Where to post questions?
Old July 12th 10, 07:34 PM
WhenTurtlesFly WhenTurtlesFly is offline
Junior Member
First recorded activity by AviationBanter: Jul 2010
Default Where to post questions?
'Cause I have one- Filed to cruise at 8500. Two GPS's (old simple one in the plane and my new portable) say I'm at 8500, but pressure altimeter says I'm at 8000. I of course set my altimeter to departing airport elevation, which should calibrate it to current pressure and nonstandard temperature, right? Do I...
* fly what seems to be accurate and correct readouts on both of my GPS's? Then risk my altimeter being off and my Mode C reporting incorrectly...
* fly GPS's and adjust altimeter to read the GPS altitude, even though the altimeter setting is not what is reported?
* fly the altimeter set at reported conditions, have my Mode C report accurately, but run the risk of being off VFR altitude?
Thanks
Old July 12th 10, 09:19 PM posted to rec.aviation.piloting
Jim Logajan
incorrectly...
U.S. FAR 91.121(a) implies flying by reference to an altimeter whose output
can be adjusted from station readings or actual airport elevation. I doubt
either of your GPS's allow such adjustment settings, so you probably can't
fly VFR cruising altitudes by reference to them.
Regulations do not appear to allow setting an altimeter to anything other
than a barometric altimeter setting from a station within 100 NM, other
appropriate station, or to actual elevation of a departure airport.
Unless your altimeter is way out of calibration (in which case you probably
shouldn't be flying that airplane until the problem is corrected,) then
everyone else near your aircraft should in theory be flying with similar
offsetting temperature and pressure differences, so long as they are all
"off" in the same way.
(Unfortunately it isn't hard to think up cases where the above fails to
work out.)
Old July 12th 10, 10:43 PM posted to rec.aviation.piloting
Mxsmanic
WhenTurtlesFly writes:
incorrectly...
No. The altimeter is more accurate than the GPS units. The fact that the two
GPS units agree simply means that they are both subject to the same error when
operating in the same place at the same time.
Yes. Fly the altimeter. The risk of being 500 feet off is virtually nil if
you've set the altimeter correctly to begin with.
GPS provides very poor vertical accuracy compared to a barometric altimeter.
GPS is designed for lateral accuracy rather than vertical accuracy.
Old July 13th 10, 12:12 AM posted to rec.aviation.piloting
Jim Logajan
incorrectly...
the two GPS units agree simply means that they are both subject to the
same error when operating in the same place at the same time.
His new portable would almost certainly use WAAS when available and would
not be off by 500 ft.
WAAS is accurate to 25 ft vertically 95% of the time. Standard aneroid
altimeter have no adjustment for changes from non-standard temperature. A
temp difference of ~4 degrees Celsius from standard atmosphere would show a
500 ft difference.
nil if you've set the altimeter correctly to begin with.
altimeter. GPS is designed for lateral accuracy rather than vertical
accuracy.
Which is why WAAS was developed.
Old July 13th 10, 01:54 AM posted to rec.aviation.piloting
Mxsmanic
Jim Logajan writes:
WAAS is independent of GPS. It's one of many GPS augmentation schemes.
500 ft difference.
So if you depend on your WAAS GPS for altitude, you might collide with traffic
that is depending on barometric altitude.
WAAS was developed to improve GPS accuracy overall, not to allow GPS to
replace traditional barometric altimeters.
Old July 13th 10, 02:26 AM posted to rec.aviation.piloting
Jim Logajan
Mxsmanic wrote:
Jim Logajan writes:
would not be off by 500 ft.
WAAS cannot simultaneously be independent of GPS and an augmentation of it.
Only the second of your two quoted sentences is accurate in any useful way.
While your conclusion that he should use the altimeter set to the nearest
station setting was correct, the rationale leading up to it was based on an
invalid premise.
Old July 13th 10, 02:24 AM posted to rec.aviation.piloting
Don Poitras
incorrectly...
500 ft difference.
The temperature correction is affected by height. The rot is 4 feet per
thousand feet for each degree C of difference from standard. A 500 ft
difference at 4 degrees would only be true at 30,000 feet. So at my 250
foot high airport, it would have to be -35C to get my altimeter to be
50 feet high. I don't think I've ever seen it more than 20 feet off when
set to the broadcast setting on the ground.
accuracy.
Don Poitras
Old July 13th 10, 07:07 AM posted to rec.aviation.piloting
Jim Logajan
"Stephen!" wrote:
Jim Logajan wrote in
It could very well be 'off' by that much quite easily. Keep in mind
that the earth is neither smooth nor a sphere. Depending on where you
are on the theoretical sphere that the GPS uses for its calculations,
its altitude calculation could be off from actual AGL by quite a bit.
I saw that quite frequently on Guam where I would be in a boat and the
GPS would swear we were a couple hundred feet below sea level.
I don't believe WAAS is yet available in Guam.
Old July 13th 10, 12:32 AM posted to rec.aviation.piloting
Babbling nonsense when talking about aviation GPS.
Jim Pennino
Remove .spam.sux to reply.
Old July 13th 10, 01:15 AM posted to rec.aviation.piloting
a[_3_]
On Jul 12, 1:34*pm, WhenTurtlesFly wrote:
'Cause I have one- *Filed to cruise at 8500. *Two GPS's (old simple one
altimeter says I'm at 8000. *I of course set my altimeter to departing
nonstandard temperature, right? *Do I...
GPS's? *Then risk my altimeter being off and my Mode C reporting
incorrectly...
Thanks
WhenTurtlesFly
Everyone in the airspace should be flying with reference to the
(correctly set) altimeter and you should too. The fact that you may
know your exact altitude by other means is not relevant when you're
cruising en route to somewhere -- the idea behind using the same
reference instrument is traffic avoidance.
You'll have a measure of the altimeter's accuracy when you're at an
airport and set the altimeter to the local barometric pressure. As
best I remember, the altimeter should be within 75 feet of the
reported field elevation -- be sure you know the field elevation where
your airplane is, airports are mostly not level, and the minor changes
in field elevation can eat into your error budget.
First post birdog[_2_] Piloting 8 May 6th 10 11:31 PM
P-40 2nd post Phil Rhodes Aviation Photos 3 March 27th 07 08:09 PM
Another OT post, but you're not alone! Jim Burns Piloting 10 October 26th 06 02:59 AM
Mig-29 questions & general aviation questions 2003 Steven Military Aviation 1 October 20th 03 07:06 AM
Seven Questions For Michael Moore from a Blogger (was Questions for Mr. Bush, from Michael Moore) Jim Yanik Military Aviation 2 October 9th 03 10:36 PM
