The Oudies Have Arrived
Old April 14th 10, 05:28 PM posted to rec.aviation.soaring
Paul Remde
Default The Oudies Have Arrived
Hi,
I just received my first batch of Naviter Oudies. They are very nice!
There are many small software tweaks that make them easier to use. For
example, when selecting the comm port (the default is the internal GPS) the
selection list includes text which clarifies how each port is used (COM 1:
Internal, COM 4: Serial, etc.).
http://www.cumulus-soaring.com/seeyou.htm
All 30 of the units received today have already been sold, but many more are
on the way to me which should arrive next week. They have not all been sold
yet.
The supplied serial cable works well with a 302 or GPS-NAV but has nuts on
the connector, so a straight through cable is required to connect it to a
GPS-NAV. I have them in stock (see link below). The nuts can be removed,
but then there is no simple way to secure it to the GPS-NAV. I feel that it
is important that a secure connection is made because you wouldn't want it
to fall off in flight. The 12V power leads must be powered for the cable to
work. It supplies 5V power to the Oudie and also has a built-in RS-232
voltage level converter. I recommend this cable for use with the Cambridge
GPS-NAV.
http://www.cumulus-soaring.com/cai_prices.htm#HA-349
For the Cambridge 302 and other devices I recommend the Oudie-PS5a-1 cable
because they pass 5V power from the 302 to the Oudie. The 302 seems to
provide enough power for the Oudie as long as the Oudie is fully charged or
nearly so.
http://www.cumulus-soaring.com/goddard.htm#Oudie-PS5a-1
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
Old April 14th 10, 06:47 PM posted to rec.aviation.soaring
Richard[_9_]
On Apr 14, 9:28*am, "Paul Remde" wrote:
Hi,
I just received my first batch of Naviter Oudies. *They are very nice!
There are many small software tweaks that make them easier to use. *For
Internal, COM 4: Serial, etc.).http://www.cumulus-soaring.com/seeyou.htm
on the way to me which should arrive next week. *They have not all been sold
yet.
GPS-NAV. *I have them in stock (see link below). *The nuts can be removed,
but then there is no simple way to secure it to the GPS-NAV. *I feel that it
to fall off in flight. *The 12V power leads must be powered for the cable to
work. *It supplies 5V power to the Oudie and also has a built-in RS-232
voltage level converter. *I recommend this cable for use with the Cambridge
GPS-NAV.http://www.cumulus-soaring.com/cai_prices.htm#HA-349
because they pass 5V power from the 302 to the Oudie. *The 302 seems to
nearly so.http://www.cumulus-soaring.com/goddard.htm#Oudie-PS5a-1
Best Regards,
Paul Remde
Craggy Aero, LLC has Oudies available & Wings & Wheels I believe also
have Oudies Available.
Craggy Aero provides no charge support. Almost all the time ,
including evenings, weekends and holidays.
Richard
www.craggyaero.com
Old April 14th 10, 08:02 PM posted to rec.aviation.soaring
Mike[_8_]
Hi,
yet.
Hi Richard,
Any opinion on the readability compared to the current crop of PNA'a
in direct sunlight?
Thanks,
Mike
Best Regards,
Paul Remde
Craggy Aero provides no charge support. *Almost all the time ,
Richardwww.craggyaero.com
Old April 14th 10, 09:30 PM posted to rec.aviation.soaring
Richard[_9_]
Hi,
yet.
Hi Richard,
Any opinion on the readability compared to the current crop of *PNA'a
in direct sunlight?
Thanks,
Mike
Best Regards,
Paul Remde
Richardwww.craggyaero.com- Hide quoted text -
- Show quoted text -- Hide quoted text -
I think that it is more readable because it is larger than the current
PNA devices. But compared to the Craggy Aero Ultimate not.
http://www.craggyaero.com/ultimate.htm
Richard
www.craggyaero.com
Old April 14th 10, 09:39 PM posted to rec.aviation.soaring
Paul Remde
Hi Mike,
I brought my Oudie out into bright sunlight today. I didn't have my iPAQ
310 with me at the time. The Oudie was OK in sunlight. Like all PDAs and
PNAs it is not great in sunlight, but it seemed a lot better than my iPAQ
hx4700. It is nothing like a ClearNav in regard to sunlight readability,
but it costs a lot less than a ClearNav.
My iPAQ 310 is for sale for $195.
