Given a mean sea level designated as A,
if a distance of 1,173 ft is required for a plane to take off when the temperature is 73 degrees F, and 1,356 ft when the temp. is 86 degrees F, then what distance is required when the temp. is 79.5 degrees, and given a different elevation (B) in which a distance of 1,173 ft. is required for takeoff when the temp. is 70 degrees F, and 1,356 ft.when the temp. is 80 degrees, then at 75 degrees, what is the difference in takeoff distance between the two respective elevations? --- Mark |
On Nov 19, 2:27*pm, Mark wrote:
Given a mean sea level designated as A, if a distance of 1,173 ft is required for a plane to take off when the temperature is 73 degrees F, and 1,356 ft when the temp. is 86 degrees F, then what distance is required when the temp. is 79.5 degrees, and given a different elevation (B) in which a distance of 1,173 ft. is required for takeoff when the temp. is 70 degrees F, and 1,356 ft.when the temp. is 80 degrees, then at 75 degrees, what is the difference in takeoff distance between the two respective elevations? --- Mark Since I didn't get any takers on my quiz, then I'll go ahead and reveal that it was sort of a trick question. See, the elevation works out to give us a take-off distance of...1,264.5 ft. But when you do the math on the second elevation, it also comes out to 1,264.5 ft., so, There is no difference in distance. I designed the problem to come out with equal take-off distances. So you say, then it's impossible, given the temperature spread and density altitudes for the performance to vary like that. Answer: It was 2 different airplanes! (not relevant to the problem) --- Mark |
On Nov 20, 7:25*pm, Mark wrote:
On Nov 19, 2:27*pm, Mark wrote: Given a mean sea level designated as A, if a distance of 1,173 ft is required for a plane to take off when the temperature is 73 degrees F, and 1,356 ft when the temp. is 86 degrees F, then what distance is required when the temp. is 79.5 degrees, and given a different elevation (B) in which a distance of 1,173 ft. is required for takeoff when the temp. is 70 degrees F, and 1,356 ft.when the temp. is 80 degrees, then at 75 degrees, what is the difference in takeoff distance between the two respective elevations? --- Mark Since I didn't get any takers on my quiz, then I'll go ahead and reveal that it was sort of a trick question. See, the elevation works out to give us a take-off distance of...1,264.5 ft. But when you do the math on the second elevation, it also comes out to 1,264.5 ft., so, There is no difference in distance. I designed the problem to come out with equal take-off distances. So you say, then it's impossible, given the temperature spread and density altitudes for the performance to vary like that. Answer: *It was 2 different airplanes! (not relevant to the problem) --- Mark Proved- In the first scenerio of elevation A we establish a relationship of the temperatures, such that the unknown temperature/distance at 79.5 degrees is expressed as 6.5/13, because the difference between 73 degrees and 86 degrees is 13, and the difference between 73 degrees and 79.5 is 6.5...therefore, 6.5 over 13. Then you can do this in your head, the difference between 1,173 ft. and 1,356 ft is 183. The only thing missing now is the take-off distance at 79.5. This is simply...X. So, by interpolation, one can see- 6.5/13 = X/183 Then, 13X = 1189.5 So, X = 91.5 Therefore, 1,173 ft + 91.5 ft = 1264.5 ft at 79.5 degrees That's the first answer. Now, thru reverse engineering, we can use trickery and make another simple set of data which yields the same answer, then apply it to the landing strip scenerio. Ok, we want an equation in which the answer comes out to 91.5 ft again, and uses the same take-off distance difference of 183. So... I establish a temperature relationship between 70 degrees and 80 degrees as...duh, 10. The unknown distance temperature is now 75, which is simply expressed as 5 over 10, or 5/10. Now the numbers are rigged to come out again to 91.5 ft. So... 5/10 = X/183 and 10X = 915 Therefore, X = 91.5 again. And like before, 1,173 + 91.5 = 1,264.5 ft. again. Same answer for both take-off distances. --- Mark |
Sailplane quiz | Mike[_8_] | Soaring | 5 | April 3rd 07 03:45 PM |
Aircraft guess quiz | [email protected] | Piloting | 2 | May 6th 06 10:03 AM |
Pop Quiz | Flyingmonk | Piloting | 19 | April 26th 06 01:54 AM |
Fun Quiz | John Clonts | Owning | 2 | August 14th 05 04:35 AM |
Thursday's Basrak hotel bombing | John Keeney | Military Aviation | 0 | March 21st 04 06:15 AM |
