On Jul 13, 4:29*pm, Frank Whiteley wrote:
http://rgl.faa.gov/Regulatory_and_Gu....nsf/list/2010... Effective July 19th, 2010 Am I reading correctly that no aerobatics are permitted after July 19th regardless of the outcome of the inspection? Thanks, Craig |
On Jul 13, 5:29*pm, Craig wrote:
On Jul 13, 4:29*pm, Frank Whiteley wrote: http://rgl.faa.gov/Regulatory_and_Gu....nsf/list/2010... Effective July 19th, 2010 Am I reading correctly that no aerobatics are permitted after July 19th regardless of the outcome of the inspection? Thanks, Craig Yes. That seems very clearly stated. Darryl |
Who will be the first to post the LET s/b?
I guess I will, although this is NOT the exact s/b revision as called out it the AD: http://ad.easa.europa.eu/ad/2010-0122-E/ aerodyne |
SORRY!
This is the correct link to the s/b. Check to make sure the date and rev level is the same as specified in the FAA or ESA AD, as applicable. http://www.let.cz/files//bulletines/...9a_english.pdf aerodyne |
Am I reading correctly that no aerobatics are permitted after July 19th regardless of the outcome of the inspection? Yes. That seems very clearly stated. They also state that: "Note 1: The above limitation is an interim solution until a final action is identified, at which time the European Aviation Safety Agency (EASA) and the FAA may consider further AD action." So, there is hope for those of us who enjoy an occasional loop. B. |
On Jul 13, 6:38*pm, Bart wrote:
Effective July 19th, 2010 Am I reading correctly that no aerobatics are permitted after July 19th regardless of the outcome of the inspection? Yes. That seems very clearly stated. They also state that: "Note 1: The above limitation is an interim solution until a final action is identified, at which time the European Aviation Safety Agency (EASA) and the FAA may consider further AD action." So, there is hope for those of us who enjoy an occasional loop. B. ....and that could also mean the whole fleet ends up being grounded. Darryl |
I disagree with Bart
"there may be FURTHER action" Since when does the FAA recind an AD action? There would have to be demonstrated proof that it would be safe to do so. A overly optomistic scenario would be a recurring inpection, probably involving NDI certainly not visual alone. Forget about aerobatics, and hope they don't restrict the flight envelope like they have done with so many others Diamant, Grob, duo discus, ect aerodyne |
On Jul 13, 5:36*pm, Darryl Ramm wrote:
On Jul 13, 5:29*pm, Craig wrote: On Jul 13, 4:29*pm, Frank Whiteley wrote: http://rgl.faa.gov/Regulatory_and_Gu....nsf/list/2010.... Effective July 19th, 2010 Am I reading correctly that no aerobatics are permitted after July 19th regardless of the outcome of the inspection? Thanks, Craig Yes. That seems very clearly stated. Darryl Yes, I thought it was clearly stated too, just so draconian that it was a bit difficult to believe. No exit clauses based on total hours, etc. Cheers, Craig |
On Jul 14, 8:26*am, Craig wrote:
On Jul 13, 5:36*pm, Darryl Ramm wrote: On Jul 13, 5:29*pm, Craig wrote: On Jul 13, 4:29*pm, Frank Whiteley wrote: http://rgl.faa.gov/Regulatory_and_Gu....nsf/list/2010... Effective July 19th, 2010 Am I reading correctly that no aerobatics are permitted after July 19th regardless of the outcome of the inspection? Thanks, Craig Yes. That seems very clearly stated. Darryl Yes, I thought it was clearly stated too, just so draconian that it was a bit difficult to believe. *No exit clauses based on total hours, etc. Cheers, Craig I don't see it as draconian. I see it as appropriate for a glider type that has had a spar failure/fatal accident and the TC owner, EASA, and FAA are allowing the type to keep flying after inspection and while collecting critical data on cracking. You guys need to wait until the field data is in and maybe you'll have a case to try to remove limitations, but I'd not hold my breath. Darryl |
