Skin repairs on a Schroeder type trailer
Old December 30th 09, 11:06 PM posted to rec.aviation.soaring
Brad[_2_]
Default Skin repairs on a Schroeder type trailer
I've got a trailer that was damaged a few years back when a load of
snow slid off the roof and landed right on the skin. About 5 of the
fiberglass ribs are broken and the skin is fractured, split and
generally ripped apart in a few areas.
Has anyone got some idea about how to repair the broken skin? I can
easily make new ribs, but the skin looks a bit challenging to repair.
Maybe replacing the broken sections with pre-cured laminated sheets is
the way to go?
Any thoughts would be appreciated................heck, I guess if I
can build a glider I can repair a busted trailer top!
Thanks,
Brad
Old December 31st 09, 01:55 AM posted to rec.aviation.soaring
the way to go?
Thanks,
Brad
Did one of those a few years ago- Yep snow made shed fall on it.
We made replacement bows from 3/4 EMT and bonded them in next to
damaged bows. Much less work than making a form to
do proper repair on fiberglass bows. Skins will be a bit of a problem
because they are probably brittle and it will be a challange to get
stuff to go to contour. We only had a few minor repairs. I'd suggest
premaking flat skin using 3 layers of 92110 bid and bonding to the
inside. If there is a good straight section, you could just lay some
plastic on it and laminate skin pre bent.
Good Luck
UH
Old December 31st 09, 03:52 PM posted to rec.aviation.soaring
Mike[_32_]
the way to go?
Thanks,
Brad
Good Luck
UH
On old friend of mine, Steve Bowen, had the same thing happen. He
found a source of a fiberglass panel and replaced the complete top.
The last I knew he was in the Winona, Minnesota area. Perhaps he reads
RAS.
TM6 repairs in the UK Ian Johnston Soaring 2 January 21st 06 10:26 PM
COBRA Skin Trailer Protector - Commercial John Seaborn Soaring 0 July 20th 04 04:38 PM
flight navigator3.0 Helga Schroeder [email protected] Piloting 0 January 28th 04 05:08 PM
flight navigator3.0 Helga Schroeder [email protected] Piloting 0 January 28th 04 05:00 PM
1894 Driggs-Schroeder 6 pdr surviving old hoodoo Naval Aviation 8 December 2nd 03 11:28 PM
