Pixel Qi display with both e-text and color display modes.
http://www.pixelqi.com/products http://techland.com/2009/05/30/pixel...-of-e-reading/ |
On Dec 22, 6:47*am, Tim Taylor wrote:
Pixel Qi display with both e-text and color display modes. http://www.pixelqi.com/products http://techland.com/2009/05/30/pixel...-is-the-future... Tim, The Pixel Qi screen is OK in the sun notice they did not show any true colors in the picture. If you want to see the best in the sun. http://www.hvgc.com.au/blog/?p=262 It is designed for sunlight readabiltiy. I have not seen anything better, and I have looked. Richard www.craggyaero.com |
On Dec 22, 12:00*pm, Richard wrote:
On Dec 22, 6:47*am, Tim Taylor wrote: Pixel Qi display with both e-text and color display modes. http://www.pixelqi.com/products http://techland.com/2009/05/30/pixel...-is-the-future... Tim, The *Pixel Qi screen is OK in the sun notice they did not show any true colors in the picture. * *If you want to see the best in the sun.. http://www.hvgc.com.au/blog/?p=262 It is designed for sunlight readabiltiy. I have not seen anything better, and I have looked. Richardwww.craggyaero.com I don't need color and the reduced energy use would be extremely helpful in the glider. I look forward to this technology being tried for use in the glider. I don't see any data on the refresh rates in the e-paper mode, that will be the determining factor if one can be used in the glider. |
On Dec 22, 11:49*am, Tim Taylor wrote:
On Dec 22, 12:00*pm, Richard wrote: On Dec 22, 6:47*am, Tim Taylor wrote: Pixel Qi display with both e-text and color display modes. http://www.pixelqi.com/products http://techland.com/2009/05/30/pixel...-is-the-future.... Tim, The *Pixel Qi screen is OK in the sun notice they did not show any true colors in the picture. * *If you want to see the best in the sun. http://www.hvgc.com.au/blog/?p=262 It is designed for sunlight readabiltiy. I have not seen anything better, and I have looked. Richardwww.craggyaero.com I don't need color and the reduced energy use would be extremely helpful in the glider. *I look forward to this technology being tried for use in the glider. *I don't see any data on the refresh rates in the e-paper mode, that will be the determining factor if one can be used in the glider.- Hide quoted text - - Show quoted text - Tim, I fly with two batteries one 9 amp hour, one 12 amp hour, with the following equipment I don't have battery issues with 7 hour flights. Equipment CAI 302, 303, Ultimate full brightness max current draw, Microair 760, Microair T2000 transponder, Borgelt B400, Tail water dump solenoid (this draws the most when used). Richard www.craggyaero.com |
On Dec 22, 12:00*pm, Richard wrote: On Dec 22, 6:47*am, Tim Taylor wrote: Pixel Qi display with both e-text and color display modes. http://www.pixelqi.com/products http://techland.com/2009/05/30/pixel...-is-the-future.... Tim, The *Pixel Qi screen is OK in the sun notice they did not show any true colors in the picture. * *If you want to see the best in the sun. http://www.hvgc.com.au/blog/?p=262 It is designed for sunlight readabiltiy. I have not seen anything better, and I have looked. Richardwww.craggyaero.com I don't need color and the reduced energy use would be extremely helpful in the glider. *I look forward to this technology being tried for use in the glider. *I don't see any data on the refresh rates in the e-paper mode, that will be the determining factor if one can be used in the glider.- Hide quoted text - - Show quoted text - Tim, I suspect that it would be rather hard to find a black and white display, and I would guess that they don't use any less power. If you don't want color you could probably turn it off with SeeYou Mobile software. Richard www.craggyaero.com |
On Dec 22, 12:45*pm, Richard wrote:
