Best instrument combination
Old September 12th 10, 06:30 PM posted to rec.aviation.soaring
ryanglover1969[_2_]
Default Best instrument combination
Looking for some consensus of opinion on what is the best combination
of flight computer, logger and PDA. / soaring software.
Recently sold my glider with LX 1600, Colibri and 3800 series Ipaq
running SeeYou Mobile. I liked the set up ok, but there were some
minor glitches, as I'm sure there are with any set up. What do you
think is the best? And cost is a factor.
Old September 12th 10, 07:46 PM posted to rec.aviation.soaring
jcarlyle
I predict the consensus will be "whatever I have in my ship". Having
said that, I have a SN-10B, a Volkslogger, and an iPAQ 3950 running
Glide Navigator II. The Volkslogger because its utterly reliable and
interfaces with the SN-10B (although the VL does have some quirks).
GNII because it's really simple to use and tells me only what I need
to know about where I am, what my options are and what's coming up.
The SN-10B because it's dead nuts accurate with wind and final glide
(although it does have a rather steep learning curve).
-John
Old September 12th 10, 07:49 PM posted to rec.aviation.soaring
ryanglover1969[_2_]
-John
Thanks John! That's exactly the kind of information I'm looking for.
Anybody else want to weigh in?
Old September 12th 10, 08:25 PM posted to rec.aviation.soaring
Morgan[_2_]
I run two different setups in the two gliders I own. My ASW-20 has an
old Zander SR 820. No GPS, but decent speed-to-fly and netto vario
calculations. For navigation I have a PNA with XCSoar. Slightly more
workload since I've got two instruments to set Macready on if I'm
trying to keep them in sync. I generally don't worry too much about
that though. Leave the PNA at MC2.0 or so depending on the day and it
gives me enough info about what is reachable that I can always fly
faster/slower on a final glide and watch my arrival height. Word of
caution on the PNA though, the GPS altitude is not terribly accurate,
though it seems fairly linear in how much it is off. So while it may
be off by 1000ft at 17500, down low it is usually off by less. It's
just something to be aware of since if you've got a marginal final
glide it might be overly optimistic with your actual height.
In our Duo, we've got a Cambridge L-nav and GPS-nav model 20. In
general the wind calculations from circling are pretty comparable with
the XCSoar. While I think it is supposed to calculate wind while on
glide, I don't trust it much. I think the SN10 does a better job.
Final glide and speed-to-fly are good with clear push-pull visual and
audio indications. Final glide is total-energy compensated so if
you're on a fast final glide, the height of finish includes a pull-up
at the end. Just something to keep in mind, but this can also be
useful when dolphin flying as it will tell you if you're really being
more efficient by pulling up in lift since a poorly timed pull-up will
usually result in more height, but less energy as far as the flight
computer is concerned.
I still fly with XCSoar in the Duo as a backup and moving map for
reachable airfields as the interface is so much more intuitive at a
glance. Another nice aspect of XCSoar (probably other PDA/PNA tools
as well) are the thermal statistics available. On my thermalling
screen I keep the "thermal climb" and "thermal climb all" fields
available. At a glance you can see what your achieved climb in the
current thermal including centering. Nice for having a less
subjective view on your thermal rather than a 30 sec average or your
mental average.
I only have about 3 flights in a Duo with an SN-10, but I liked it.
Not your cheapest option for sure.
-John
Old September 12th 10, 09:13 PM posted to rec.aviation.soaring
ContestID67[_2_]
I love the Cambridge 302. Good flight computer, audio variometer*,
speed to fly, averager, recorder, GPS, airbrake warning, and supplies
5VDC to my PDA. All in 2-1/2".
I believe that most would believe that a moving map is a MUST have. I
would love to have the new Clearnav but cost and panel real estate
holds me back. Anyway, I have a standard PDA with Glide Nav II which
seems fine for what I do. But take that with a large grain of salt as
I haven't flown much with anything else.
So, two pieces of equipment and I think that you are set to go.
* What I find really interesting about the 302's audio variometer are
the tones that it emits. Obviously, it has the standard lift/sink
stuff. But beyond that if you are in sink and flying the correct
speed the sink tone will go away to say that you are doing the right
thing. If you are in lift and nearing stall speed, the tone modulates
in a more "urgent" way. Cool.
My $0.02.
- John
Old September 12th 10, 09:29 PM posted to rec.aviation.soaring
Andreas Maurer
On Sun, 12 Sep 2010 11:49:49 -0700 (PDT), ryanglover1969
I'm with John - SN-10, Ipaq 3970 running SeeYou, and a Volkslogger.
