Is there an easy way to check that my solar powered vent on top of the
Cobra trailer is functioning properly? I haven't heard it running lately, but don't really know what triggers it to run (besides light of course...) Thanks, Matt |
If it's the Intersolar vent as delivered from Cobra, it's likely
"D.E.D." The 4" Nicro Day/Night vent with C-cell NiMH battery works very well. You'll just need to drill 3 new mounting holes and plug the old ones if replacing an Intersolar vent. If the battery is completely dead, the Nicro may not work. If the push-button switch inside (not everyone knows it's there) is in the OFF position, it won't do much either. The Nicro is available from most gliding suppliers or marine suppliers. Jim |
So these things are designed to run continuously? They don't kick on
when the temp is above a set point? |
On Sep 25, 10:13*pm, "Matt Herron Jr." wrote:
So these things are designed to run continuously? *They don't kick on when the temp is above a set point? Nope. They just run whenever there is power (sun or battery) available, as long as the push-button switch (which some don't have) is ON. |
On Sep 26, 8:35*am, brianDG303 wrote:
On Sep 25, 10:13*pm, "Matt Herron Jr." wrote: So these things are designed to run continuously? *They don't kick on when the temp is above a set point? Nope. They just run whenever there is power (sun or battery) available, as long as the push-button switch (which some don't have) is ON. Now, with winter coming, is a great time to hear the assembled wisdom (and random opinions!) of r.a.s. on the trailer vent issue. It's been nagging me for years. Most trailers are left outside. Go look at your glider at 6 am. It's covered with condensation. Bad. The sun comes out, the condensation dries, and the vent sucks it all out. Well, that's better than no vent, in which case it would stay dripping all day and the gel coat would peel off in your hands after a few months. I bought a little recording hygrometer to test all this, and the result is frightening -- 100% relative humidity for the early morning hours. So, I got a battery powered vent that sucks all night too. But am I doing any good? I'm just sucking in more humid air. I stack the thing with drying crystals, but who knows if that is helping. Sure, they soak up a lot of moisture, but since I'm also venting perhaps they are just drying air that I then promptly pump outside. The right answer is to hook it up to power and throw in a dehumidifier. This works like a charm... but there is no power at my trailer. A small heater works well too, and I use one over the winter. But there is no power at my trailer. An even better answer of course is to store it inside in a humidity controlled environment. Note: The average hangar can be worse than outside. They leak, the solar vent no longer works, and that huge concrete slab below you is a humidity magnet in the springtime; it also keeps the glider from warming up and drying out. Sooo. Does anyone have hard data or anything other than obvious opinions on what works best? Vents were solution 1.0 to this problem. Are battery powered vents better or worse? What's solution 2.0? Some solar powered heating or dehumidifier system seems to be the way to go, but it has to cost less than a hangar. John Cochrane |
On Sep 26, 11:42*am, John Cochrane
wrote: On Sep 26, 8:35*am, brianDG303 wrote: On Sep 25, 10:13*pm, "Matt Herron Jr." wrote: So these things are designed to run continuously? *They don't kick on when the temp is above a set point? Nope. They just run whenever there is power (sun or battery) available, as long as the push-button switch (which some don't have) is ON. Now, with winter coming, is a great time to hear the assembled wisdom (and random opinions!) of r.a.s. on the trailer vent issue. It's been nagging me for years. Most trailers are left outside. Go look at your glider at 6 am. It's covered with condensation. Bad. The sun comes out, the condensation dries, and the vent sucks it all out. Well, that's better than no vent, in which case it would stay dripping all day and the gel coat would peel off in your hands after a few months. I bought a little recording hygrometer to test all this, and the result is frightening -- 100% relative humidity for the early morning hours. So, I got a battery powered vent that sucks all night too. But am I doing any good? I'm just sucking in more humid air. I stack the thing with drying crystals, but who knows if that is helping. Sure, they soak up a lot of moisture, but since I'm also venting perhaps they are just drying air that I then promptly pump outside. The right answer is to hook it up to power and throw in a dehumidifier. This works like a charm... but there is no power at my trailer. A small heater works well too, and I use one