Vertical stabilizers
Old February 18th 10, 09:02 PM posted to rec.aviation.piloting
Dallas
Default Vertical stabilizers
Speaking of below 250 knot aircraft, does it really matter much what shape
they make the vertical stabilizer?
They seem to come in all kinds of shapes... de Havilland favored
elliptical, Cessna favors a swept back trapezoid, Mooney swept forward...
etc.
Aerodynamically speaking, what difference does it's shape make? I guess
sweeping back creates a bit less drag than straight vertical. But other
than that, we're not generating induced drag because it's not generating
lift. It seems like area should be the only consideration.
Dallas
Old February 19th 10, 02:00 AM posted to rec.aviation.piloting
etc.
Aerodynamically speaking, what difference does it's shape make? *I guess
sweeping back creates a bit less drag than straight vertical. * But other
lift. *It seems like area should be the only consideration. *
Dallas
I don't know that sweep reduces drag. It just looks faster.
Sometimes it appears swept because it's tapered and the trailing edge
is vertical. And a tapered vertical tail can be made lighter and have
less "tip" drag. Cessna's swept tail supposedly helps hold the nose up
a little in a turn if the rudder is deflected, but it would be a
minimal contribution, I think.
The old rounded tails were easy to make with small steel tubing
and fabric; lots harder with sheet metal. Rounded shapes were popular
in those old days--just look at the cars of the '40s. Angular shapes
were popular in the '60s and '70s, just like the cars of the day, and
airplanes were angular, too. Which mostly means that style sells
airplanes more than functionality.
Dan
Old February 19th 10, 08:40 AM posted to rec.aviation.piloting
John Smith
I'm no aerodynamicist, so I can't offer hard numbers, just some thoughts:
As the stabilizer is a wing like any other wing, its shape will matter
as the shape of any wing.
Aerodynamics in coordinated flight is only part of the story.
Particularly spin recovery is crucial, which depends highly on the
airflow on the rudder, which in turn depends on a lot of things, e.g. on
the the shape of the horizontal stabilizer and the horizontal rudder
position.
Aesthetics certainly matters, too.
Old February 19th 10, 07:21 PM posted to rec.aviation.piloting
Robert M. Gary
etc.
Dallas
Obviously the Mooney design is faster.
Old February 20th 10, 12:46 AM posted to rec.aviation.piloting
Frank Stutzman[_3_]
I had one owner explain to me that the tail on the Mooney was indeed
faster as the tip vortices ended up comming off the bottom of the
vertical stablizer. The air down there was already churned up by
the fuselage and so less air was disturbed than otherwise would be.
Personally the fastest thing would be to get rid of the vertical stabilizer.
Hmmm, now what kind of a plane would do that....
Frank Stutzman
Bonanza N494B "Hula Girl"
Boise, ID
Old February 20th 10, 01:08 AM posted to rec.aviation.piloting
John Smith
Horten, for example: http://www.youtube.com/watch?v=GjXr5w3M4mc
Old February 20th 10, 03:15 AM posted to rec.aviation.piloting
Peter Dohm
"John Smith" wrote in message
stabilizer.
And, of course, the B2 Spirit: http://www.youtube.com/watch?v=IdbpMOWGYGk
Old February 21st 10, 07:22 AM posted to rec.aviation.piloting
Dallas
faster as the tip vortices ended up coming off the bottom of the
vertical stablizer.
But a vertical stabilizer is not going to generate a tip vortice.
(disclaimer: as far as I know)
The vortices are generated by unequal pressure on opposing sides of an
airfoil. A vertical stabilizer in coordinated flight would have equal
pressure on both sides of the surface, thus no vortice.
Dallas
Old February 23rd 10, 12:21 AM posted to rec.aviation.piloting
romeomike
Just askin', but is that always true? In a turn, even if coordinated, is
there not a force against the vertical stab causing it to act as a
keel
to help maintain lateral stability?
Old February 27th 10, 09:08 PM posted to rec.aviation.piloting
Dallas
there not a force against the vertical stab causing it to act as a keel
(Disclaimer: I don't claim to be an aeronautical engineer, but I like the
subject.)
To me, coordinated is coordinated. Sure, there are micro disruptions that
try to produce a yaw that the vertical stabilizer is called upon to resist,
after all, that's why it's there.
But, in a coordinated turn, the goal is to balance the pressure on both
sides of the stabilizer.
Have you ever seen those short strands of yarn some glider pilots tape to
the front of their canopies? The goal is to keep the strand straight down
the centerline during a turn which can only be accomplished if there is
equal airflow on either side of the hull.
Dallas
Vertical stabilizer wont come out (Asw-19) [email protected] Soaring 13 June 4th 09 12:45 AM
Vertical Card Compass? Bubba[_2_] Owning 10 April 2nd 07 03:31 PM
Vertical Card Compass? Bubba[_2_] Products 0 March 30th 07 06:58 PM
Vertical Card Compass Bubba[_2_] General Aviation 0 March 30th 07 06:56 PM
Vertical Card Compass? Bubba[_2_] Aviation Marketplace 0 March 30th 07 06:56 PM
