Std Cirrus: Blue or Gray trim color ONLY!...why?
Old September 5th 10, 12:24 PM posted to rec.aviation.soaring
Scott Alexander[_2_]
Default Std Cirrus: Blue or Gray trim color ONLY!...why?
On my last annual, the IA showed me the AD's and a special note for
Standard Cirrus gliders that they can only have "light gray or blue
trim colors only." huh???
My contest ID is "medium gray" and I was told he would "let it slide
this year".......OK!!! Whatever!!
He wasn't making it up, he showed me the printout. The IA was just as
surprised as I was. Anyone know why this is?
Scott Alexander
Standard Cirrus #118
Old September 5th 10, 01:13 PM posted to rec.aviation.soaring
Tony[_5_]
On Sep 5, 6:24*am, Scott Alexander
trim colors only." *huh???
He wasn't making it up, he showed me the printout. *The IA was just as
surprised as I was. *Anyone know why this is?
Scott Alexander
i believe it is to prevent hot spots. i think the Std Libelle and
perhaps other early glass ships have similar limitations.
Old September 5th 10, 01:31 PM posted to rec.aviation.soaring
After the multiple mid-airs we have had this year, I am wanting to add
some high-vis trim colors on the nose, wingtips and rudder. How would
I go about getting approval for a high visibility color that isn't
blue or gray? Or maybe there's a high visibility blue out there I can
use.
Old September 5th 10, 04:33 PM posted to rec.aviation.soaring
JS
Look at the Schempp website, Tech notes and downloads, standard
cirrus, TM 278-4.
On Sep 5, 5:31*am, Scott Alexander
some high-vis trim colors on the nose, wingtips and rudder. *How would
blue or gray? *Or maybe there's a high visibility blue out there I can
use.
Old September 5th 10, 06:09 PM posted to rec.aviation.soaring
"Scott Alexander" wrote in message ...
use.
Scott,
If you are a member of the SSA you might want to read John Greene's article in the Sept 1975 issue of Soaring.
(http://www.ssa.org/magazine/archive/...onth=9&page=03)
The article is on PDF page 24 & 25.
I am sure similar tests are what lead up to the creation of the AD.
HP-14 "6F"
(Which can be painted any color; however I have chosen white.)
Old September 5th 10, 04:12 PM posted to rec.aviation.soaring
use.
Scott,
HP-14 "6F"
Old September 6th 10, 05:22 AM posted to rec.aviation.soaring
Gary Boggs
Haven't test by the military shown that anything other than all white
less visable?
Boggs
use.
Old September 6th 10, 06:16 AM posted to rec.aviation.soaring
SoaringXCellence
less visable?
Boggs
use.
I think I heard that in Sweden that ALL sailplanes are required to
have "high visibility" wing tips, nose and tail. I know that several
imports from Sweden did come with such markings.
You might check with the manufacturer about how they meet the Sweden
requirements
Mike
Old September 6th 10, 09:19 AM posted to rec.aviation.soaring
David Salmon[_2_]
At 05:16 06 September 2010, SoaringXCellence wrote:
less visable?
Boggs
On Sep 5, 5:31=A0am, Scott Alexander
add
some high-vis trim colors on the nose, wingtips and rudder. =A0How
woul=
d
blue or gray? =A0Or maybe there's a high visibility blue out there
I
ca=
n
use.
requirements
Mike
Quite a long time ago, the BGA did some controlled tests re visibility
markings. I can't remember the details, but I am fairly certain that the
findings were that conspicuity patches etc did nothing to improve seeing
gliders in the air.
Dave
Old September 8th 10, 04:41 PM posted to rec.aviation.soaring
John Gilbert[_2_]
less visable?
Boggs
use.
have "high visibility" wing tips, nose and tail. *I know that several
requirements
Mike
My understanding is that the hi-vis markings are for landing out in
snow. In the air, the darker tips tend to decrease visible span.
John
sky is gray but we can still see the F-16s Pensacola Beachcomber Aviation Photos 1 January 10th 08 05:50 PM
sky is gray but we can still see the F-16 as it flys by Pensacola Beachcomber Aviation Photos 0 January 10th 08 05:28 PM
sky is gray but we can still see the F-16 as it flys by.... Pensacola Beachcomber Aviation Photos 0 January 10th 08 05:27 PM
Does anyone know if FS 26270 Haze Gray = RAL 7042 Traffic Gray ? Landy Man Naval Aviation 2 January 9th 08 03:42 AM
