Has anyone heard of Dick Johnson's wing flattening jig? I'm interested
in a Discus A and the owner said that this glider has had the wings flattened. A previous owner of this glider was Wil Schuemann so mabey he did the work. Anyone have more information about a wing flattening jig and if it yielded any performance increase? |
![]() "ryanglover1969" wrote in message ... Has anyone heard of Dick Johnson's wing flattening jig? I'm interested in a Discus A and the owner said that this glider has had the wings flattened. A previous owner of this glider was Wil Schuemann so mabey he did the work. Anyone have more information about a wing flattening jig and if it yielded any performance increase? Is that related to the left hand, or the right hand board stretcher? -- Jim in NC |
On Aug 21, 7:31*am, "Morgans" wrote:
Is that related to the left hand, or the right hand board stretcher? Yes, probably so. |
On Aug 20, 9:02*pm, ryanglover1969 wrote:
Has anyone heard of Dick Johnson's wing flattening jig? I'm interested in a Discus A and the owner said that this glider has had the wings flattened. A previous owner of this glider was Wil Schuemann so mabey he did the work. Anyone have more information about a wing flattening jig and if it yielded any performance increase? You may be thinking of the Johnson wing waviness measuring tool. It's a 3 contact point base with a dial gauge in the middle. It's one thing to measure what's there, quite another to change what's there into what you might like. Andy |
As a matter of fact I purchased the Wng Flattener from Dick just
before his untimley death. It is necessary to flatten both the top and bottom of both wings to get maximum perormance increase. You must carefully remove all wax and contaminates before placing your wings into the molds. Then plug it into 220 (3-phase) current and select 75 amps to start with. If after an hour the wings arent flat then turn the selector up to max (100 amps) and wait another hour. I charge $1000 per side, so both sides of both wings will run you $4000 with a 10% discount for FNG's Dick also sold me the rights to his Wing Stretcher which will run you $1000 per meter. Expencive, but one customer is ecstatic over his 30 meter Libelle! JJ |
On Aug 21, 1:12*pm, JJ Sinclair wrote:
As a matter of fact I purchased the Wng Flattener from Dick just before his untimley death. It is necessary to flatten both the top and bottom of both wings to get maximum perormance increase. You must carefully remove all wax and contaminates before placing your wings into the molds. Then plug it into 220 (3-phase) current and select 75 amps to start with. If after an hour the wings arent flat then turn the selector up to max (100 amps) and wait another hour. I charge $1000 per side, so both sides of both wings will run you $4000 with a 10% discount for FNG's Dick also sold me the rights to his Wing Stretcher which will run you $1000 per meter. Expencive, but one customer is ecstatic over his 30 meter Libelle! JJ Can the wing stretcher be modified to fit a glider tail? Darryl |
On Aug 21, 4:12*pm, JJ Sinclair wrote:
As a matter of fact I purchased the Wng Flattener from Dick just before his untimley death. It is necessary to flatten both the top and bottom of both wings to get maximum perormance increase. You must carefully remove all wax and contaminates before placing your wings into the molds. Then plug it into 220 (3-phase) current and select 75 amps to start with. If after an hour the wings arent flat then turn the selector up to max (100 amps) and wait another hour. I charge $1000 per side, so both sides of both wings will run you $4000 with a 10% discount for FNG's Dick also sold me the rights to his Wing Stretcher which will run you $1000 per meter. Expencive, but one customer is ecstatic over his 30 meter Libelle! JJ JJ- You're not spillin' the beans on th Mark IV version with the 4th order reflex compensation are you? I thought we agreed to keep it to ourselves till 2015. Are you selling out on me? UH |
![]() JJ- You're not spillin' the beans on th Mark IV version with the 4th order reflex compensation are you? I thought we agreed to keep it to ourselves till 2015. Are you selling out on me? UH At the time of his death, Dick Johnson was also working on a ground- loop prevent'er and I have his concept drawings. The heart of the system is a gyro that instantly detects lateral motion while on the ground. The unit is armed via an oleo-strut micro switch and directs high pressure air to the opposite wing (ground-loop detected to left = air directed to right wing). A 2 inch plastic sleeve is mounted inside both wings with a 10 pound sliding slug that will instantly fly from the root rib to the wing tip just as soon as the gyro detects a ground- loop developing. I believe the concept to be sound and I am presently working on a method of stopping the slug when it reaches the wing tip. Stat tuned, JJ |
On Aug 22, 7:43*am, JJ Sinclair wrote:
JJ- You're not spillin' the beans on th Mark IV version with the 4th order reflex compensation are you? I thought we agreed to keep it to ourselves till 2015. Are you selling out on me? UH At the time of his death, Dick Johnson was also working on a ground- loop prevent'er and I have his concept drawings. The heart of the system is a gyro that instantly detects lateral motion while on the ground. The unit is armed via an oleo-strut micro switch and directs high pressure air to the opposite wing (ground-loop detected to left = air directed to right wing). A 2 inch plastic sleeve is mounted inside both wings with a 10 pound sliding slug that will instantly fly from the root rib to the wing tip just as soon as the gyro detects a ground- loop developing. I believe the concept to be sound and I am presently working on a method of stopping the slug when it reaches the wing tip. Stat tuned, JJ JJ, Be careful, Homeland Security and the TSA might want to know more about that Sliding Slug, AKA a projectile-aircraft mounted-airborne delivery system! Brad |
On Aug 22, 8:09*am, Brad wrote:
On Aug 22, 7:43*am, JJ Sinclair wrote: JJ- You're not spillin' the beans on th Mark IV version with the 4th order reflex compensation are you? I thought we agreed to keep it to ourselves till 2015. Are you selling out on me? UH At the time of his death, Dick Johnson was also working on a ground- loop prevent'er and I have his concept drawings. The heart of the system is a gyro that instantly detects lateral motion while on the ground. The unit is armed via an oleo-strut micro switch and directs high pressure air to the opposite wing (ground-loop detected to left = air directed to right wing). A 2 inch plastic sleeve is mounted inside both wings with a 10 pound sliding slug that will instantly fly from the root rib to the wing tip just as soon as the gyro detects a ground- loop developing. I believe the concept to be sound and I am presently working on a method of stopping the slug when it reaches the wing tip. Stat tuned, JJ JJ, Be careful, Homeland Security and the TSA might want to know more about that Sliding Slug, AKA a projectile-aircraft mounted-airborne delivery system! Brad- Hide quoted text - - Show quoted text - Lighten up Brad. The PAMADS is an entirely different project. What you NEED to worry about is the stuff they're NOT talking about. |
Dick Johnson | Clint | Soaring | 4 | June 6th 09 10:40 PM |
Dick Johnson is gone. | Burt Compton - Marfa | Soaring | 23 | July 27th 08 05:38 PM |
Dick Johnson's FTE of the Discus-2 | Flavio Formosa | Soaring | 1 | January 18th 07 03:18 PM |
Richard Johnson's Report on the Sparrowhawk | skysailor | Soaring | 10 | February 21st 05 09:47 AM |
Dick Tracy | C J Campbell | Piloting | 3 | December 24th 04 02:18 AM |
