WANTED SWEIZER GLIDER TOW HOOK FOR CESSNA 172
Old March 29th 10, 04:21 PM posted to rec.aviation.soaring
Rocket[_6_]
Default WANTED SWEIZER GLIDER TOW HOOK FOR CESSNA 172
I am looking for a Sweizer Tow Hook Kit to be used on a Cessna 172 for
towing Gliders, if anyone knows were to find one?
Old March 29th 10, 04:40 PM posted to rec.aviation.soaring
Darryl Ramm
Insert standard Schweizer tow release safety problems.
I think Tim at Wings and Wheels has Cessna 172 Tost tow hooks, given
that why wold anybody fit a Schweizer hook?
Darryl
Old March 31st 10, 06:50 PM posted to rec.aviation.soaring
Ed
On Mon, 29 Mar 2010 08:21:15 -0700 (PDT), Rocket
You might look up the McFarlane hook on the internet.
Old March 31st 10, 07:10 PM posted to rec.aviation.soaring
Ed
I also just noticed that Aircraft Spruce sells a hook, but they ain't
cheap. Also McFarlane sold their hook to an outfit in Olanthe Kansas.
Old March 31st 10, 07:24 PM posted to rec.aviation.soaring
Darryl Ramm
And the Aircraft Spruce tow hook I believe is manufactured by Wings
Unlimited http://www.wingsunlimitedtowhooks.com/products.html
Neither the Wings Unlimtied or McFarlane tow hooks have an STC AFAIK.
So you are in the same situation needing to do a 337/field approval
for any of these as you would for a Tost. So why would somebody pick
one of these over a Tost? (that's a question not a sarcastic comment).
Darryl
Old March 31st 10, 08:09 PM posted to rec.aviation.soaring
lanebush
Unlimitedhttp://www.wingsunlimitedtowhooks.com/products.html
Darryl
Your support for TOST is admirable. How about getting them to develop
an STC the next time you guys have a company meeting.
XF
Old March 31st 10, 08:58 PM posted to rec.aviation.soaring
Darryl Ramm
Darryl
Your support for TOST is admirable. *How about getting them to develop
XF
Ah you lost me there.
Somebody is asking for a particular type of tow hook. I point out they
are dangerous vs. a modern alternative like a Tost. Somebody else
points out other options (lets discount the found objects on ebay). I
provide more details and a link. None of any of the ones we are
talking about have an STC AFAIK. I am sure many people would like a
modern safe tow-hook option with STC'ed for popular tow aircraft. If
the lack of an STC is a problem for you then you can follow up with
the parts manufactures/reps (Tim Mara for Tost). But given the market
size/demand, I suspect it is awfully unlikely any manufacturer is
going to want to STC a tow hook for a Cessna 172. I am pretty sure
people are installing Tost tow hooks with a 337. If you have problems
maybe somebody who has done the paperwork before (with the same or a
different FSDO) can help you. If a FSDO is giving you problems for a
Tost then presumably the FSDO is going to give you a problem for all
the other available options now as well?
The other non-Tost releases mentioned claim to have improved release
under high load angles than the original Schweitzer. I believe the
McFarlane and the Wings Unlimited tow releases are the same item/
design, in which case I understand they were designed with knowledge
of the problems with the Schweitzer releases. But again they are not
STC'ed. I'm not necessarily a fan of the rubber block spring based
design, but maybe that is better in dirty/dusty situations than a
Tost? Is the attraction just they are cheaper than a Tost? Is the
attraction wanting to use the large Schweitzer tow rings at a club/
FBO? Or are people just instinctively asking for a "Schweitzer
release" because that is what they think tow planes have?
Darryl
Old February 5th 14, 02:41 PM posted to rec.aviation.soaring
On Wednesday, 31 March 2010 21:58:15 UTC+2, darrylr wrote:
On Mar 31, 12:09*pm, lanebush wrote: On Mar 31, 2:24*pm, Darryl Ramm wrote: On Mar 31, 11:10*am, Ed wrote: On Mon, 29 Mar 2010 08:21:15 -0700 (PDT), Rocket wrote: I am looking for a Sweizer Tow Hook Kit to be used on a Cessna 172 for towing Gliders, if anyone knows were to find one? I also just noticed that Aircraft Spruce sells a hook, but they ain't cheap. Also McFarlane sold their hook to an outfit in Olanthe Kansas. And the Aircraft Spruce tow hook I believe is manufactured by Wings Unlimitedhttp://www.wingsunlimitedtowhooks.com/products.html Neither the Wings Unlimtied or McFarlane tow hooks have an STC AFAIK. So you are in the same situation needing to do a 337/field approval for any of these as you would for a Tost. So why would somebody pick one of these over a Tost? (that's a question not a sarcastic comment). Darryl Your support for TOST is admirable. *How about getting them to develop an STC the next time you guys have a company meeting. XFAh you lost me there.Somebody is asking for a particular type of tow hook. I point out they are dangerous vs. a modern alternative like a Tost. Somebody else points out other options (lets discount the found objects on ebay). I provide more details and a link. None of any of the ones we are talking about have an STC AFAIK. I am sure many people would like a modern safe tow-hook option with STC'ed for popular tow aircraft. If the lack of an STC is a problem for you then you can follow up with the parts manufactures/reps (Tim Mara for Tost). But given the market size/demand, I suspect it is awfully unlikely any manufacturer is going to want to STC a tow hook for a Cessna 172. I am pretty sure people are installing Tost tow hooks with a 337. If you have problems maybe somebody who has done the paperwork before (with the same or a different FSDO) can help you. If a FSDO is giving you problems for a Tost then presumably the FSDO is going to give you a problem for all the other available options now as well?The other non-Tost releases mentioned claim to have improved release under high load angles than the original Schweitzer. I believe the McFarlane and the Wings Unlimited tow releases are the same item/ design, in which case I understand they were designed with knowledge of the problems with the Schweitzer releases. But again they are not STC'ed. I'm not necessarily a fan of the rubber block spring based design, but maybe that is better in dirty/dusty situations than a Tost? Is the attraction just they are cheaper than a Tost? Is the attraction wanting to use the large Schweitzer tow rings at a club/ FBO? Or are people just instinctively asking for a "Schweitzer release" because that is what they think tow planes have?Darryl
Hi Darry,
do you know by any chance whether or not since you have communicated all above, there has been any change it the legislation and TOST or any other hooks are now approved by either FAA or EASA on Cessna 172N or FR Cessna 172N?
Thank you
Regards
Juraj
Old March 31st 10, 11:58 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
A Schweizer tow hook and smoke system (I didn't know Schweizer made
smoke systems! :-) ) just showed up on Barnstormers.
Suppose the smoke system is for the glider, or the towplane?
Steve
Old April 14th 11, 04:53 PM
usmcshooter usmcshooter is offline
Junior Member
First recorded activity by AviationBanter: Apr 2011
Go to eBay and search for Schweizer...I listed one yesterday. Blue Skies.
Tow Hook on Cessna 180 - Update Stuart Grant Soaring 13 April 10th 20 10:48 AM
Cessna 185 with a Tost hook? Nimbob Soaring 1 September 29th 09 12:43 PM
Cessna 150/150 Tow hook Ed Byars Soaring 5 July 14th 09 11:14 PM
Glider Wanted: LS-4 [email protected] Soaring 0 February 25th 05 08:13 PM
Tow Hook on Cessna 180? Stuart Grant Soaring 3 October 2nd 03 12:50 AM
