I have a question for anyone familiar with flying the 747-200.
According to news stories in the media reporting the crash of a MK Airlines 747-200 freighter at Halifax Canada awhile ago, the investigators found that the airspeed was some 55 kph low. It was noted that the engines had been operated at a power 'inconsistent with the a/c weight' (as if the engines are normally operated at a power governed by the a/c weight during takeoff). Is this true for this a/c? I've never heard of this. Any a/c that I'm familiar with certainly don't modulate takeoff power according to their weight. Is it done on the 747? -- -Gord. (use gordon in email) |
BRBR The 747 with or without the tailhook?? Sorry, just a little holiday humor. Ohh so many guys here that are flying the big winged buses, wondering about their future. P. C. Chisholm CDR, USN(ret.) Old Phart Phormer Phantom, Turkey, Viper, Scooter and Combat Buckeye Phlyer |
Gord Beaman wrote
I've never heard of this. Any a/c that I'm familiar with certainly don't modulate takeoff power according to their weight. It can be done for most all jet transport category aircraft. It is called the "reduced takeoff thrust" procedure. Most airlines have FAA approval to use this procedure in order to extend engine life. It's all about "creep units", RPM, and EGT or TIT. Keep the RMP and EGT as low as possible for extended engine life. It goes something like this...... From the runway takeoff limit chart, determine the maximum allowable temperature for the actual weight. Then use that assumed temperature to determine the takeoff power setting. This will produce takeoff performance equal to a takeoff at maximum weight for the actual temperature. I'll scan the procedure out of my Boeing manual if this is not clear enough. Bob Moore VP-21 VP-46 ATP B-707 B-727 PanAm (retired) |
Bob Moore wrote:
Gord Beaman wrote I've never heard of this. Any a/c that I'm familiar with certainly don't modulate takeoff power according to their weight. It can be done for most all jet transport category aircraft. It is called the "reduced takeoff thrust" procedure. Most airlines have FAA approval to use this procedure in order to extend engine life. It's all about "creep units", RPM, and EGT or TIT. Keep the RMP and EGT as low as possible for extended engine life. It goes something like this...... From the runway takeoff limit chart, determine the maximum allowable temperature for the actual weight. Then use that assumed temperature to determine the takeoff power setting. This will produce takeoff performance equal to a takeoff at maximum weight for the actual temperature. I'll scan the procedure out of my Boeing manual if this is not clear enough. Bob Moore VP-21 VP-46 ATP B-707 B-727 PanAm (retired) Thanks Bob, and that's quite clear, no need to scan it at all. I just had never heard of it being done before. Seems like a somewhat unsafe thing to be doing with a high value machine in a highly critical phase of its flight. Perhaps 'unsafe' isn't the correct word here, my point is that I feel that it might be unproductive to operate the a/c closer to it's maximum capabilities just to save some 'wear and tear' on the engines? I'd think that you're not availing yourself of that 'extra performance' in case of an engine failure at a critical time. I suspect that it'd take a hell of a long time to make up what they lost in that one crash. (not even to mention the seven crew-members) -- -Gord. (use gordon in email) |
"Gord Beaman" wrote...
Thanks Bob, and that's quite clear, no need to scan it at all. I just had never heard of it being done before. Seems like a somewhat unsafe thing to be doing with a high value machine in a highly critical phase of its flight. Perhaps 'unsafe' isn't the correct word here, my point is that I feel that it might be unproductive to operate the a/c closer to it's maximum capabilities just to save some 'wear and tear' on the engines? I'd think that you're not availing yourself of that 'extra performance' in case of an engine failure at a critical time. I suspect that it'd take a hell of a long time to make up what they lost in that one crash. (not even to mention the seven crew-members) Well, this is just an example of the reality that belies the "safety is paramount" theory... Reduced T/O thrust and non-optimum noise abatement climb profiles have been made "standard" to put economics and politics ahead of actual safety considerations... There are actually some limited cases (e.g., contaminated runways, to reduce Vmc) where reduced thrust takeoffs are "safer" than full-thrust takeoffs, but they are the exception to the rule. |
"John R Weiss" wrote:
"Gord Beaman" wrote... Thanks Bob, and that's quite clear, no need to scan it at all. I just had never heard of it being done before. Seems like a somewhat unsafe thing to be doing with a high value machine in a highly critical phase of its flight. Perhaps 'unsafe' isn't the correct word here, my point is that I feel that it might be unproductive to operate the a/c closer to it's maximum capabilities just to save some 'wear and tear' on the engines? I'd think that you're not availing yourself of that 'extra performance' in case of an engine failure at a critical time. I suspect that it'd take a hell of a long time to make up what they lost in that one crash. (not even to mention the seven crew-members) Well, this is just an example of the reality that belies the "safety is paramount" theory... Yep, I agree...and further, I think they're right to do so too. I've said this before (and gotten slapped down for it) I think a/c are too safe now...we need to allow the safety factor to slowly float downward until it's close to the 'safety factor plus the financial risk factor of the automobile'. At that point the passenger will still be much safer in an a/c than an automobile because of the much higher financial risk factor of the aircraft. BUT the cost for an airline ticket won't be so prohibitive that lots of people will drive rather than fly. Or are the airlines fully utilizing the available airspace in North America therefore there's no opportunity to increase air traffic? Reduced T/O thrust and non-optimum noise abatement climb profiles have been made "standard" to put economics and politics ahead of actual safety considerations... There are actually some limited cases (e.g., contaminated runways, to reduce Vmc) where reduced thrust takeoffs are "safer" than full-thrust takeoffs, but they are the exception to the rule. John, I recall that you're a qualified 747 F/E or Pilot so can you tell me whether replacing aerodynamic trim of the tailplane with fuel weight to reduce drag during cruise is still being done?...I never seem to hear of it anymore, also what's the proper nomenclature for that? -- -Gord. (use gordon in email) |
