Hot Spark Ignition
Old November 16th 03, 01:06 AM
Larry Smith
Default Hot Spark Ignition
A friend in Florida rigged up his own non-magneto ignition robbed from a
late-model motorcycle and installed it on his O-200-powered Murphy Renegade.
If I recall correctly he has it set up to advance itself as much as 35
degrees. Any more anecdotes about nonstandard ignition boxes?
I want to use one on the IO-360 Continental. And did you know ---- full
advance timing on that engine is 20 degrees btdc? It doesn't seem right,
does it?
Lightspeed Klaus used to advance timing on his O-200 to as much as 45 deg.
btdc. I wonder if he still does. I was just reading Klaus's
denunciation of the magneto as something of an ancient relic. I think I
agree with him.
Old November 16th 03, 02:53 AM
On Sat, 15 Nov 2003 20:06:48 -0500, "Larry Smith"
Friend of mine (a very CHEAP friend of mine) did the same thing with the
O-290 on his T-18, except he based his on a late '80s GM electronic
ignition. Eventually got it working fine, but he fought an EMI problem for
quite a while. Ran fine on the ground, but it would start misfiring just
after clearing the fence on takeoff....
Old November 16th 03, 10:54 AM
Ken Reynolds
"I have a VW engine in a gyro, using this system and it is terrific. Easy
start, smooth idle , two of everything. My cyl head is drilled and tapped
for twin plugs. www.leburg.freeserve.co.uk/
I would reccomend it to anyone.
Ken Reynolds
Old November 16th 03, 01:59 PM
- Barnyard BOb -
does it?
Doesn't *SEEM* right?
WoW....
Here's a piece of solid engineering data
we can hang our hats on and put to good use.
Inform Continental immediately of your discovery.
Save the world... and maybe a whale or two? g
agree with him.
1. Isn't Klaus's denunciation..... an infomercial?
2. Has not "thinking" gotten you into a ton of trouble, before?
P.S.
Purchased that T-Craft prop yet?
If you think that prop is expensive...
Write a check for two of Klaus's spark boxes.
Better yet, try again having great fun with a credit card.
FWIW --
I'm into cost benefit ratios that benefit ME,
not the seller of a 'better' mouse trap.
In the marketplace....
The magneto remains a very intelligent
and viable choice for most GA missions.
Barnyard BOb -- over 50 years of successful flight
Old November 17th 03, 01:52 PM
Larry Smith
"- Barnyard BOb -" wrote in message
Renegade.
full
right,
does it?
Ja, Bob, that's retarded, relatively speaking.
WoW....
Ja, Bob, and I'm not even an engineer. Does it tell you something that
spark timing on autos has "advanced" into this century while spark timing on
aircraft engines is mired up in the 20th?
Engine experts will tell you that the Continental IO-360 has a primitive
ignition system and an outmoded low-pressure induction. It's a great
engine. It just needs some tweaking. On the other hand I may leave mine
stock. I have flown an assbuster or two before and at my age no longer
want to push the envelopes. I'll let the young whippersnappers do that.
You can be sure they've been playing, experimenting with something like
Unison's Lasar in their skunkworks wing.
deg.
agree with him.
Yeah, but if you've seen how his ignition will shoot a hot spark across an
..040 gap and fire fouled plugs a mag can't budge, you'd be sold.
Hell, no.
Klaus's ignition works. So does the Electroair. This is
rec.aviation.experimental. Be in it.
Variable timing ignition is more efficient, saves fuel, gets you there
quicker.
I know at least 2 A&P's who are fascinated with auto engines in aeroplanes.
One is building up a Subaru at the time for his airplane; another is
building a Piet which he's gonna put a flathead Ford engine in. We got an
A&P at Rutherfordton who thinks Franklin engines are great and has a
Franklin in his Rallye. Isn't a Franklin an auto engine?
We have 2 builders in our club putting those diminutive 30-hp Continental
gpu engines in their Mini-Max airplanes. They should be using VW engines
instead.