Best Regards,
Paul Remde
"Mike" wrote in message
On Apr 14, 11:47 am, Richard wrote:
On Apr 14, 9:28 am, "Paul Remde" wrote:
Hi,
1:
are
sold
yet.
on
a
it
it
to
Cambridge
cable
or
Hi Richard,
in direct sunlight?
Thanks,
Mike
Best Regards,
Paul Remde
Old April 14th 10, 07:53 PM posted to rec.aviation.soaring
Bob 7U
Hi Paul,
Does it run the Cambridge flight download utility?
I know it will have ConnectMe but I was curious about running the
Cambridge software.
Bob 7U
On Apr 14, 12:28*pm, "Paul Remde" wrote:
Hi,
yet.
Best Regards,
Paul Remde
Old April 14th 10, 09:37 PM posted to rec.aviation.soaring
Paul Remde
Hi Bob,
I don't know for certain. The unit is setup to be specific to running
Mobile and ConnectMe. I don't see an easy way to access Windows File
Explorer to run the Cambridge 300 Utility and I don't know whether File
Explorer is even installed in the unit. It is possible to copy files to the
Oudie, but I can't see a way to run them.
SeeYou ConnectMe will work fine, except that it can't check the flight log
security after download.
Best Regards,
Paul Remde
"Bob 7U" wrote in message
Hi Paul,
Cambridge software.
Bob 7U
On Apr 14, 12:28 pm, "Paul Remde" wrote:
Hi,
are
sold
yet.
it
to
or
Best Regards,
Paul Remde
Old April 14th 10, 09:48 PM posted to rec.aviation.soaring
Richard[_9_]
On Apr 14, 1:37*pm, "Paul Remde" wrote:
Hi Bob,
I don't know for certain. *The unit is setup to be specific to running
Mobile and ConnectMe. *I don't see an easy way to access Windows File
Explorer is even installed in the unit. *It is possible to copy files to the
Best Regards,
Paul Remde
Hi Paul,
Cambridge software.
Bob 7U
Hi,
are
sold
yet.
it
to
or
Best Regards,
Paul Remde
Cumulus Soaring, Inc.- Hide quoted text -
Bob,
To run the CAI utility the correct nav path would have to be set and
certain .dlls would need to be auto installed. This is something we
would probably have to ask SeeYou to do.
I have the Ultimate running the CAI Utility, but I have much more
access to the operating system and the registry on the Ultimate.
Richard
www.craggyaero.com
Old April 14th 10, 10:03 PM posted to rec.aviation.soaring
Bob 7U
Thanks Paul, thanks Richard,
I'm sure you will playing with these units in the days to come and
reporting back.
ConnectMe works a charm with the only snag being that it produces a
'Grey' score line on the OLC.
Maybe this is something the OLC people can fix or Naviter might look
at including the ability to run the Cambridge utility.
Bob 7U
Hi Bob,
Best Regards,
Paul Remde
Hi Paul,
Cambridge software.
Bob 7U
Hi,
are
sold
yet.
it
to
or
Best Regards,
Paul Remde
Bob,
certain .dlls would need to be auto installed. *This is something we
would probably *have to ask SeeYou *to do.
Old April 14th 10, 10:33 PM posted to rec.aviation.soaring
Paul Remde
Hi Bob,
I think you are doing something wrong in the flight log download. A flight
log downloaded by ConnectMe is exactly the same as a flight log downloaded
by the 300 Utility. I suspect that you are submitting a flight log
generated by the SeeYou Mobile "PDA logger".
Best Regards,
Paul Remde
reporting back.
Bob 7U
On Apr 14, 4:48 pm, Richard wrote:
On Apr 14, 1:37 pm, "Paul Remde" wrote:
Hi Bob,
log
Best Regards,
Paul Remde
Hi Paul,
Cambridge software.
Bob 7U
Hi,
GPS)
(COM 1:
more
are
sold
yet.
nuts on
to a
removed,
that
it
want it
cable
to
Cambridge
cable
charged
or
Best Regards,
Paul Remde
Bob,
Before Help Arrived Mitchell Holman Aviation Photos 15 January 18th 09 11:36 AM
first P-3C CUP Orion arrived at Valkenburg Marco P.J. Borst Military Aviation 1 May 27th 04 09:42 PM
first P-3C CUP Orion arrived at Valkenburg Marco P.J. Borst Naval Aviation 1 May 27th 04 09:42 PM
(long) WxWorx arrived... Tom S. Instrument Flight Rules 1 September 10th 03 12:37 AM
(long) WxWorx arrived... Tom S. Piloting 0 September 9th 03 04:54 PM
