air drill question
Old November 20th 03, 01:14 PM
Ded Dog
Default air drill question
what rpm range best for aluminum sheet metal? 2600? 3600? less? more?
thanks KM
Old November 20th 03, 05:52 PM
Steve Robertson
Wow. I'm glad I just started reading this group. What a helpful bunch here!
I'll the the original poster would never have thought about looking it up.
Steve Robertson
N4732J 1967 Beechcraft A23-24
Orval Fairbairn wrote:
thanks KM
It is all a function of drill size -- available in metalworking books.
Old November 20th 03, 08:47 PM
Lpmcatee356
Not everything that you and I might take for granted is common knowledge among
some of the new builders - or even somewhat experienced ones. And sometimes
those of us that have been doing "it" for a score+ years forget that not
everybody knows the basics.
To answer the original post - the smaller the drill bit the faster you
can/should turn it.
In my experience:
for sheet metal work (drilling #30 holes) the fastest air drill you can buy is
none too fast.
A sharp split point bit and an accurate center-punch help too.
Old November 21st 03, 01:01 AM
Larry Smith
Here you go, for the air drill speed. Scroll down about 1/4 to Veeduber's
(R. S. Hoover's) Riveting 101, etc. Course, natcherly giving a nod of
approval to Ron Wanttaja's marvelous website:
http://home1.gte.net/ikvamar/avlinks/index.htm
"Lpmcatee356" wrote in message
here!
up.
among
sometimes
can/should turn it.
In my experience:
buy is
none too fast.
Old November 21st 03, 04:20 AM
Del Rawlins
On 20 Nov 2003 11:47 AM, Lpmcatee356 posted the following:
here! I'll the the original poster would never have thought about
looking it up.
knowledge among some of the new builders - or even somewhat
experienced ones. And sometimes those of us that have been doing "it"
for a score+ years forget that not everybody knows the basics.
can/should turn it.
In my experience:
can buy is none too fast.
A quick and dirty back of the envelope calculation shows that a 1/8" bit
can be spun in excess of 9000 RPM in aluminum. Higher grade bits can,
of course, be spun faster, but the bottom line is that for drilling
rivet holes in sheet aluminum, no generally available drill is going to
be too fast.
I recently purchased a 6000 rpm Sioux air drill and find it to be
ideally suited for sheet aluminum work. I've worked with standard air
drills at around 2800rpm and I didn't like them as much, although they
work far better than the garden variety of electric drills, which always
seem to be too slow for aluminum, but too fast for steel. My drill
motors are the aforementioned Sioux, and a 1200RPM Porter-Cable electric
which is great for steel but will twist your arm off if you let it dig
in.
Del Rawlins-
Remove _kills_spammers_ to reply via email.
Unofficial Bearhawk FAQ website:
http://www.rawlinsbrothers.org/bhfaq/
Old November 23rd 03, 06:25 PM
Del Rawlins
On 23 Nov 2003 04:26 AM, Stealth Pilot posted the following:
On 20 Nov 2003 20:47:30 GMT, (Lpmcatee356)
looking it up.
for a score+ years forget that not everybody knows the basics. To
can/should turn it.
In my experience:
can buy is none too fast. A sharp split point bit and an accurate
our experiences differ.
my experience is that most drills spin too fast, particualrly for
aluminium.
the speed of your average cordless battery drill is about right and
allows far better control for freehand drilling.
Stealth Pilot
I agree with the other guy, the faster the better. I don't see how
using a heavy electric drill with a heavy attached battery makes it
easier to control. My Sioux with a lightweight air hose is much easier
to work with than any cordless I have tried, for rivet hole sizes,
anyway. If I'm going to be using my unibit or a larger twist drill I
agree that an electric might be easier to work with.
Del Rawlins-
Old November 21st 03, 04:27 AM
Del Rawlins
On 20 Nov 2003 08:52 AM, Steve Robertson posted the following:
looking it up.
If the original poster is new to aircraft sheetmetal work he needs to
get a book even if he does find the answer to his question here. There
are just too many things that need to be looked up like bend radii and
figuring setback/bend allowance et cetera.
A drill speed chart is handy, but if you know what the allowable cutting
speed is for your bit material in the work material, you can easily
calculate the maximum RPM based on the diameter of the drill bit using
pi times the diameter. The short answer is that he isn't going to find
a drill that is too fast for drilling rivet holes in aluminum, and the
faster the drill he buys, the better it will work.
Del Rawlins-
Old November 21st 03, 12:46 AM
Larry Smith
"Ded Dog" wrote in message
om...
thanks KM
Read Veeduber's article on the subject. It's a great article chockfull of
good info. It's at Ron Wanntaja's website. What I recall is that it's
somewhere around 30,000.
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 01:51 AM
Tool Question??? Paul Home Built 2 September 1st 03 04:06 PM
Question on Pulsejets/Ramjets??? DarylG1532 Home Built 3 August 16th 03 03:20 AM
Structural adhesive question BD5ER Home Built 1 August 3rd 03 06:03 AM
Fairing question... Tina Marie Home Built 5 July 16th 03 12:18 AM
