Question About Mid-Air Collisions
Old September 15th 10, 07:46 PM
jason219 jason219 is offline
Junior Member
First recorded activity by AviationBanter: Sep 2010
Default Question About Mid-Air Collisions
Hello everyone. I'm preparing a mock press conference for one of my college classes. In my particular scenario, I am the public relations head of a top international airliner.
Three hours into the flight, one of our planes was involved in a mid-air collision (whether it was with another aircraft or another object, I am not sure). The plane is still airborne but is only able to fly higher and to the right. All attempts to make a left turn or decrease altitude have failed.
I need some expert knowledge on what would happen in this situation. Judging by the damage, is it possible to land the plane safely? Is an emergency landing feasible? If so, what would the steps necessary be to execute it and how long (roughly) would that take?
Thank you for your help!
Old September 16th 10, 02:21 AM posted to rec.aviation.piloting
Mark
On Sep 15, 2:46*pm, jason219
Hello everyone. *I'm preparing a mock press conference for one of my
have failed.
Judging by the damage, is it possible to land the plane safely? *Is an
jason219
Although the airfoil surfaces are stuck in a
position to induce lift, the plane would be induced to decrease
elevation by throttle reduction or fuel mixture. If you can only
turn left you won't make it.
Mark
Old September 16th 10, 02:59 AM posted to rec.aviation.piloting
Mark wrote:
On Sep 15, 2:46Â*pm, jason219
Hello everyone. Â*I'm preparing a mock press conference for one of my
have failed.
Judging by the damage, is it possible to land the plane safely? Â*Is an
jason219
Airliners don't have mixture controls.
Jim Pennino
Remove .spam.sux to reply.
Old September 16th 10, 06:51 AM posted to rec.aviation.piloting
Ari Silverstein
have failed.
jason219
*lol*
A fireside chat not with Ari!
http://tr.im/holj
Motto: Live To Spooge It!
Old September 16th 10, 11:27 AM posted to rec.aviation.piloting
Mark
have failed.
jason219
elevation by throttle reduction or fuel mixture. *If you can only
Jim Pennino
Thank you. I stand corrected.
You're still a pinhead.
Mark
Old September 16th 10, 01:49 PM posted to rec.aviation.piloting
Help! I Need SomeBooty!
have failed.
jason219
Jim Pennino
You're still a pinhead. I am still a gay bipolar ****nutzoid.
Mark
The beginning of recovery is admission.
Old September 16th 10, 07:28 AM posted to rec.aviation.piloting
Jean O'Boyle[_3_]
Mark
Assclown post.
Beware.
http://tinyurl.com/5gt7
Old September 16th 10, 02:27 AM posted to rec.aviation.piloting
have failed.
This can not happen.
If you reduce or eliminate engine power, the airplane will come down.
Also, eventually an airplane will stop climbing.
The situation just isn't realistic.
While it is remotely possible that the controls could get damaged to the
extent that the airplane can only be turned in one direction, there is
still the use of unbalanced thrust from the engines to control direction,
and this has actually been done in airliners and military aircraft.
If nothing can control the aircraft heading, about all you can do is reduce
power, spiral down, and hope where the airplane touches the ground is
open and flat.
Jim Pennino
Old September 16th 10, 09:56 AM posted to rec.aviation.piloting
D Ramapriya
By the OP's "all attempts to decrease altitude have failed" statement,
I take it that moving the throttle has for some reason stopped ceased
to have an effect on N1.
The aircraft would fly right up to its ceiling altitude before it kind
of levels out until the A-1 exhausts. If the oxygen masks don't drop
for whatever reason, there'll at least be mercifully painless deaths
to the pax.
Ramapriya
Old September 16th 10, 04:42 AM posted to rec.aviation.piloting
Mxsmanic
jason219 writes:
have failed.
First, it's never impossible to decrease altitude. All you have to do is
reduce power, and you descend. If for some reason you cannot adjust the
control surfaces at all, and cannot control the engines at all, you'll still
descend once you run out of fuel. So that part isn't very realistic.
As for being able to turn right but not left, that would require an extremely
unusual set of circumstances, since the same control surfaces are used for
turns in both directions. And since a turn begins by rolling the aircraft, an
inability to roll it in the opposite direction would make it impossible to end
the turn in most cases, and ultimately bad things would happen.
But let's assume that both types of damage are possible. In that case, the
airplane can never land, since it cannot descend. Let's suppose that it finds
a way to descend, then. If it still only only turn right, it might be able to
find its way down to an airport. It could work its way down with just right
turns, but the final approach would be extremely difficult, since only
corrections to the right would be possible, and any circumstance that might
require turning left (such as maintaining alignment with the runway) would
require starting over with the approach. This does not bode well for a safe
landing, unless the aircraft has expert pilots and unlimited fuel aboard.
It might be better to select a different type of damage. The loss of all
controls except engines has already happened, for example. See United Airlines
Flight 232 (most of the people aboard survived) and JAL Flight 123 (all but
four of the 524 people aboard the aircraft died).
If all midair collisions were eliminated... Jim Logajan Piloting 138 February 19th 10 11:20 PM
Mid Air Collisions Sukumar Kirloskar Soaring 2 July 3rd 08 02:42 PM
Mid Air Collisions Sukumar Kirloskar Soaring 4 July 3rd 08 02:27 PM
Mid-Air Collisions JJ Sinclair Soaring 26 April 19th 04 08:52 AM
MID AIR COLLISIONS Vorsanger1 Soaring 2 April 16th 04 04:17 AM
