Glass Cockpit Architecture
by: Douglas Eagleson 2010 A proper glass window cockpit display is a hard system to design. Fault tolerance become the primary issue. A display of engine and flight controls as a primary visual information panel becomes a central control computer. I have considered all architectures and have decided on a modifed system than is commonly found. I invented a modified slave-master communicattion system suitable for fighter aircraft. Homebuilts should also avail themselves of this technology. A glass central computer appears to be suitable as long as auxilary display is available. Making slave instruments of ALL data displayed on the glass window. Boot up time afteer poer failure is critical to proper aircraft control an slave instruments should boot-up and display data very very fast. A glass window trailing the slaves allows for a controled recovery following power failures. One communication line per slave. A multicommunication line master is demanded. A custom operating system that allows even simple serial lines as a network appears the best possible world of glass cockpits. 10 com lines are possible in MS-DOS. I would recommend this as a good homebuilt aircraft glass master computer operating system. Here is my invention. A pole command on a serial line demands an answer from the slave. Normally the issue ends here be close examination determines a fault with this architecture. Timing of power failure recoveery means that slave recovery must be faster than glass master recovery. Allowing a valid communication at ALL times. Noise from a lightnening strike can cause intermediate states of serial line validity. How to ALWAYS have valid slave-master communication lines is the technolgy invention. Invalid serial line communication recovery is critical also. Making a special version of RS-232 a manditory invention to assure valid glass operation. SEND-RECIEVE paired lines appears the failure. A single line system always ensures valid communications. Mistiming is vertually eliminated. SO I propose a new RS-255 standard. Watch as a communication line state appears necessary all the time for the slave and only briefly for the master. Watching a single line enforces cpu code runtime synchronization with communication line operation. When the code waits it only has a certain time span window of waiting. It is a critical technology for superior glass systems. RS-255. Modifying MS-DOS to RS-255 is a very small task. Simply twist the RS-232 send and recieve lines together and runtime code synchronize the single RS-255 line. It is hardly patentable so I send it out public domain. Fighter quality slave-master communication is possible even in a homebuilt. |
Glass cockpit hard to read | Arno | Piloting | 83 | October 9th 07 06:41 AM |
OSH Homerun? Glass Cockpit for the Budget-Challenged | Marco Leon | Piloting | 4 | July 27th 07 11:27 PM |
Avionics architecture / Systems is this good info??? | [email protected] | General Aviation | 0 | January 26th 07 02:29 AM |
Why Not Use PC To Make Glass Cockpit? | Le Chaud Lapin | Instrument Flight Rules | 52 | July 19th 05 03:45 AM |
Glass Cockpit in Older Planes | Charles Talleyrand | Owning | 2 | May 20th 04 01:20 AM |