On Dec 22, 11:49*am, Tim Taylor wrote: On Dec 22, 12:00*pm, Richard wrote: On Dec 22, 6:47*am, Tim Taylor wrote: Pixel Qi display with both e-text and color display modes. http://www.pixelqi.com/products http://techland.com/2009/05/30/pixel...-is-the-future... Tim, The *Pixel Qi screen is OK in the sun notice they did not show any true colors in the picture. * *If you want to see the best in the sun. http://www.hvgc.com.au/blog/?p=262 It is designed for sunlight readabiltiy. I have not seen anything better, and I have looked. Richardwww.craggyaero.com I don't need color and the reduced energy use would be extremely helpful in the glider. *I look forward to this technology being tried for use in the glider. *I don't see any data on the refresh rates in the e-paper mode, that will be the determining factor if one can be used in the glider.- Hide quoted text - - Show quoted text - Tim, I suspect that it would be rather hard to find a black and white display, and I would guess that they don't use any less power. If you don't want color you could probably *turn it off with SeeYou Mobile software. Richardwww.craggyaero.com Richard You need to read the link Tim posted. I've mentioned Pixel Qi here before as a future interesting display technology. Pixel Qi has a reflective LCD monochrome display with some "color hinting" in full daylight that runs with full color and backlight indoors. It is likely the most interesting near term evolution in consumer display technology and should appear in netbooks, e-book readers, tablets, etc. It's a pretty simple transition for vendors using current LCD displays to adopt the Pixel Qi display. They have high pixel density, low power (compared to conventional LCD).Unliek e-ink you get full motion and video etc. But it consumes significantly more power than e-ink. But personally I think e-ink type displays are too limiting even for e-book readers. Longer term we've got OLED, DMD and color e-ink technologies coming, but they have their own problems and will take longer to arrive in strength. Darryl |
On Dec 22, 4:04*pm, Darryl Ramm wrote:
On Dec 22, 12:45*pm, Richard wrote: On Dec 22, 11:49*am, Tim Taylor wrote: On Dec 22, 12:00*pm, Richard wrote: On Dec 22, 6:47*am, Tim Taylor wrote: Pixel Qi display with both e-text and color display modes. http://www.pixelqi.com/products http://techland.com/2009/05/30/pixel...-is-the-future... Tim, The *Pixel Qi screen is OK in the sun notice they did not show any true colors in the picture. * *If you want to see the best in the sun. http://www.hvgc.com.au/blog/?p=262 It is designed for sunlight readabiltiy. I have not seen anything better, and I have looked. Richardwww.craggyaero.com I don't need color and the reduced energy use would be extremely helpful in the glider. *I look forward to this technology being tried for use in the glider. *I don't see any data on the refresh rates in the e-paper mode, that will be the determining factor if one can be used in the glider.- Hide quoted text - - Show quoted text - Tim, I suspect that it would be rather hard to find a black and white display, and I would guess that they don't use any less power. If you don't want color you could probably *turn it off with SeeYou Mobile software. Richardwww.craggyaero.com Richard You need to read the link Tim posted. I've mentioned Pixel Qi here before as a future interesting display technology. Pixel Qi has a reflective LCD monochrome display with some "color hinting" in full daylight that runs with full color and backlight indoors. It is likely the most interesting near term evolution in consumer display technology and should appear in netbooks, e-book readers, tablets, etc. It's a pretty simple transition for vendors using current LCD displays to adopt the Pixel Qi display. They have high pixel density, low power (compared to conventional LCD).Unliek e-ink you get full motion and video etc. But it consumes significantly more power than e-ink. But personally I think e-ink type displays are too limiting even for e-book readers. Longer term we've got OLED, DMD and color e-ink technologies coming, but they have their own problems and will take longer to arrive in strength. Darryl Actually, there are prototype full-color "electronic-ink" displays being shown around to product developers. The press releases say they are fast enough for video. I expect that within a year or so we'll have paper thin reflective- only extremely low power displays that look like magazine covers. Glider cockpits will never be the same. |
Digital Paper displays | Roger Worden | Soaring | 11 | December 11th 06 03:47 PM |
Cockpit video displays. Was: Get Rid Of Warbirds At Oshkosh | Jim Logajan | Home Built | 18 | August 16th 06 05:10 AM |
Cockpit video displays. Was: Get Rid Of Warbirds At Oshkosh | Jim Logajan | Piloting | 16 | August 16th 06 03:01 AM |
IL2 Forgotten Battles Displays upside down | LeonardR | Simulators | 15 | June 4th 05 08:55 PM |
More on FOTI / A-6 Radar Displays | Mike Kanze | Naval Aviation | 0 | September 28th 04 02:42 AM |
