Intake plenum
I'm thinking about making a carb. heat plenum for my plane out of
fiberglass ( epoxy.) I had done it once for my Quickie many years ago because that's what what the plans said to do. But that was a very small plenum. Due to space constraints, it would be very easy to make it out of fiberglass for my new project ( 120 h.p.) but I'm wondering if the carb heat would be too hot for the fiberglass. I will make it out of aluminum if I have to, but it would be harder to do. Do you think the fiberglass would work? Thanks Neal |
Intake plenum
On Sat, 3 Apr 2010 12:52:03 -0700 (PDT), Neal Fulco
wrote: I'm thinking about making a carb. heat plenum for my plane out of fiberglass ( epoxy.) I had done it once for my Quickie many years ago because that's what what the plans said to do. But that was a very small plenum. Due to space constraints, it would be very easy to make it out of fiberglass for my new project ( 120 h.p.) but I'm wondering if the carb heat would be too hot for the fiberglass. I will make it out of aluminum if I have to, but it would be harder to do. Do you think the fiberglass would work? Thanks Neal Nope. Fiberglass (unless you are getting ito really exotic resins) won't handle the heat. |
Intake plenum
On Sat, 03 Apr 2010 21:54:40 -0500, cavelamb ""cavelamb\"@ X
earthlink.net" wrote: On 4/3/2010 8:28 PM, wrote: On Sat, 3 Apr 2010 12:52:03 -0700 (PDT), Neal wrote: I'm thinking about making a carb. heat plenum for my plane out of fiberglass ( epoxy.) I had done it once for my Quickie many years ago because that's what what the plans said to do. But that was a very small plenum. Due to space constraints, it would be very easy to make it out of fiberglass for my new project ( 120 h.p.) but I'm wondering if the carb heat would be too hot for the fiberglass. I will make it out of aluminum if I have to, but it would be harder to do. Do you think the fiberglass would work? Thanks Neal Nope. Fiberglass (unless you are getting ito really exotic resins) won't handle the heat. 90 degrees above ambient? 200 max? That is the minimum required Can often be a lot hotter than that. Only isophthalic resin rated for 210F and Vynylester rated at 241F would even be close. None of the common epoxies are rated for that temperature. You would need a novolac based epoxy (special high temperature epoxy resin) |
Intake plenum
Intake plenum
On Wed, 07 Apr 2010 19:56:31 -0400, Ernest Christley
wrote: wrote: 90 degrees above ambient? 200 max? That is the minimum required Can often be a lot hotter than that. Only isophthalic resin rated for 210F and Vynylester rated at 241F would even be close. None of the common epoxies are rated for that temperature. You would need a novolac based epoxy (special high temperature epoxy resin) Thin some JBWeld. Squish it into the glass between sheets of cellophane with a large socket or piece of pipe. A BADGE Resin (Bisphenol A DiGlycidyl Ether) resin is another one of the special high temperature epoxy resins. Good to about 500 |
Intake plenum
On Apr 3, 12:52*pm, Neal Fulco wrote:
I'm thinking about making a carb. heat plenum for my plane out of fiberglass ( epoxy.) * I had done it once for my Quickie many years ago because that's what what the plans said to do. *But that was a very small plenum. *Due to space constraints, it would be very easy to make it out of fiberglass for my new project ( 120 h.p.) but I'm wondering if the carb heat would be too hot for the fiberglass. *I will make it out of aluminum if I have to, but it would be harder to do. *Do you think the fiberglass would work? *Thanks Neal On my Glasair, I have a composite plenum on the intake side of the carb with a flapper valve to direct air. The plenum is actually part of the cowl with a rubber gasket next to the carb. Don't know what was used to make the part, but it's attached to the cowl with vinylester. Seems to work OK. Ed |
Similar Threads | ||||
intake air filter choices | Dick | Home Built | 8 | January 19th 07 03:06 PM |
Flexible air intake hose | abripl | Home Built | 10 | July 21st 06 04:11 AM |
Blackbird intake | Speed | Piloting | 5 | May 25th 05 07:52 PM |
Q. about Eurofighter intake | Alistair Gunn | Military Aviation | 1 | August 20th 04 06:58 AM |
Lycoming intake preheater | Dale Larsen | Home Built | 5 | June 6th 04 10:32 PM |
