![]() Rumor has (had), it that the Feds were about to authorize a nation wide non-discrete transponder code for gliders which was to be 0000 in lieu of the current VFR squawk of 1200. Does anyone know anything about this or is this just another pipe dream? Zulu |
zulu wrote:
Rumor has (had), it that the Feds were about to authorize a nation wide non-discrete transponder code for gliders which was to be 0000 in lieu of the current VFR squawk of 1200. Does anyone know anything about this or is this just another pipe dream? Sounds like NTSB recommendation A-08-12 that they sent to the FAA in this letter: http://www.ntsb.gov/Recs/letters/2008/A08_10_13.pdf The NTSB sent another letter at the same time to SSA: http://www.ntsb.gov/Recs/letters/2008/A08_14_15.pdf Likely the FAA will issue a notice of proposed rule making if it decides to ever follow up on A-08-12. Don't know how the coming ADS-B regs change the playfield with respect to gliders. |
On Jan 2, 8:00*pm, Jim Logajan wrote:
zulu wrote: Rumor has (had), it that the Feds were about to authorize a nation wide non-discrete transponder code for gliders which was to be 0000 in lieu of the current VFR squawk of 1200. *Does anyone know anything about this or is this just another pipe dream? Sounds like NTSB recommendation A-08-12 that they sent to the FAA in this letter:http://www.ntsb.gov/Recs/letters/2008/A08_10_13.pdf The NTSB sent another letter at the same time to SSA:http://www.ntsb.gov/Recs/letters/2008/A08_14_15.pdf Likely the FAA will issue a notice of proposed rule making if it decides to ever follow up on A-08-12. Don't know how the coming ADS-B regs change the playfield with respect to gliders. If done, it will be as a 'document change' rather than formal NPRM. I don't know the current status, but if it's still moving ahead, target date is about five weeks. Frank Whiteley |
(USA) NTSB issues recommendations to the FAA and the SSA regarding transponder use in gliders | BT | Soaring | 78 | July 25th 08 06:26 PM |
(USA) NTSB issues recommendations to the FAA and the SSAregarding transponder use in gliders | Andy[_1_] | Soaring | 4 | May 22nd 08 05:16 PM |
Glider specific transponder codes | Bob Caldwell | Soaring | 12 | January 1st 07 05:18 AM |
Non-radar transponder codes | Michael | Instrument Flight Rules | 16 | February 13th 04 01:15 PM |
transponder codes | Guy Elden Jr. | Piloting | 1 | December 2nd 03 05:21 PM |
