Updraft Speed Ranges in Different Types of Storms
Old July 28th 10, 06:52 PM posted to rec.aviation.soaring
IdoMillet
Default Updraft Speed Ranges in Different Types of Storms
Just wanted to share an interesting article found at:
http://www.stormtrack.org/forum/arch...php/t-716.html
Here are some key figures extracted from it:
- non-severe thunderstorm: 15 to 30 MPH (1,200 - 2,500 fpm)
- severe "Multicell cluster" thunderstorms: 60 MPH (5,500 fpm)
- supercell: typical 70 or 80 MPH with extremes of 150 to 175 MPH
(12,000 - 15,000 fpm)
Cheers,
- Ido
Old July 28th 10, 08:06 PM posted to rec.aviation.soaring
IdoMillet
On Jul 28, 1:52*pm, IdoMillet wrote:
Just wanted to share an interesting article found at:http://www.stormtrack.org/forum/arch...php/t-716.html
Cheers,
- Ido
Just to clarify: the numbers above are updraft speeds - not wind
speeds.
Old July 28th 10, 09:06 PM posted to rec.aviation.soaring
sisu1a
Cheers,
- Ido
speeds.
There is a barogram I think Ben Green made while accidentally getting
sucked into a supercell in a K-6 that isn't far from these numbers.
His vertical speed while in a full spin (intentional) was around
90mph. Add the 45pmh sink rate of the spin and you have a 135mph
updraft. If I find it I'll scan and post it along with clarifications
if the ras hivemind hasn't already filled in the correct details by
then
-Paul
Old July 28th 10, 09:08 PM posted to rec.aviation.soaring
Mike the Strike
Cheers,
- Ido
speeds.
You can get an idea of the necessary updraft if you look at the
terminal velocity of hailstones of various sizes. Tennis-ball sized
hail (which I have witnessed) has a terminal velocity of more than 100
mph.
Mike
Old July 28th 10, 09:17 PM posted to rec.aviation.soaring
Tony[_5_]
This is an interesting paper about a Grunau Baby in a thunderstorm in
Australia
http://adsabs.harvard.edu/full/1949AuSRA...2..550R
Old July 30th 10, 01:56 PM posted to rec.aviation.soaring
Mike[_28_]
And then there's the paraglider pilot who got sucked up to 32,000' and
survived. Another paraglider caught in the same storm wasn't so
lucky.
http://www.flightlevel350.com/forum/...howtopic=10400
VOR ranges on sectionals Mxsmanic Piloting 17 April 21st 07 03:20 AM
Solar storms spell trouble for GPS Larry Dighera Piloting 66 April 11th 07 03:20 AM
B-17 wreck site - Owen Stanley Ranges PNG Dave Kearton Aviation Photos 10 January 4th 07 04:07 PM
Soaring: A Search for the Perfect Updraft Johan Larson Soaring 0 December 15th 06 04:27 AM
roland radar around the Nellis ranges miso Military Aviation 15 September 22nd 03 11:17 PM