Gord Beaman wrote
John, I recall that you're a qualified 747 F/E or Pilot so can you tell me whether replacing aerodynamic trim of the tailplane with fuel weight to reduce drag during cruise is still being done?...I never seem to hear of it anymore, also what's the proper nomenclature for that? We never did the fuel thing in the B-707, but we did try to keep as much luggage/cargo in the aft hold as possible in order to accomplish the same thing. Bob |
John, I recall that you're a qualified 747 F/E or Pilot so can you tell me whether replacing aerodynamic trim of the tailplane with fuel weight to reduce drag during cruise is still being done?...I never seem to hear of it anymore, also what's the proper nomenclature for that? I'm a 747-400 Pilot. Some 744s were delivered with fuel tanks in the horizontal tail. They hold 10,000 Kg. I have not flown any airplanes with them installed, so I do not know any fuel management specifics for them. While it may be possible to "passively" manage the CG by retaining the tail fuel as long as possible, I don't know if this is authorized. Also, AFAIK, there is no way to move fuel to the tail tank in flight -- once transferred down, it stays down. |
Gord Beaman wrote
Perhaps 'unsafe' isn't the correct word here, my point is that I feel that it might be unproductive to operate the a/c closer to it's maximum capabilities just to save some 'wear and tear' on the engines? I'd think that you're not availing yourself of that 'extra performance' in case of an engine failure at a critical time. Gord, I post the following excerpt from the excellent book, "Handling the Big Jets" by D.P. Davies, the Brit who certified the B-707 in Britian as Chief Test Pilot for the United Kingdom Airworthiness Authority. --------------------------------------------------------- The overall safety level of reduced thrust take-offs is something which bothers some pilots, who believe that the average exposure to `near critical' take-off conditions is increased. The proof that this worry is groundless is, as one would expect of something produced by performance experts, long and detailed. However, the following is a brief outline: When reduced thrust is used for take-off the risk per flight is decreased because : (a) The `assumed temperature' method of reducing thrust to suit take-off weight does so at constant thrust/weight ratio, and the actual take-off distance, take-off run and accelerate-stop distances at reduced thrust are less than at full thrust and full weight by approximately 1 % for every 3°C that the actual temperature is below the assumed temperature. (b) The accelerate-stop distance is further improved by the increased effectiveness of full reverse thrust at the lower temperature. (c) The continued take-off after engine failure is protected by the ability to restore full power on the operative engines. Furthermore, although there is inevitably a slight increase in average risk, this increase is minimised by two factors: (a) A significant percentage of take-offs are at weights close enough to R.T.O.W. not to warrant the use of reduced thrust. (b) The excess margins on lighter-weight take-offs are largely preserved by the maximum thrust reduction rule. In any case it is anticipated that more than adequate compensation will be provided by enhanced engine reliability. -------------------------------------------------------------- BTW Gord, just in case you are not that familiar with civilian jet transports, takeoff thrust does not equate to full throttle. T.O. thrust is set in acordance with pressure/temperature charts always with some throttle left to account for the hot/high day. Bob Moore VP-21 VP-46 ATP B-707 B-727 PanAm (retired) |
Bob Moore wrote:
-------------------------------------------------------------- BTW Gord, just in case you are not that familiar with civilian jet transports, takeoff thrust does not equate to full throttle. T.O. thrust is set in acordance with pressure/temperature charts always with some throttle left to account for the hot/high day. Bob Moore Very interesting Bob, thanks. I certainly won't be arguing with HIM any time soon and yes, I'm familiar with less than full throttle 'full power'. I'm very familiar with large radial recips most of which have very definite power limits well short of the firewall. But we always used those limits no matter what conditions prevailed and I didn't know that large jet a/c used anything less. I gather that the 747 freighter loss at Halifax Canada had approx. the proper weight calculated but that It was some 55 Km PH low in speed and that there was some controversy as to whether he had used the whole runway. -- -Gord. (use gordon in email) |
| Thread Tools | |
| Display Modes | |
| Dennis Fetters Mini 500 | EmailMe | Home Built | 70 | June 21st 04 10:36 PM |
| Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 07:42 PM |
| What if the germans... | Charles Gray | Military Aviation | 119 | January 27th 04 12:20 AM |
| #1 Jet of World War II | Christopher | Military Aviation | 203 | September 1st 03 04:04 AM |
| Aircraft engine certification FAR's | Corky Scott | Home Built | 4 | July 25th 03 07:46 PM |
