After quick observations, I noticed that fuel range in certified aircraft is
slightly lower than comparable hombuilt aircraft. Anybody agree with this? Toks Desalu |
slightly lower than comparable hombuilt aircraft. Anybody agree with this? LOL - one is telling the truth, the other isn't |
On Thu, 13 Nov 2003 21:51:39 GMT, "Toks Desalu"
wrote: After quick observations, I noticed that fuel range in certified aircraft is slightly lower than comparable hombuilt aircraft. Anybody agree with this? Toks Desalu It's pretty difficult to compare homebuilts to certified aircraf. Homebuilts are often lighter, more narrow and almost always more slippery. In addition, Homebuilts usually do not have similar fuel tank sizes. For instance, the Christavia Mk4 I'm building is _roughly_ comparable to the Cessna 172 in performance. But the Christavia specs two wing tanks at 12 to 14 gallons each plus an optional fuselage tank that might hold another 8 to 10 or so for a total of maybe 30 or 32 gallons. The C172 holds 54 gallons, 52 useable. At 10 gallons per hour, the 172 is flying for more than 5 hours, longer if you throttle back. The Christavia is only in the air for 3 hours. What airplanes were you thinking of for comparison purposes? Corky Scott |
| Thread Tools | |
| Display Modes | |
| Fuel Drip Containment | Sven | Home Built | 28 | October 27th 03 11:28 PM |
| Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 03:57 AM |
| Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 08:09 PM |
| Fuel pressure Problems | smf | Home Built | 3 | September 7th 03 09:25 PM |
| Question ~ Does fuel injection add weight? | Barnyard BOb -- | Home Built | 0 | July 6th 03 10:47 PM |
