Did a simulated power out emergency today, and
killed the throttle near 4500 ft. Established my best rate of glide (70mph) and as I found my most viable field to land in, we were going over the procedures for such an occasion. Eventually I reached a grassy field that actually looked decent, surface and all. As I set up an attitude and realistic entry we had really lost altitude, and now, I gave it full throttle. Sputter, sputter. We were dropping. My CFI's hands were suddenly moving fast as a blur. It seemed like a long time, and I just stayed on my landing course fully prepared to set it in the field, and then Broommm! the engine revved up and it was climb baby climb! Now that's one I'm not gonna forget! --- Mark |
On May 7, 11:41*am, Mark wrote:
Did a simulated power out emergency today, and killed the throttle near 4500 ft. *Established my best rate of glide (70mph) and as I found my most viable field to land in, we were going over the procedures for such an occasion. Eventually I reached a grassy field that actually looked decent, surface and all. As I set up an attitude and realistic entry we had really lost altitude, and now, I gave it full throttle. *Sputter, sputter. We were dropping. My CFI's hands were suddenly moving fast as a blur. *It seemed like a long time, and I just stayed on my landing course fully prepared to set it in the field, and then Broommm! the engine revved up and it was climb baby climb! Now that's one I'm not gonna forget! Did you forget to clear the engine every 1000'? Cheers |
On May 7, 7:09*am, "Flaps_50!" wrote:
On May 7, 11:41*am, Mark wrote: Did a simulated power out emergency today, and killed the throttle near 4500 ft. *Established my best rate of glide (70mph) and as I found my most viable field to land in, we were going over the procedures for such an occasion. Eventually I reached a grassy field that actually looked decent, surface and all. As I set up an attitude and realistic entry we had really lost altitude, and now, I gave it full throttle. *Sputter, sputter. We were dropping. My CFI's hands were suddenly moving fast as a blur. *It seemed like a long time, and I just stayed on my landing course fully prepared to set it in the field, and then Broommm! the engine revved up and it was climb baby climb! Now that's one I'm not gonna forget! Did you forget to clear the engine every 1000'? Cheers- Hide quoted text - - Show quoted text - Had carb heat on, as rpms were below the arc. But no, I wasn't instructed to input throttle during the descent. Is that what you mean? thanks, Mark |
![]() "Mark" wrote in message ... Had carb heat on, as rpms were below the arc. But no, I wasn't instructed to input throttle during the descent. Is that what you mean? Your CFI should have been doing that. All of mine did, every time. Prevents such occurrences. |
On May 7, 10:06*am, "Ęslop" wrote:
"Mark" wrote in message ... Had carb heat on, as rpms were below the arc. But no, I wasn't instructed to input throttle during the descent. Is that what you mean? Your CFI should have been doing that. All of mine did, every time. Prevents such occurrences. I'm speechless. We have a choice of appx.7 cfi's to choose from at this academy. I'll try another. If the head instructor knew, this one would be fired. In hindsight, the gravity of what happened yesterday is serious. I barely had time to pull out. On the way back up I was compelled to keep scanning that field. It looked possible but there was something barely visible running across it. Now I'm thinking it was a ditch. --- Mark |
On May 7, 10:06*am, "Ęslop" wrote: "Mark" wrote in message ... Had carb heat on, as rpms were below the arc. But no, I wasn't instructed to input throttle during the descent. Is that what you mean? Your CFI should have been doing that. All of mine did, every time. Prevents such occurrences. I'm speechless. We have a choice of appx.7 cfi's to choose from at this academy. *I'll try another. If the head instructor knew, this one would be fired. In hindsight, the gravity of what happened yesterday is serious. I barely had time to pull out. On the way back up I was compelled to keep scanning that field. It looked possible but there was something barely visible running across it. Now I'm thinking it was a ditch. It would be useful to simply ask your CFI what happened. "Hands flying all over" doesn't cut it, there are only a few things to do. My guess would have been carb ice: If you were coming down from 4500 to say 1000 at 500 fpm that would be 6 to 8 minutes of throttle closed gliding. If the RH was high I am not at all sure I'd expect carb heat to keep ahead of the icing for that length of time, but others more expert with those airplanes may have a different opinion. My Mooney has an injected engine, but when coming down from altitude it is very rarely with a closed throttle, and cowl flaps are in play too, engines are to be babied and thermal shock is a bad thing. For that matter, the time the throttle is moved the fastest, and even then it's not very fast, is when I decide to go around. Here's a question for the aviators among us. How long do you take to go from idle to take-off power when you're "position and hold" to "cleared for immediate"? As I sit here and think about it, I'm guessing it takes me a slow count to 5 to get to full throttle, and that is assuming RPMs follow throttle position pretty closely. .. .. |
On Fri, 7 May 2010 08:41:40 -0700 (PDT), Mark wrote:
On May 7, 10:06*am, "Ęslop" wrote: "Mark" wrote in message ... Had carb heat on, as rpms were below the arc. But no, I wasn't instructed to input throttle during the descent. Is that what you mean? Your CFI should have been doing that. All of mine did, every time. Prevents such occurrences. I'm speechless. And clueless, you haven't the first idea how to choose a competent CFI, Mark(ie). /lol/ -- A fireside chat not with Ari! http://tr.im/holj Motto: Live To Spooge It! |
Gear Up, pt 7 - su27 mishap 1.jpg (1/1) | Mitchell Holman | Aviation Photos | 4 | April 21st 07 10:16 AM |
Gear Up, pt 7 - su27 mishap 3.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | April 20th 07 02:21 PM |
Gear Up, pt 7 - su27 mishap 2.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | April 20th 07 02:21 PM |
AT 6 mishap in dallas.. | Dave S | Piloting | 4 | June 24th 05 09:07 PM |
Quantico mishap? | Paul Michael Brown | Naval Aviation | 22 | October 5th 04 02:47 AM |