over the winter. But there is no power at my trailer. An even better answer of course is to store it inside in a humidity controlled environment. Note: The average hangar can be worse than outside. They leak, the solar vent no longer works, and that huge concrete slab below you is a humidity magnet in the springtime; it also keeps the glider from warming up and drying out. Sooo. Does anyone have hard data or anything other than obvious opinions on what works best? *Vents were solution 1.0 to this problem. Are battery powered vents better or worse? What's solution 2.0? Some solar powered heating or dehumidifier system seems to be the way to go, but it has to cost less than a hangar. John Cochrane The opinion we have at our airport (and that's all it is, I'm afraid), is that the purely solar powered vents are best. When the weather is warm and dry and sunny they pull air through your trailer and dry it out. When the weather is damp and cloudy they leave well enough alone. My plane sat parked in its trailer for 6 years before I bought it. It didn't have a solar vent. The condensation would collect on the wings and fuselage, run down to the low point (leading edge of the wings), and gradually rot the gelcoat. It had to have a partial refinish of the leading edges before I bought it. I got a solar vent and installed it early this year to improve the circulation. In my case the passive vents were in the front of the trailer, so I put mine on top of the doghouse. -- Matt |
On Sep 26, 8:42*am, John Cochrane
wrote: On Sep 26, 8:35*am, brianDG303 wrote: On Sep 25, 10:13*pm, "Matt Herron Jr." wrote: So these things are designed to run continuously? *They don't kick on when the temp is above a set point? Nope. They just run whenever there is power (sun or battery) available, as long as the push-button switch (which some don't have) is ON. Now, with winter coming, is a great time to hear the assembled wisdom (and random opinions!) of r.a.s. on the trailer vent issue. It's been nagging me for years. Most trailers are left outside. Go look at your glider at 6 am. It's covered with condensation. Bad. The sun comes out, the condensation dries, and the vent sucks it all out. Well, that's better than no vent, in which case it would stay dripping all day and the gel coat would peel off in your hands after a few months. I bought a little recording hygrometer to test all this, and the result is frightening -- 100% relative humidity for the early morning hours. So, I got a battery powered vent that sucks all night too. But am I doing any good? I'm just sucking in more humid air. I stack the thing with drying crystals, but who knows if that is helping. Sure, they soak up a lot of moisture, but since I'm also venting perhaps they are just drying air that I then promptly pump outside. The right answer is to hook it up to power and throw in a dehumidifier. This works like a charm... but there is no power at my trailer. A small heater works well too, and I use one over the winter. But there is no power at my trailer. An even better answer of course is to store it inside in a humidity controlled environment. Note: The average hangar can be worse than outside. They leak, the solar vent no longer works, and that huge concrete slab below you is a humidity magnet in the springtime; it also keeps the glider from warming up and drying out. Sooo. Does anyone have hard data or anything other than obvious opinions on what works best? *Vents were solution 1.0 to this problem. Are battery powered vents better or worse? What's solution 2.0? Some solar powered heating or dehumidifier system seems to be the way to go, but it has to cost less than a hangar. John Cochrane You could buy about 100 of these: http://tinyurl.com/254daal If your trailer is well sealed maybe you won't have to dry them out on a regular basis. I think traditional dehumidifiers draw 3-5 amps - too much for solar or battery. 9B |
On Sep 25, 10:17*pm, "Matt Herron Jr." wrote:
Is there an easy way to check that my solar powered vent on top of the Cobra trailer is functioning properly? *I haven't heard it running lately, but don't really know what triggers it to run (besides light of course...) Thanks, Matt Lie down next to the fuselage. Have your significant other close, latch, and lock the trailer. After a couple of days in there you should have a pretty good idea of how its working. See ya, Dave |
COBRA TRAILER | Gordon Schubert[_2_] | Soaring | 0 | February 10th 09 04:15 AM |
Cobra Trailer | [email protected] | Soaring | 22 | December 7th 06 11:38 PM |
Solar vents delivered on Cobra trailers | Dan Dunkel | Soaring | 7 | April 4th 04 08:38 PM |
Cobra Trailer | Soaring | 1 | September 28th 03 01:14 PM | |
FS: Cobra Trailer | Ed Byars | Soaring | 0 | September 22nd 03 04:47 PM |
