Typical metric stock for panel mounted instruments
Old March 4th 10, 02:24 PM posted to rec.aviation.soaring
Ken Kochanski (KK)
Default Typical metric stock for panel mounted instruments
Anybody know the size range of metric fasteners we typically use for
our panel mounted instruments ... for Dittle, Borgelt, etc ... I just
wanted to order some stock ... maybe 3 - 6 mm diameter ... 10 mm
long ... thanks.
KK
Old March 4th 10, 03:29 PM posted to rec.aviation.soaring
Peter Scholz[_2_]
long ... thanks.
KK
For standard European instruments we use 4mm screws:
M4 x 12mm
The holes in the panel and instruments usualy have 4,3mm
Peter Scholz
JE
Old March 4th 10, 03:32 PM posted to rec.aviation.soaring
Grider Pirate
On Mar 4, 6:24*am, "Ken Kochanski (KK)"
our panel mounted instruments *... for Dittle, Borgelt, etc ... I just
long ... thanks.
KK
4 x 20 is what the FSG-2T uses.
Old March 4th 10, 03:44 PM posted to rec.aviation.soaring
Grider Pirate
long ... thanks.
KK
Correction: As Peter Stated - 4 x 12mm is standard.
Old March 4th 10, 04:37 PM posted to rec.aviation.soaring
Bob Kuykendall
our panel mounted instruments...
I've found some few instruments, including, I seem to recall, the
Cambridge GPS-NAV display unit, use M3.5 threaded studs. I don't
remember the pitch, but I remember that finding screws of that size
was troublesome.
Old March 5th 10, 12:15 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
remember the pitch, but I remember that finding screws of that size was
troublesome.
M3.5 now seems to be the standard UK screw for electrical fittings (Wall
sockets, etc.), though possibly not all that useful for instrument
mounting, since they usually have countersunk slotted heads finished as
shiny metal.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old March 4th 10, 05:20 PM posted to rec.aviation.soaring
Bruce
long ... thanks.
KK
Generally M4x12 but some manufacturers who shall remain nameless to
avoid embarrassing the Americans use strange sizes.
If you can get them with a non-threaded shank then it needs to be chosen
to fit the panel thickness.
Cheers
Bruce
--- news://freenews.netfront.net/ - complaints: ---
Metric Instruments Roy Bourgeois Soaring 29 May 27th 13 01:53 PM
Anyone ever panel mounted a PCAS MRX? Matt Herron Jr. Soaring 11 April 3rd 09 08:01 PM
Panel mounted GPS on E-Bay. Tri-Pacer Aviation Marketplace 0 May 3rd 07 08:40 PM
Metric Instruments? AFSax Soaring 14 August 24th 05 02:52 PM
Panel mounted WindowsCE device tango4 Soaring 8 December 13th 03 06:20 AM
