very often leaves surfaces on. This requires logbook entry by qualified individual- A&P. Hank, remember that we are talking about an experimental aircraft, which 14CFR43.1(b) exempts from everything in part 43. So unless the OpLims require an A&P signoff, I would [citation needed] any generic statement about an A&P signoff being required. 5. Able to accomplish appropriate weight and balance record keeping and revision to operation limits. Logbook entry by A&P. Same as above. Many gliders are started on this path by"non pros". The list is long of those that get completed later by "pros" at greater expense than hoped. Many gliders and airplanes have also been built, maintained, and repaired by "non pros," at lower expense, with greater performance and utility, and greater enjoyment than hoped. Bottom line, I agree with the sentiment that you should seek guidance wisely, and proceed cautiously, when undertaking critical repair and maintenance operations. But I would disagree with the idea, implied or explicit, that working on aircraft is too difficult to be left to any ordinary folks. Thanks again, Bob K.www.hpaircraft.com I completely agree that we are not talking about some black art, much as the FAA would like us to believe it is. That said, there are some areas where real care needs to be taken, a couple of which I described before. FWIW- The limitations on both my Experimental Exhibition and Air racing licensed gliders specifically mention that maintenance is to be done in accordance with the manual provided with the glider. It does not say, in all cases, who can do the work. All this said, care and conservative wisdom can save heart ache. And maybe some expensive bills. It is also true that taking a serious interest in doing a good job maintaining your glider is a very good thing. A very knowledgeble owner likely will keep his glider is as good, or better shape than lots of "pros". CU UH |
On Nov 18, 1:19*pm, wrote:
I completely agree that we are not talking about some black art, much as the FAA would like us to believe it is... I fully agree with you, and I agree especially with this point in particular. The FAA policy verbiage regarding experimental aircraft in specific, and general aviation aircraft in general is in some respects at odds with the actual language in 14CFR. And individual FSDOs are often at odds with each other about how both the policies and the rules in 14CFR are interpreted and enforced. My favorite example of this is the language in 14CFR21 that allows owners of type-certificated aircraft to manufacture replacement parts for their own aircraft under certain fairly reasonable circumstances. I've talked with a couple of DERs and DARs who swear up and down that that cannot possibly be true, and that any part not anointed and blessed by FAA, TSO, PMA and STC and other TLAs too numerous to mention is bogus, counterfeit and illegal. And yet there it is in black and white in 14CFR21.303. Here are my two favorite articles on this topic: http://www.faa.gov/news/aviation_new...ulyAug2001.pdf http://www.faa.gov/news/aviation_new...ulyAug2002.pdf I like to encourage people to understand exactly what the FAA and the regulations in 14CFR actually do and do not require when it comes to the maintenance, repair, and modification of experimental aircraft. And to further understand the authority under which those requirements are based. My somewhat paranoid fear is that if we let ourselves believe that an officially-blessed signoff is required for every little thing, then some day the FAA may come to believe it as well. And when they find out it's not true, they will just go ahead and make it true in the next round of NPRMs. Thanks again, and best regards to all Bob K. www.hpaircraft.com |
On Nov 18, 2:29*pm, Bob Kuykendall wrote:
On Nov 18, 1:19*pm, wrote: I completely agree that we are not talking about some black art, much as the FAA would like us to believe it is... I fully agree with you, and I agree especially with this point in particular. The FAA policy verbiage regarding experimental aircraft in specific, and general aviation aircraft in general is in some respects at odds with the actual language in 14CFR. And individual FSDOs are often at odds with each other about how both the policies and the rules in 14CFR are interpreted and enforced. My favorite example of this is the language in 14CFR21 that allows owners of type-certificated aircraft to manufacture replacement parts for their own aircraft under certain fairly reasonable circumstances. I've talked with a couple of DERs and DARs who swear up and down that that cannot possibly be true, and that any part not anointed and blessed by FAA, TSO, PMA and STC and other TLAs too numerous to mention is bogus, counterfeit and illegal. And yet there it is in black and white in 14CFR21.303. Here are my two favorite articles on this topic: http://www.faa.gov/news/aviation_new...ulyAug2001.pdf http://www.faa.gov/news/aviation_new...ulyAug2002.pdf I like to encourage people to understand exactly what the FAA and the regulations in 14CFR actually do and do not require when it comes to the maintenance, repair, and modification of experimental aircraft. And to further understand the authority under which those requirements are based. My somewhat paranoid fear is that if we let ourselves believe that an officially-blessed signoff is required for every little thing, then some day the FAA may come to believe it as well. And when they find out it's not true, they will just go ahead and make it true in the next round of NPRMs. Thanks again, and best regards to all Bob K.www.hpaircraft.com Well, my answer to all that goobeldeegook is the build my own sailplane: Once you get the N-number, the FAA inspection and the Amateur Built CofA, AND your repairmens certificate, you are on your own and left alone! Heck, what's so hard about that...... ![]() Brad |
![]() The process is very messy and can be hazardous to your health. And it takes many, many hours of careful preperation. Labor intensive. As JJ said, mass balance of controls is very important. 400-1000 hours is possible...no joke. Polyurethane may be best way to go. GA |
On Nov 18, 3:35*pm, glider wrote:
*The process is very messy and can be hazardous to your health. And it takes many, many hours of careful preperation. *Labor intensive. *As JJ said, mass balance of controls *is very important. * 400-1000 hours is possible...no joke. *Polyurethane may be best way to go. *GA Jim Phoenix nicely documented the refinish on his Nimbus 3. http://www.jimphoenix.com/?page_id=42 Heck, anything less than 18m will seem like a cakewalk. Just don't plan on having a social life this winter... Best regards, Craig Funston |
Source for Gelcoat in USA? | John Bojack[_2_] | Soaring | 1 | June 9th 09 05:25 AM |
Gelcoat sag? | [email protected] | Soaring | 10 | December 17th 07 08:07 PM |
Fiberglass/gelcoat repair question | Kilo Charlie | Soaring | 9 | April 19th 05 03:30 PM |
Ferro gelcoat | Basil Fairston | Soaring | 0 | December 16th 03 08:34 AM |
Refinishing gelcoat | tango4 | Soaring | 21 | November 3rd 03 07:29 AM |
