Need a box shaped nosebowl
Old February 4th 10, 08:37 PM posted to rec.aviation.homebuilt
DonMorrisey
Default Need a box shaped nosebowl
I have an experimental Bushcaddy with a Lyc O-235. I also have the
standard ACS nosebowl for a lyc: http://www.aircraftspruce.com/catalog/appages/mc3a.php
My exhaust is a slightly modified Powerflow system. I have just
discovered I can't use my nosebowl because it is too rounded on the
bottom. The top is fine but the bottom is basically a crescent shape
from side to side. To accomodate the exhaust pipes and collector box
from the powerflow sytem I need something with a more rectangular or
boxy shape on the bottom. As an example a powerflow system will fit
in a Glastar Sportsman but their colw costs $1200. Any thoughts or
ideas??? Any kits you can think of that have such a shape to the
noebowl where perhaps I could buy that component??
Thanks. Don...
Old February 4th 10, 08:56 PM posted to rec.aviation.homebuilt
Bob Kuykendall
On Feb 4, 11:37*am, DonMorrisey wrote:
I have just discovered I can't use my nosebowl because it is too rounded on the
bottom...
Does that mean you can't use the nosebowl, or does it just mean you
can't use it without modifying it?
I'd suggest considering just cutting away the offending portions and
installing one or more blister fairings as necessary to clear the
revised exhaust system.
Old February 4th 10, 09:01 PM posted to rec.aviation.homebuilt
stol
bottom...
I agree with this idea.. For sure the cheapest way and you will get
exactly what you need.
IMHO.
Old February 4th 10, 09:30 PM posted to rec.aviation.homebuilt
DonMorrisey
Howdy,
Where would I find these "blister fairings"??
Although I have a feeling the interference is too significant to cure
with those. Just giving it the eyeball test both lower left and right
sides would have to be cut from the nosebowl and somehow a boxier
shape created. I have never worked with fiberglass so really don't
want to undertake that unless absoluely necessary. Thre must be some
boxy type nosebowls out there...although I've been searching and
haven't found one so far. Thanks
Old February 4th 10, 10:29 PM posted to rec.aviation.homebuilt
Bob Kuykendall
On Feb 4, 12:30*pm, DonMorrisey wrote:
Howdy,
Where would I find these "blister fairings"??...
You make them, using any of a wide variety of tools, materials, and
methods. My favorite method for small blisters is to constrain a nylon
or Visqueen membrane using double-sided tape and whatever else is
handy, inflate it with a few PSI of air, and lay up a few plies of
fiberglass over the resulting bulge. Fill to shape, file to fit, sand
smooth, and paint to hide.
...Although I have a feeling the interference is too significant to cure
with those. *Just giving it the eyeball test both lower left and right
shape created...
Are we just talking about just the fiberglass MC-3 nosebowl here, or
are we talking about the nosebowl and lower cowl? I am hard-pressed to
see how any exhaust on an O-235 would get very far outside the
envelope of just the MC-3 bowl.
I suspect that what you might mean is that the exhaust system gets
outside the envelope of a lower cowl that would be formed by a ruled
surface extended between the lower half of the MC-3 nosebowl and the
firewall. Is that it, or am I off-base on that guess?
Looking at this picture of your engine, I can see that the PowerFlow
system is indeed a pretty tall exhaust system:
http://www.donsbushcaddy.com/sitebui...ingO235L2C.jpg
That's one of the reasons I was never a particular fan of the
PowerFlow. Their installations seems sort of clunky, and they have
that huge muffler hanging way out in the breeze. I'm far more partial
to the Vetterman systems common on the RV-series airplanes:
http://vettermanexhaust.com/
Thanks, Bob K.
Old February 5th 10, 02:02 AM posted to rec.aviation.homebuilt
DonMorrisey
Bob,
The quote above is exactly the problem, hence the need for a more
rectangular nosebowl. So what I'm really after is direction on where
I may find a nosebowl that isn't crescent shaped on the bottom???
Thanks. Don...
cavelamb[_2_]
Howdy,
Well, the front part of the blister might be from a 2 or 3 liter Coke bottle.
I use Dr. Pepper bottles myself. The after part can be anything that makes
the shape you want. Wood, metal, plastic, bondo, plaster of paris, etc.
What's I'm recommending here is a male mold that the parts can be made on.
Richard Lamb
http://www.home.earthlink.net/~cavelamb/
"The clock of life is wound but once, and no man has the power
to tell just when the hands will stop, at late or early hour...
Now is the only time you own. Live, love, toil with a will.
Place no faith in time. For the clock may soon be still."
Old February 5th 10, 12:28 AM posted to rec.aviation.homebuilt
Scott[_7_]
Howdy,
Fiberglass work isn't terribly tough. It might be a bit itchy at times,
but it isn't THAT bad
U shaped wings Hul Tytus Home Built 15 January 8th 10 10:46 AM
Triangle shaped ice/frost on the wing - anyone seen this? Nathan Young Piloting 9 December 7th 05 11:15 PM
