Anybody ever convert a fixed aluminum panel to a tilt version - using
the factory or any other design. Question 2 ... can you replace the aluminum panel with a glass version ... perhaps with the addition of tabs or stiffeners ... thanks, |
On Dec 24, 8:20*am, "Ken Kochanski (KK)"
wrote: Anybody ever convert a fixed aluminum panel to a tilt version - using the factory or any other design. Question 2 ... can you replace the aluminum panel with a glass version ... perhaps with the addition of tabs or stiffeners ... thanks, Ken, I converted my ventus b panel to fiberglass and moved it aft. Arms too short.. I put a stiffener .25" X 2" aluminum bar with angle brackets about 12 inches forward of the original panel. I have several fiber glass panels they are cut for the Craggy Aero Ultimate. Pictures on the following page http://www.craggyaero.com/ultimate.htm Richard www.craggyaero.com |
wrote: Anybody ever convert a fixed aluminum panel to a tilt version - using the factory or any other design. Question 2 ... can you replace the aluminum panel with a glass version ... perhaps with the addition of tabs or stiffeners ... thanks, Ken, I also have a mold for a blank panel and could make you one. Call if you are interested Richard www.craggyaero.com |
You can buy the tilt-up panel parts from Schempp-Hirth. Heinz would
know. Perhaps there's a used one about somewhere, from a wrecked Ventus C or later? Liz Schwenkler did the mod on the Nimbus 3 I bought from her. Tilt- up glass panel with tabs on it and notches cut in the canopy rail. Also requires tabs on the glare shield. You may need a new glare shield for the flat-topped panel, if your B has a round panel. The S-H tilt up panels take a bit of getting used to. They make it nicer to get in and out, except that you must use two steps to close the canopy: 1. Tilt panel down. 2. Close canopy. Skipping step 1 could break the forward hinge on the canopy. Rented a Ventus C in South Africa which was combat repaired from the previous pilot making that mistake. Another note. Cut the brake handle down so it won't hit anything in the panel. My radio was in the lowest spot, and when I bought the glider the stick had to be moved out of the way to lower the panel without hitting the dual concentric knobs. Cutting an inch or so off the motorcycle brake handle fixed that. You know the ridge will be working the day you rip the glider apart! Jim |
On Dec 24, 9:52*am, JS wrote:
* You can buy the tilt-up panel parts from Schempp-Hirth. Heinz would know. Perhaps there's a used one about somewhere, from a wrecked Ventus C or later? * Liz Schwenkler did the mod on the Nimbus 3 I bought from her. Tilt- up glass panel with tabs on it and notches cut in the canopy rail. Also requires tabs on the glare shield. You may need a new glare shield for the flat-topped panel, if your B has a round panel. * The S-H tilt up panels take a bit of getting used to. They make it nicer to get in and out, except that you must use two steps to close the canopy: 1. Tilt panel down. 2. Close canopy. Skipping step 1 could break the forward hinge on the canopy. Rented a Ventus C in South Africa which was combat repaired from the previous pilot making that mistake. * Another note. Cut the brake handle down so it won't hit anything in the panel. My radio was in the lowest spot, and when I bought the glider the stick had to be moved out of the way to lower the panel without hitting the dual concentric knobs. Cutting an inch or so off the motorcycle brake handle fixed that. * You know the ridge will be working the day you rip the glider apart! Jim Good idea cutting the brake handle. Mine after the short arms mod could hit a radio knob if it was full forward. Thanks, Richard www.craggyaero.com |
Forgot it also needs tabs on the canopy rail to stop the panel from
jumping up on those red-line ridge days. Jim |
On Dec 24, 12:52*pm, JS wrote:
* Another note. Cut the brake handle down so it won't hit anything in the panel. My radio was in the lowest spot, and when I bought the glider the stick had to be moved out of the way to lower the panel without hitting the dual concentric knobs. Cutting an inch or so off the motorcycle brake handle fixed that. Or just throw the handle away, doesn't do anything anyway... |
On Dec 24, 2:59*pm, Dave Nadler wrote:
( brake handle) Or just throw the handle away, doesn't do anything anyway... Good point! The hydraulic brake mod helps. Jim |
Hydraulic brake mod ?
On Dec 24, 11:20*am, "Ken Kochanski (KK)"
wrote: Anybody ever convert a fixed aluminum panel to a tilt version - using the factory or any other design. Question 2 ... can you replace the aluminum panel with a glass version ... perhaps with the addition of tabs or stiffeners ... thanks, You should think about replacing the aluminum panel with a glass part with a beefy flange. Much safer in an accident. Proven unfortunately the hard way. Hope that helps, See ya Dave |
Looking for an uncut Ventus panel?? | Gary Emerson | Soaring | 3 | October 15th 07 10:31 PM |
Discus A Tilt-Up Panel | Chuck Schroeder | Soaring | 1 | February 18th 07 04:23 PM |
Tilt-wing V-22 Osprey? | Henry J Cobb | Naval Aviation | 0 | February 11th 07 06:28 PM |
Ventus Panel upgrade | Fish | Soaring | 3 | September 12th 06 10:44 PM |
"V-22 Osprey Tilt-Rotor Aircraft" | Mike | Naval Aviation | 0 | September 28th 05 02:46 PM |
