iPhone Logger?
Old September 1st 10, 03:59 PM posted to rec.aviation.soaring
vontresc
Default iPhone Logger?
From time to time I check the iPhone app store for soaring apps. I
just came across GlidePath. The developer claims it's OLC compliant. I
havent purchased it yet, but it looks like a good backup for OLC
flying.
http://itunes.apple.com/us/app/glide...83714417?mt=8#
Pete
Old September 1st 10, 06:17 PM posted to rec.aviation.soaring
Mike the Strike
flying.
Pete
Interesting App. My concern would be battery life without external
power. I've used a few tracking and logging apps on my iPhone and
find I am limited to a couple of hours before needing a recharge.
Presumably it also won't plot a map without Internet access. Assuming
this is available via 3G, this is currently likely a violation of
contest rules.
Mike
Old September 1st 10, 06:30 PM posted to rec.aviation.soaring
Darryl Ramm
flying.
Pete
Interesting App. *My concern would be battery life without external
power. *I've used a few tracking and logging apps on my iPhone and
Presumably it also won't plot a map without Internet access. *Assuming
contest rules.
Mike
OLC Contest Rules? They don't seem to care about communication
devices.
I suspect it is not aimed at sanctioned contests and would not try to
be an IGC position recorder.
The power consumption is likely to be high. I don't believe it can
rely on the background low-power tracking mode in iOS 4 as that relies
on cell tower switching tricks.
Anybody tried it?
Darryl
Old September 2nd 10, 04:58 AM posted to rec.aviation.soaring
kammeyer
Hi All,
I'm the author of GlidePath. Just to clarify a few things -- we are
OLC approved, although I have gotten a couple of comments about
validation problems, and we'll be releasing a new version shortly that
resolves these issues. I'm hoping to get it approved as an IGC
Position Recorder, which is a new class of loggers that can only be
used for Silver and Gold badges. There are some obstacles for using
this in contests due to the phone's abilities, but I believe that a
technical solution can be found that will be satisfying to the contest
officials for use as a backup logger.
The really nice features of GlidePath a
1. Super easy OLC submission: You just log your flight, and tap a
couple of times, and your flight is on OLC. No hassles with SD cards
and making sure you get everything transferred before the OLC weekly
deadline.
2. Super easy transfer of flights to your computer: Just push a
button and the flight is emailed to yourself or anyone else.
3. Very low cost to start logging your flights, which is especially
useful to newcomers to the sport who may be flying club gliders. They
can start analyzing their flights quickly and easily, and start
participating on OLC even before they start doing real x/c.
Some tips:
1. Turn off Wi-Fi and Cellular Data for the best GPS reception
2. Make sure the phone has a clear view of the sky. It's easy to
accomplish this by either using a cheap suction cup mount or a running
type armband.
3. For long flights, battery life may be a concern. Turning off Wi-Fi
and Cellular Data help a lot, but you may want to consider one of the
available external batteries or plugging into ships power with one of
the car adapters available for the phone. Battery life is also an
area I will be addressing in the next couple of versions.
flying.
Pete
contest rules.
Mike
devices.
Anybody tried it?
Darryl
Old September 2nd 10, 06:59 AM posted to rec.aviation.soaring
Mike the Strike
On Sep 1, 7:58*pm, kammeyer wrote:
Hi All,
I'm the author of GlidePath. *Just to clarify a few things -- we are
resolves these issues. *I'm hoping to get it approved as an IGC
used for Silver and Gold badges. *There are some obstacles for using
1. Super easy OLC submission: *You just log your flight, and tap a
couple of times, and your flight is on OLC. *No hassles with SD cards
deadline.
2. Super easy transfer of flights to your computer: *Just push a
useful to newcomers to the sport who may be flying club gliders. *They
Some tips:
2. Make sure the phone has a clear view of the sky. *It's easy to
type armband.
3. For long flights, battery life may be a concern. *Turning off Wi-Fi
the car adapters available for the phone. *Battery life is also an
just came across GlidePath. The developer claims it's OLC compliant.. I
flying.
Pete
contest rules.
Mike
devices.
Anybody tried it?
Darryl
Thanks for the info - probably the cheapest way of getting an OLC
certified logger.
Am I correct in my assumption that the mapping feature will work only
with wifi or cellphone access, or does the app have the capability of
storing maps to memory?
Also, I assume it will work on an iPad, which has much better battery
life.
Mike
Old September 2nd 10, 08:03 AM posted to rec.aviation.soaring
kammeyer
Hi All,
deadline.
Some tips:
type armband.
flying.
Pete
contest rules.
Mike
devices.
Anybody tried it?
Darryl
certified logger.
Am I correct in my assumption that *the mapping feature will work only
life.
Mike
Hi Mike,
The mapping feature currently uses the iPhone's Google Maps
capability, which downloads the map tiles over the wireless
connection. Therefore, unless you have previously pulled up the Maps
app and viewed the area you will be flying in, you probably (depending
on cell reception) won't be able to view a map in flight. Certainly,
this is an area that I'm looking at for future versions. Currently,
the app is essentially a logger, a log viewer, and an easy way to
email logs, and submit them to OLC. Additionally, it provides a
simple display such as speed, ground track, and distance/bearing to
the takeoff point. It's not yet a replacement for a flight computer
or moving-map GPS. I haven't tested GlidePath on the iPad, but it
should work fine assuming you have the 3G iPad -- the Wi-Fi version
doesn't have a GPS. Also, I love feature requests. Email me if
there's something you'd like to see in an iPhone soaring app!
-Dave
Old September 2nd 10, 02:24 PM posted to rec.aviation.soaring
Tony[_5_]
certified logger.
depends on how you figure the cost. the app is 10 bucks but the phone
is what? a couple or three hundred? won't pretty much any old garmin
handheld make a file that can be converted to igc format? i just
picked up a flywithCE logger that was $120 and ready for the OLC.
Old September 22nd 10, 03:40 PM posted to rec.aviation.soaring
Andy[_1_]
certified logger.
Really? How much is an iPhone, the app, and a suitable service
contract?
Andy
Old September 21st 10, 12:29 AM posted to rec.aviation.soaring
Grider Pirate
flying.
Pete
contest rules.
Mike
External power is easy. Get a cigarette lighter USB power adapter and
hack it to add connectors to your glider battery. Another 'under
$10.00' solution.
Old September 24th 10, 03:12 AM posted to rec.aviation.soaring
Darryl Ramm
flying.
Pete
contest rules.
Mike
External power is easy. *Get a cigarette lighter USB power adapter and
hack it to add connectors to your glider battery. *Another 'under
$10.00' solution.
The iPhone is fussy about DC power adapters, many cheap USB out
cigarette lighter adapters won't work with a iPhone you are not into
mucking around with this buy one that specifically states it works
with a current generation iPhone. For the technically inclined the
difference is a couple of resistors, well documented on the Web. Some
of the cheap adapters also leak lots of RF noise that can affect your
VHF radio. Better ones should be fine.
Darryl
iPhone in a glider? Matt Herron Jr. Soaring 39 September 23rd 08 09:22 AM
iPhone and /G A Guy Called Tyketto Piloting 2 June 17th 08 01:01 AM
iPhone and /G A Guy Called Tyketto Instrument Flight Rules 2 June 17th 08 01:01 AM
iPhone in the air Ramy Soaring 2 June 3rd 08 01:03 AM
E6B for iPhone? C J Campbell[_1_] Piloting 16 September 27th 07 04:54 AM
