Does anyone know what type of seal exists where the dump valve actuator
goes through the root rib of the wing on a LAK-17? I have water seeping here. On the root rib I see a round plate with 3 screws that the actuator rod goes through and assuming there is a seal behind it. Thanks in advance. Wells 9U --- news://freenews.netfront.net/ - complaints: --- |
The answer.....
the seal actually consists of surgical tubing slid over the actuator rod and the end plate that screws into the wing root. Very high tech... My tubing had broken between the end plate and the actuator rod, only requiring some new tubing... On 8/22/2010 6:15 AM, Leroy Tire wrote: Does anyone know what type of seal exists where the dump valve actuator goes through the root rib of the wing on a LAK-17? I have water seeping here. On the root rib I see a round plate with 3 screws that the actuator rod goes through and assuming there is a seal behind it. Thanks in advance. Wells 9U --- news://freenews.netfront.net/ - complaints: --- --- news://freenews.netfront.net/ - complaints: --- |
P-51 Question | David Pride[_2_] | Aviation Photos | 3 | February 10th 08 09:53 AM |
I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 06:39 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
Question of the Day | M B | Soaring | 16 | September 10th 03 07:30 AM |