P.S.
I'm balking at $2250. That's about $500 more than for a brand-new prop for
an O-320. It defies logic. I already have 2 Sensenich woodies, one for
climb and one for cruise. The cruiser hangs on the wall. I'd buy a 1B90
7445 for $1800. McCauley acts like it doesn't even want to manufacture
aluminum props for the small engines any more. So does Sensenich.
Yeah, he's pricey, so I may try my friend's setup, or Electroair, or the
Continental version of Lasar. You just go by once, you know.
FWIW --
Maybe I'll stay with those good ol' S6LN-25's set at a droll 20 deg. btdc.
One of them throws a shower of sparks, but only for a second or two.
Over 51 now. Hasn't a year ticked over?
Old November 17th 03, 04:39 PM
- Barnyard BOb -
On Mon, 17 Nov 2003 08:52:11 -0500, "Larry Smith"
WoW....
What your reply tells me is --
until you are more engineer than lawyer...
lawyers know jack **** about advance
or timing... except as it applies to collecting
monies from clients and adversaries.
SO?
deg.
agree with him.
I am sold.
I'm just not gonna write an outrageous check for an
upgrade that is not required and CANNOT BE JUSTIFIED
by my current airworthy application.
You may be a dumb **** that just gotta have the latest
and greatest to stay ahead of the Jones's. I *do not*.
Hell, no.
So do magnetos... at a far, far lesser price.
This is rec.aviation.experimental. Be in it.
Quit the cheap shots and condescending horse****. OK?
I've was in experimental aviation before you got out of diapers.
BTW, this is...... rec.aviation.homebuilt ---
Does anybody that takes issue with me know where they're at?
Sheesh!!!!!!!!!!!!!!
quicker.
Let the spin stop for a moment.
Give me some hard numbers that I can take to the bank.
My calculator sez...it will take me a gazillions years to
recoup an investment in any upgrade priced like Klaus's
at the current price of auto fuel and the hours I fly per year.
Figure this, too....
When a Klaus unit drops dead and I can't find Klaus or I'm
cross country and need to get home what do I do? Buy
a standard magneto to get home and then mail the offending
high priced Klaus unit to the Republik of Kalifonia for service?
I'll pass, thank you.
As an advocate...
you ain't **** until you part with your cold hard cash for the
above product. Until you do, your call for me to join in
rec.aviation.experimental? is as hollow and empty as your
friggin' head. I own and fly experimental now and began it
with a Fly Baby in the early '60's and belonged to the EAA
when Rockford was the cool place to go.
Old November 17th 03, 05:31 PM
Ben Sego
This reminds me of a conversation I witnessed between a sales guy and a
lawyer. The lawyer worked for a large firm on K street. He was in
charge of technology on a couple of really, really large cases which
involved the preparation and exchange of millions of pages of
information. The sales guy (a friend of mine for some years) had sold
the firm on a particular method of handling the documents
electronically. Things hadn't been going well. (In fact, that's why
the sales guy called my company in. We had, on a couple of previous
occasions, cleaned up the mess made by his company.) During a misguided
effort to "bond" with the lawyer, the following exchange occurred:
SG: Law fascinates me.
Lawyer: Hmmm.
SG: I always wished I had become a lawyer.
Lawyer: Hmmm.
SG: My father is a lawyer. And a diplomat. My sister is a lawyer. My
grandfather was a lawyer. It's really ironic that I'm not. I mean,
I've been surrounded by it all my life, and I've been influenced by so
many people, all lawyers. I can't really think of any better heritage
than to come from a long line of lawyers.
Lawyer: Is that so? You feel that being brought up around all those
lawyers made you a better person?
SG: Oh, absolutely. In subtle and not so subtle ways.
Lawyer: Yeah, well everybody in my family was an auto mechanic. I think
I f**ked up.
snip
I am sold.
snip
snip
quicker.
snip
Some good points on both sides. The new stuff is great; the old stuff
is adequate to the purpose. The new stuff doesn't have decades of
provable success under its proverbial belt. But the old stuff doesn't
make use of anything we've learned in those same decades. Great
discussion, ****ing aside.
