LET Blanik L-13 OE-0935 History Details?
Old August 30th 10, 08:48 PM posted to rec.aviation.soaring
Tim Taylor
Default LET Blanik L-13 OE-0935 History Details?
Does anyone have a source for the flight history of Blanik L-13
OE-0935 that was involved in the wing failure? Total hours, take-off/
landings, aerobatics, and winch launch history?
Old August 30th 10, 09:12 PM posted to rec.aviation.soaring
Andy[_1_]
OE-0935 that was involved in the wing failure? *Total hours, take-off/
If you're going that route you'll probably need all accident and
repair history as well.
Andy
Old August 30th 10, 09:50 PM posted to rec.aviation.soaring
Andrew Corrigan
It would be interesting to know this information for curiosity sake.
But, I'm not sure if this historical data can conclusively say fatigue
was the root cause of the failure. The failure might have been caused by
flying the glider out of it's design limits.
This would not be hard to do if a pilot screwed up an aerobatic manevour.
If things go wrong, Vne and G limits can be easily exceeded in a hurry.
Our friends that had the last flight may done a normal basic training
flight. But, a previous flight might have damaged the glider.
Unfortunately, no one said anything about over stressing the glider and
someone else paid the price.
Andrew
At 20:12 30 August 2010, Andy wrote:
OE-0935 that was involved in the wing failure? =A0Total hours,
take-off/
Andy
Old August 30th 10, 10:42 PM posted to rec.aviation.soaring
vaughn[_3_]
"Andrew Corrigan" wrote in message
I think that accident investigators can fairly positively tell the difference
between a structure that has failed from overstressing and one that has failed
from fatigue. The AD says "The preliminary investigation has revealed that the
fracture may have been due to fatigue". So there seems to be little reason to
suspect this accident resulted from prior overstress damage; particularly damage
from a recent flight.
Vaughn
Old August 30th 10, 11:16 PM posted to rec.aviation.soaring
Bart[_4_]
from fatigue. *The AD says "The preliminary investigation has revealed that the
fracture may have been due to fatigue". *So there seems to be little reason to
If a glider is routinely overstressed by, say, 20%, I would not expect
it to fail. I would, however, expect its fatigue life to be
significantly decreased. Years later, the wing could fail when under
"normal" load, and the fracture would look like a fatigue fracture. I
may be wrong... am I?
Bart
Old August 30th 10, 11:21 PM posted to rec.aviation.soaring
Bart[_4_]
If a glider is routinely overstressed by, say, 20%...
I would like to add that the scenario above is purely theoretical and
I am not trying to suggest that the accident in Austria was caused by
anyone who has flown the glider in question in the past.
B.
Blanik L-23 Super Blanik Manual -F.C.F.S. Joel Flamenbaum Soaring 2 April 14th 10 03:29 PM
Anyone got any details on this? Jay Honeck Piloting 5 December 19th 07 06:54 AM
SS1 details [email protected] Soaring 0 January 13th 05 02:30 PM
Any details about this? Dan Soaring 5 October 28th 03 07:22 PM
