iPAQ-310-LK8000-wind calculation
Old September 7th 10, 05:31 PM posted to rec.aviation.soaring
Brad[_2_]
Default iPAQ-310-LK8000-wind calculation
I have my HP-24 set up with the iPAQ 310 and it is running the latest
LK8000 software, since the aircraft hasn't flown yet I am curious to
know if anyone out there is using this combination and what they have
noticed regarding the wind calculation function (not the true wind
feature).
I am using the same software, but a PDA/Garmin GPS set up in my Apis.
I am very happy with the wind feature and am hoping the 310 will be as
"accurate"
I know there are numerous threads where this subject is embedded, but
would like to have a thread just for this subject.
thanks,
Brad
Old September 7th 10, 06:03 PM posted to rec.aviation.soaring
Andy[_1_]
feature).
If you are using the HP310 internal GPS you can expect the LK8000
circling wind calculation to produce an unreliable wind estimate
unless you thermal at a very low turn rate.
In small Arizona cores that require high bank angles my experience is
that the internal GPS gets hoplessly confused and the wind estimate
cannot work because it does not have good circling position data.
In smooth late afternoon thermals worked at low bank angles the wind
estimate is in the same ball park as my 302 with Glide Nav II.
I don't think there is anything wrong with LK8000 wind calcs but you
will need an external GPS with a fast update rate to give it a chance
of producing a valid result.
Andy
Old September 7th 10, 07:01 PM posted to rec.aviation.soaring
jb92563
feature).
Andy
I concur that the higher turn rate reduces the ability to get a good
wind direction fix.
It seems to me that the reason might be that the position fixes are
produced at a maximum rate of 1/sec under ideal conditions
and that just does not seem to be enough resolution when making small
circles.
I wonder if there is a way to get more fixes or create your own
virtual fixes by projecting a position based on the turn rate and
average diameter to help out the wind calculator?
Ray
Old September 7th 10, 07:06 PM posted to rec.aviation.soaring
Darryl Ramm
feature).
Andy
wind direction fix.
circles.
Ray
I think this has all been covered in the past.
It is not the update rate, it is the iPAQ 310 internal GPS doing
position extrapolation/smoothing based on past velocity - designed
for road navigation. This "feature" cannot be disabled in the internal
GPS, technical folks have tried...
Use an external GPS and you'll be fine. Presumably an external
bluetooth will work, I've not tried it. This was one of the
limitations with the iPAQ 310 that many of the early purchasers,
including me, discovered to our annoyance.
Darryl
Old September 7th 10, 07:21 PM posted to rec.aviation.soaring
Brad[_2_]
feature).
Andy
wind direction fix.
circles.
Ray
position extrapolation/smoothing *based on past velocity - designed
Darryl
Thanks guys, I just talked to Paul Remde and bought an external GPS
unit that will plug right in to the PS-5a and send all the info to the
310.
I just got back from a mountain flying expedition and the wind info
was critical to my successful flights...............at least it seemed
to help me a lot and I will want the same features for the HP-24.
Darryl, yep......you're right..........this subject has come up often
and now for me I dropped the dime and have some resolution!
Brad
Old September 7th 10, 07:47 PM posted to rec.aviation.soaring
PCool
That's correct, the HP310 (and 314, 316) has a "feature" you cannot disable
in its embedded GPS: in order to filter out bad readings (that are highly
unlikely to happen anyway) it looks at what you are doing, trying to "guess"
the correct position when you are turning fast and tight.
Sure, you may turn slow and in large circles.. but that's not good for
thermalling, it is good only in a car at a roundabout! (hehe).
This will result in bad wind calculation in the LK8000/XCSoar circling wind
calculation engine. Which is in my opinion very accurate.
It is simply rejecting the "guessed" positions, thus not having enough data
to process it won't compute the wind sometimes.
In my opinion, having an HP31X, the best solution is to get an RS232 USB
cable (custom for the HP) and connect it to an external instrument feeding
both GPS position and barometric pressure (altitude). A Flarm will do it,
and send also traffic informations at the same time.
Using BlueTooth is an option, and the automatic fallback feature of LK on
dual rs232 feeds can be helpful when BT is dropped: in this case, the
internal gps is going to be used and flight can continue.
However, while choosing a BT GPS, it is important that it is both Slave and
Master BT, which is not obvious.
Otherwise the connection cannot be established and resumed automatically by
the HP.
FYI, many other (even cheap) PNAs can use the HP's serial cable. MIOs,
NILOX, and probably some navigon and virtually all PNAs declaring external
TMC capability (because TMC is using serial rs232 TTL connection).
Also, we recently discovered that some cheap PNAs that were looking bad
under sunlight, were very good readable using.. polarized sunglasses! So,
the race to the "perfect" PNA is still open.
paolo
"Brad" ha scritto nel messaggio
On Sep 7, 11:06 am, Darryl Ramm wrote:
On Sep 7, 11:01 am, jb92563 wrote:
On Sep 7, 10:03 am, Andy wrote:
latest
have
feature).
Andy
wind direction fix.
circles.
Ray
Darryl
310.
Brad
302 wind calculation AK Soaring 21 April 3rd 10 01:27 PM
302 wind calculation 5Z Soaring 1 March 26th 10 11:56 AM
302 wind calculation Darryl Ramm Soaring 0 March 26th 10 03:04 AM
302 wind calculation AK Soaring 0 March 26th 10 02:47 AM
Vector Wind, Relative Wind calculation C 302/303 [email protected] Soaring 2 December 9th 08 07:23 PM