Bob, I know you're one of the old hands here at
deja.yahoo.flamebait.experimental, and its great to read a lot of your
stuff. But GD, did I miss something significant in the couple of years
I was away, such that everybody started ****ing on you, or did you get
touchy? I'll go back and read the archives when I have time, but for
now, I'm just happy to have enough time to check in again.
Ben "still not caring whether you all get along, just curious" Sego
Old November 17th 03, 07:47 PM
- Barnyard BOb -
On Mon, 17 Nov 2003 17:31:38 GMT, Ben Sego
beaming
Thanx for the back handed compliment, Ben Dover.
When you have time, please funrish your list of "everybody".
I'm sure it's a hoot and is a very fine list of all those that
have distinguished themselves both with credentials and
accomplishments we both admire in the field of aviation.
P.S.
Your slipping...
You didn't ask if I quit beating my wife yet.
Also..
This thread is for Hot Spark Ignition.
Got anything to add that's on topic?
Barnyard BOb -- over 50 years tolerating unsuccessful nit****s
Old November 18th 03, 01:29 AM
Del Rawlins
On 17 Nov 2003 08:31 AM, Ben Sego posted the following:
years I was away, such that everybody started ****ing on you, or did
you get touchy? I'll go back and read the archives when I have time,
but for now, I'm just happy to have enough time to check in again.
All of the above. At this point who cast the first stone is less
important to the discussion than the matter of who has the biggest pair.
Del Rawlins-
Remove _kills_spammers_ to reply via email.
Unofficial Bearhawk FAQ website:
http://www.rawlinsbrothers.org/bhfaq/
Old November 18th 03, 02:24 PM
Larry Smith
From the auto engine and motorcycle engine builders, and experimenters,
great benefits for the aircraft engine: nikasil cylinders; lightweight
starters, generators and alternators; carbon
fiber and composite propellers; modern fuel injection systems; Ellison TB
injector
and other variable venturi carbs;
ignition boxes by Lightspeed and Electroair; porting, flow-matching, and
balancing,
auto engines with good reps: subaru, vw, mazda rotary, bmw mcy engines,
suzuki sprint 3-cylinder
Engines I'm familiar with and don't like in airplanes: Franklin, Corvair,
any 2-stroke, 65-horse Lycoming (which never even made 60 horses in its best
day below sea level and could be best used as a boat anchor); Jabiru;
Revmaster; Trabant;
GO-300; Tigre (junk); Menasco (junk)
Fascinating new developments: diesel engines, like the Thielert and Zoche.
Other great engines: Ranger inline, Continental and Lycoming radials,
Vedeneyev, P&W, Jacobs (shaky Jake), Szekely, Warner, Wright, etc.
Favorite engine: Rolls-Royce Merlin which powered the P-51 Mustang:
plenty of horsepower, liquid cooled, supercharged, very efficient for its
time, still winning, at Reno
This was my outline but I had to git this a. m. I wanted to rant a little
about having to pay such high prices for certified props when you can buy a
s-o-t-a Warp Drive for $600. Now wouldn't that pull your little
Taylorcraft along at a zippy pace? They're doing it legally --- hanging
carbon fiber propellers on A-65's and C-85's pulling certified aircraft ---
in Canada and in other countries but in the USA, oooo noooooooooo, can't
stand the progress.
Electronic Ignition Andre Home Built 1 September 5th 03 06:15 PM
Ignition Exciter Wiring Juan E Jimenez Home Built 0 August 31st 03 06:03 AM
WTB: Ignition Exciter Juan E Jimenez Home Built 0 August 27th 03 08:09 PM
Wright Flyer Ignition Dan Thomas Home Built 6 July 22nd 03 03:45 AM
2nd update on Review of Plasma II Ignition System MikeremlaP Home Built 8 July 22nd 03 01:37 AM
