Polarized Sun Glasses and PDAs
Old April 5th 10, 01:47 AM posted to rec.aviation.soaring
Michael Reid
Default Polarized Sun Glasses and PDAs
All,
I'm picking out a new pair of sunglasses for soaring and I had a few
questions.
Has anyone had problems seeing their PDA while flying with Polarized
lenses?
Is anyone flying with Oakley black iridium polarized lenses?
Thanks,
Michael 'BK'
Old April 5th 10, 01:55 AM posted to rec.aviation.soaring
ZZ
Perhaps risky, financially. My scree, an older IPAQ, is almost invisible
with a polarized lens.
Paul
ZZ
On 4/4/2010 5:47 PM, Michael Reid wrote:
All,
questions.
lenses?
Thanks,
Michael 'BK'
Old April 5th 10, 02:21 AM posted to rec.aviation.soaring
Bob Kuykendall
On Apr 4, 5:47*pm, Michael Reid wrote:
All,
questions.
lenses?
I used to fly with polarized lenses. What I found is that you have to
be careful that the polarizations of the screen and the lenses didn't
interfere. For the LCD devices I flew with at the time (GPS-NAV
screen, digital battery monitor), I pretty much got lucky and they
worked fine. But I noticed that with some other devices, for example
my FRS walkie-talkies, I had to hold the device sideways to read the
display.
Bottom line, I'd suggest taking the PDA with you when you try out the
sunglasses.
Thanks, Bob K.
Old April 5th 10, 03:20 AM posted to rec.aviation.soaring
Mike[_8_]
On Apr 4, 6:47*pm, Michael Reid wrote:
All,
questions.
lenses?
Thanks,
Michael 'BK'
Using an Ipaq 39xx and polarized Eagle Eyes I can see the screen fine.
Gets rid of the glare. The glasses do not have a dark tint.
What Bob said.
Old April 5th 10, 07:26 AM posted to rec.aviation.soaring
noel.wade
Also, on a more general note:
Some canopy materials have bad interactions with polarized lenses.
When I was training in a Diamond DA-20 I made the mistake of wearing
polarized lenses once and was treated to a wonderful changing moire
pattern all over the canopy, as I turned my head - ugh!
So check your canopy as well as your PDA, before you drop a lot of
dough on fancy lenses!
--Noel
Old April 5th 10, 09:27 AM posted to rec.aviation.soaring
Jip
"noel.wade" wrote in message
--Noel
And last but not least, with polarized lenses reflections are suppressed.
That means that you easely miss a sun reflection in the cannopy of an other
glider.
Missing other traffic means an increased risk of collission.
No polarized glasses for me in the cokpit!!
Old April 5th 10, 12:34 PM posted to rec.aviation.soaring
Tony[_5_]
and you are banking that the next gee whiz flash bang gismo to come
down the line is not going to have a polarized screen that interferes
with your sunglasses. I picked up a pair of prescription ray ban's a
few weeks ago and decided to make life easy and got non polarized
lenses.
Old April 5th 10, 06:28 PM posted to rec.aviation.soaring
Greg Arnold[_3_]
--Noel
glider.
It is possible that you might miss a sun reflection on a glider.
However, polarized gliders make the sky much darker, so in general they
make other gliders stand out. They also help with the visibility of
distant clouds.
Old April 7th 10, 06:13 AM posted to rec.aviation.soaring
Darryl Ramm
*wrote in message
--Noel
glider.
make other gliders stand out. *They also help with the visibility of
distant clouds.
I wear a blue blocking polarized lens. The combination of blue
blocking and polarizing significantly darkens large parts of the sky
makes white gliders stand out and increases cloud contrast greatly,
making wisps and haze domes visible as well.
The downside is color shifts that may affect things like field choices
in landouts in some situations, but you get used to this quickly.
Moire patterns from stress in canopy can be a problem sometimes but
with all the Meccaplex canopies I've flown with I have never seen a
problem with this. One particular side window in my Tundra is another
issue. Some powered aircraft windows with complex coumpount curvatures
may be worse than glider canopies.
Having a really good pair of sunglasses also cuts down on eye stain
and makes you more likely to see other aircraft. The old chestnut
about speculative reflection and it's importance in detecting other
aircraft keeps coming up, the scientific report often cited for this
is far from convincing.
Darryl
Old April 6th 10, 10:24 PM posted to rec.aviation.soaring
Derek C
On 5 Apr, 01:47, Michael Reid wrote:
All,
questions.
lenses?
Thanks,
Michael 'BK'
You should be able to see your PDA wearing polarized sunglasses, but
you may need to rotate your head though 90 degrees to read what's on
the screen! Plain tints are probably better. Yellow to brown tints
seem best at cutting through haze and highlighting clouds.
Derek C
Seeking 2 Compaq Aero 1550 PDAs Paul Remde Soaring 0 November 13th 09 09:26 PM
Non-polarized blue-blocker (orange) clip-ons/flip-ups? Frank[_1_] Soaring 3 September 28th 07 05:30 PM
Carrying glasses? Emily Piloting 58 September 13th 06 12:27 AM
Polarized Instrument Display Rick Soaring 14 May 14th 06 02:22 PM
More on Sunreader glasses Eric Greenwell Soaring 0 September 22nd 03 11:38 PM