Andreas
Old September 12th 10, 10:06 PM posted to rec.aviation.soaring
ASW-27: LNav, CAI Model 20 connected to 1520 running Glide NavII. Easy
to use, excellent audio and TE.
Takes about 10 minutes to know enouigh to use effectively.
ASW-28: 302 connected to 1520/GlideNavll. Touchier TE tuning. Speed to
fly communication not as good as LNav.
ASK-21: LNav with ClearNav. Don't laugh! This is the glider that
really needs the glide amoeba. Most time to learn and not as quich to
use as Glide Nav, but display and information presentation is
excellent.
Eventually the 27 and 28 will get ClearNav.
FWIW
UH/OH/K21
Old September 12th 10, 10:55 PM posted to rec.aviation.soaring
John Cochrane[_2_]
1) My current favorite: Clearnav, NK vario (hopefully coming soon!),
flarm as backup logger.
The clearnav works great, and presents the information you need,
quickly, with a minimum of fussing and fiddling.
Until the NK vario / flarm are available a 302 is a great vario and
backup GPS.
2) SN10. I used to have one. Great instrument, very accurate, very
solid and dependable. The downside is a smaller display, usually
needing an extra moving map, the need to page through lots of
numerical information. For pilots who don't really drool over the huge
map on the clearnav the downside is an upside.
3) LX. I don't have one, but buddies who do swear by them.
Avoid:
-PDAs! For the few thousand you spend on good instruments like the
above, say goodbye to batteries that die from age, batteries that die
if you leave it unplugged for 20 minutes, batteries that die over the
winter even though you left it plugged in all the time, rushing to
walmart to find backup batteries, batteries that swell up and blow
out the back of the pda and won't go back in; rebooting in flight,
hard rebooting in flight (Lost the stylus again! Now what can I find
in the cockpit to stick in the reboot hole?) , hard rebooting in
flight 5 minutes before the start gate opens, hard rebooting in flight
while driving down the ridge 10 miles from the next MAT turnpoint,
reentering the entire task in flight after the above, SD cards that
die, squinting to see what it actually says, making cheesy shades to
keep the sun at Uvalde from overheating the darn thing, and so on.
(All of the above are true stories). PDA lifespan is also less than
real instruments, so you'll buy 2 or 3 before you're done.
-Legacy instruments. The new ones are better.
Pay attention to:
-Support, especially for US pilots. I know first hand that NK and SN10
are both excellent at this. If there's a rule change or a bug, they
fix it fast.
Cost? Don't be cheap on vario/av! This is by far the most important
piece of your glider for doing well in competition and cross country.
Buy a glider that costs $4000 less, or forego the new winglets or
wingrigger or some other glider doodad somesuch, but don't be cheap
about vario and nav if you want to do well and avoid endless
frustration.
Be sure to cost out an entire system including GPS, speed to fly
vario, display, moving map, extra wires, brackets, connection gear,
backup GPS, backup vario if you want one. The integrated computers
seem expensive, but once you add up the parts it's a better deal than
it seems.
John Cochrane
Old September 12th 10, 11:20 PM posted to rec.aviation.soaring
ryanglover1969[_2_]
On Sep 12, 2:55*pm, John Cochrane
backup GPS.
Avoid:
-PDAs! *For the few thousand you spend on good instruments like the
walmart to find backup batteries, *batteries that swell up and blow
(All of the above are true stories). *PDA lifespan is also less than
Pay attention to:
fix it fast.
Cost? *Don't be cheap on vario/av! This is by far the most important
frustration.
it seems.
John Cochrane
I loved my LX 1600 and the colibri was alright, but man I could not
stand the PDA. You're right about the rebooting in flight and all the
other issues. I keep telling myself it was just the model PDA I had,
3600 then 3800. I wonder if the Oudie in more reliable?
Old September 13th 10, 04:04 AM posted to rec.aviation.soaring
Westbender
302/303. Don't care much for PDA's. I'm not a contest flyer, so the
CAI system is more than enough for me. Simple, easy to use, easy to
read in sunlight, and doesn't require much "heads down" time in the
cockpit.
SN-10b EW flight recorder/PDA combination Jim Archer Soaring 5 November 18th 08 12:30 PM
Combination of Iranian Mig-31BMs with F-14 Tomcats Amir - Iranian F-4 pilot Naval Aviation 10 July 23rd 07 07:41 PM
FS2002 de-icing key combination? Thomas Peel Simulators 0 May 21st 04 01:50 PM
JSF/Typhoon combination good? John Cook Military Aviation 6 May 11th 04 03:12 AM
